Something escapes the corona of a black hole
In summary, NASA has recently observed a black hole emitting a corona for the first time ever. The corona is a burst of X-rays that protrude from the black hole, and its ejection and flare mechanism are described in a technical article and JPL news release. The title of the article may have been misleading or ambiguous.
Astronomy news on Phys.org
marcus said:
Here's the technical article that describes the same event
http://arxiv.org/abs/1510.07656
Here's a JPL news item/press release that describes the corona, its ejection, and the flare mechanism in fairly basic terms:
http://www.jpl.nasa.gov/news/news.php?feature=4753
Answers my questions perfectly, thank you :)
I *thought* that's what it was, but didn't want to assume. I figured the title of the article was misleading/left ambiguous/clickbait :P
Related to Something escapes the corona of a black hole
What does it mean when something escapes the corona of a black hole?
When something escapes the corona of a black hole, it means that it has managed to move beyond the event horizon of the black hole and is no longer trapped by its intense gravitational pull.
How can something escape the corona of a black hole?
Something can escape the corona of a black hole if it has enough energy to overcome the gravitational pull of the black hole. This can happen if the object is traveling at a very high speed or if it is being pulled away by the gravity of another object.
What happens to something that escapes the corona of a black hole?
Once something escapes the corona of a black hole, it will continue to move away from the black hole and will no longer be affected by its gravitational pull. It may continue to travel through space or be pulled towards other objects with their own gravitational fields.
Can anything escape the corona of a black hole?
Yes, under certain conditions, objects can escape the corona of a black hole. However, the vast majority of objects that get close to a black hole will be pulled into its event horizon and will not be able to escape.
Is it possible for light to escape the corona of a black hole?
Yes, light can escape the corona of a black hole if it is traveling at the speed of light or faster. However, once light crosses the event horizon, it will not be able to escape and will be pulled into the black hole.
