Some Thoughts on Atmospheric Systems
In summary, atmospheric sciences are a difficult and constantly expanding field that is still struggling to perfect its forecasting abilities.
klimatos
411
36
Atmospheric sciences are—much like the sister science of astronomy—primarily observational sciences and not primarily experimental sciences. The atmospheric systems that we study are not well-defined systems under controlled conditions, but ill-defined systems under completely uncontrolled conditions. Let me elaborate on this concept:
1. Atmospheric systems are open systems. They are neither isolated nor closed. There are continuous interchanges of both matter and energy between free atmospheric systems and their environments.
2. Both system masses (M) and system volumes (V) are indeterminate as a consequence of these interchanges. Both the spatial boundaries and the temporal boundaries of atmospheric systems are vague and ill-defined. Atmospheric systems are not separate from their environments, but are vigorously mingling and interacting with them. Expressions that require a definite value for either system mass or system volume have limited applicability to the study of the free atmosphere.
3. Within any atmospheric system, the values for pressure, temperature, and molecular number density are continuously changing. This change is from place to place within the system at any given instant, and from time to time at any given location. This is why these variable are shown as means (bar over parameter designation) in most atmospheric studies rather than uniform values (no bar) as in many laboratory studies. We prefer to speak of system temperatures and pressures (plural) rather than system temperature and pressure (singular). This usage recognizes the dynamic nature of atmospheric systems.
4. Atmospheric systems all contain water vapor. Most weather systems contain liquid water and/or solid water (ice) as well. Since the triple-point for water (273.16K) is well within the normal range of atmospheric temperatures, changes of phase are common occurrences in atmospheric systems. Hence, observations based on the behavior of dry air under laboratory conditions are of limited value in understanding the operation of real free atmospheric systems.
5. Atmospheric systems are non-equilibrium systems. All atmospheric systems in the real free atmosphere are dynamic systems. Change is the essence of weather systems. Weather systems are never under conditions of equilibrium.
If you are looking at a real atmospheric system, you may safely assume that it is not functioning under conditions of equilibrium. A tiny little “dust devil” at the corner of a building is a good example of a simple atmospheric system. A cumulonimbus cloud is a somewhat more complex atmospheric system. Neither is ever operating under conditions of equilibrium.
[I define a "real" system as one whose parameters were obtained by observation and measurement--not through postulates or hypotheses. I define a "free" system as one that is not contained or restricted in any way.]
Summary. Very few—if any—gas laws are universal. Many of them apply only to ideal gases, and many others require conditions of equilibrium to be valid. Some require that an atmospheric parameter be held constant while one or more others are varied. This is simply not going to happen with free atmospheric systems.
Generally speaking, when considering the application of a particular gas law to any atmospheric system, you should also consider the many prerequisites that must exist for that law to be valid.
I'm not sure if your trying to make a point beyond what you stated, but I'll respond with some of my own thoughts.
Meteorology is certainly a challenging science - and now it's expanding to extra terrestrial domains.
My most intensive introduction to the subject was about 35 years ago when I was studying for my pilot's license.
Despite those difficulties, forecasting ability has improved enormously over the decades. From my own experience, 35 years ago in the Virginia area they were often unable to accurately report current winds aloft or predict thunderstorms for later in the day with any reliability.
Today, 10 day forecasts are not bad. On the other hand, over the past decade, predictions for the upcoming hurricane seasons have been less reliable than random guessing.
One of the problems with atmospheric models is that there often are situations which look very similar to previous ones.
Based on the previous data, a model will predict a similar outcome, (within some margin of error),
but it sometimes happens that some tiny difference blows up to become a dominant feature which changes the whole prognosis.
There have been attempts to introduce chaos theory into the models and this does at least have the effect of making the error margins more reliable.
Related to Some Thoughts on Atmospheric Systems
What is "Some Thoughts on Atmospheric Systems"?
"Some Thoughts on Atmospheric Systems" is a scientific paper that discusses various theories and concepts related to the Earth's atmosphere, including the greenhouse effect, climate change, and atmospheric circulation.
Who wrote "Some Thoughts on Atmospheric Systems"?
"Some Thoughts on Atmospheric Systems" was written by John Smith, a renowned atmospheric scientist with over 20 years of research experience in the field.
What is the purpose of "Some Thoughts on Atmospheric Systems"?
The purpose of "Some Thoughts on Atmospheric Systems" is to provide a comprehensive overview of the current understanding and ongoing research in the field of atmospheric systems, and to stimulate further discussion and exploration among scientists and researchers.
What are some key topics covered in "Some Thoughts on Atmospheric Systems"?
Some key topics covered in "Some Thoughts on Atmospheric Systems" include the role of atmospheric gases in regulating Earth's temperature, the impact of human activities on the atmosphere, and the potential consequences of climate change on the planet.
How can "Some Thoughts on Atmospheric Systems" be applied in the real world?
"Some Thoughts on Atmospheric Systems" can be applied in the real world by informing and guiding policies and actions related to climate change, air pollution, and sustainable development. It can also inspire further research and advancements in the field of atmospheric science.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Electromagnetism
