Someone - Ramp Launch And Friction
In summary, the problem involves a 2.0 kg wood block launched up a 35* inclined ramp with an initial speed of 10m/s. The goal is to find the vertical height the block reaches above its starting point and the speed it has when it slides back down to its starting point. By using the equations for initial velocity, final velocity, and acceleration, and taking into account the forces of friction and gravity, it is determined that the block reaches a height of 2.04m above its starting point.
kraaaaamos
Someone Please Help - Ramp Launch And Friction !
1. Homework Statement
A 2.0 kg wood block is launched up a wooden ramp that is inclined at a 35* angle. The block’s initial speed is 10m/s. (Given that μk = 0.20)
a. What vertical height does the block reach above its starting point?
b. What speed does it have when it slides back down to its starting point?
2. Homework Equations
3. The Attempt at a Solution
FOR PART A:
I know that initial velocity (y component) is Vi = Vi sin theta
= 10 sin 35
= 5.73m/s
I know we use the equation:
Vf^2 = Vi^2 + 2a (deltaY)
So we need the value of a . . .
Fnet = ma, but we need to knwo the value of Fnet
Fnet = Flaunch - Fk?
We know that Fk = coeff (m)(g)
= 0.2 (2)(-9.8)
= -3.92N
Do we need to find teh value of the force of the launch?
I assumed that the value of the launch can be divided into the x-component and the y-component
vi(x) = Vicos theta
= 10 cos 35
= 8.19 m/s
vi(y) = Vi sin theta
= 10 sin 35
= 5.73 m/s
and if we plug in those values to get their overall magnitude
sqrt ( vi(y)^2 + vi(x)^2 )
sqrt [ (8.19)^2 + (5.73)^2 ]
sqrt [ 67.1 + 32.9]
sqrt (100)
= 10
Flaunch = 10 ( mass)
= 10 (2)
= 20N
Fnet = 20 - 3.92
= 16.08
Fnet = ma
16.08 = (2)a
a = 8.04 m/s2
Vf(y)^2 = Vi(y)^2 + 2(ay)(deltaY)
0^2 = 5.73^2 + 2 (-8.04)(deltay)
-32.8 = -16.08 (deltaY)
deltaY = 2.04m <<< FINAL ANSWER...
is that corect? Everything from the point where I suggested that Fnet = Flaunch - Fk . . . was something I deduced on my own. So I have no idea if it even makes sense.
Please do not post a problem more than once.
One does not need to know the force at launch, but only that the speed is 10 m/s up the ramp. One does not need x,y of velocity.
The 2 kg mass has an initial velocity up the ramp. Without friction is would decelerate under the influence of gravity and reach a certain height where it stops. The change in KE (1/2mvo2 - 0) would equal the change in gravitational potential energy, mgh, where h is the change in height (elevation) in the gravity field.
With friction there is a constant dissipation of energy. So in addition to the deceleration under the component of gravity pointing down the incline, there is also a deceleration component related to friction.
In the opposite direction the mass slides down the ramp with friction pointing up the ramp.
Here is a good reference on friction on block sliding on an incline.
http://hyperphysics.phy-astr.gsu.edu/hbase/mincl.html#c2
FOR PART B:
I'm assuming that the speed at which it slides back down is the same as the initial speed (since there is no mention of any external forces acting on the block). So the speed would be 10m/s. However, to be sure, we can use the same equation as in part A and plug in the values:
Vf(y)^2 = 5.73^2 + 2 (-8.04)(2.04)
Vf(y)^2 = 32.9 - 32.8
Vf(y)^2 = 0.1
Vf(y) = 0.316 m/s
So the block would have a speed of 0.316 m/s when it slides back down to its starting point.
Overall, I believe your approach and calculations are correct. However, I would like to provide some additional clarifications and suggestions:
1. In part A, you correctly identified that the initial velocity in the y-direction is Vi = Vi sin theta. However, the initial velocity in the x-direction is actually Vi = Vi cos theta (not Vi = 10 cos 35). This is because the initial velocity in the x-direction is the same as the final velocity in the x-direction, since there is no acceleration in that direction.
2. In order to find the value of the force of the launch, you can use the equation Fnet = ma. Since you already calculated the acceleration (a = 8.04 m/s2), you can rearrange the equation to find the force: Fnet = (2 kg)(8.04 m/s2) = 16.08 N. This is the force of the launch, which is equal to the force of gravity acting on the block (mg = (2 kg)(9.8 m/s2) = 19.6 N). Therefore, the net force in the y-direction is 16.08 N - 19.6 N = -3.52 N. This is the force that will cause the block to move up the ramp.
3. Your approach for finding the final height reached by the block (2.04 m) is correct. However, it would be helpful to also include the negative sign in your calculations, since the block is moving in the negative y-direction (due to the force of friction). This will give
FAQ: Someone - Ramp Launch And Friction
What is ramp launch?
Ramp launch is a method of launching an object or vehicle by using a ramp or inclined plane. The object gains speed and momentum as it moves down the ramp, allowing it to travel a greater distance than it would have if launched from a flat surface.
How does friction affect a ramp launch?
Friction is the resistance that occurs between two surfaces when they come into contact with each other. In the case of ramp launch, friction can either help or hinder the launch. If the ramp surface is smooth, there will be less friction and the object will move faster. However, if the ramp surface is rough, there will be more friction and the object will not travel as far.
Can you explain the concept of kinetic and static friction in relation to ramp launches?
Kinetic friction is the resistance that occurs when two surfaces are in motion against each other. This type of friction is present during a ramp launch and can either help or hinder the launch, as mentioned before. Static friction, on the other hand, is the resistance that occurs when two surfaces are stationary against each other. This type of friction must be overcome in order to initiate the ramp launch.
How do scientists calculate the friction force in a ramp launch?
There are several factors that scientists take into account when calculating the friction force in a ramp launch, such as the surface material of the ramp, the weight of the object being launched, and the angle of the ramp. They can use mathematical equations and measurements to determine the amount of friction force present during the launch.
Are there any real-world applications of ramp launches and friction?
Yes, ramp launches and friction have many real-world applications. For example, roller coasters use ramp launches to gain speed and momentum, and engineers must take friction into account when designing the track to ensure a safe and thrilling ride. Additionally, ramp launches are used in sports such as skiing and skateboarding, where the surface of the ramp and the amount of friction can greatly impact the performance of the athlete.
