Something wrong with Ampere's Law?
In summary, there have been recent debates and discrepancies in the application of Ampere's Law, which states that the magnetic field around a closed loop is directly proportional to the electric current passing through the loop. Some physicists have found inconsistencies in certain scenarios, leading to the proposal of modifications to the law. However, further research and experimentation are needed to fully understand and resolve any potential issues with Ampere's Law.
greswd
764
We use ∇ x B = μ0 J
Imagine a thin metal wire. We measure the curl at some distance from the wire and from the Biot-Savart law we know that it is not zero.
However, as this point is at some distance from the wire, the current density at that point is definitely zero.
I'm confused as to why this is the case.
The J is not the current density at the point P where the curl is measured, but the current flowing through the area enclosed by the flow line obtained by following the magnetic field around from P until it gets back to P.
So from this area and the total current flowing through it, how do we put it in vector form? because J is a vector.
Good point. I was thinking of the integral form of Ampere's Law. I don't think what I wrote makes sense in the differential form, which is what you're looking at.
Taking a step back, what version of the Biot-Savart Law are you using? From my understanding, the Biot-Savart gives a formula for B, which would be expected to be nonzero at a finite distance from an infinitely long, infinitely thin wire carrying a steady DC current. But it says nothing about the curl of B.
From the B-S law, we can construct the B vector field around an infinitely long wire. Then apply the curl differentials.
I just did a quick check, and the curl of the mag field is indeed zero outside the wire, which matches the current density. M. Ampere will be relieved.
oh, something wrong with my calculations then. have you ever seen a derivation of the differential form of Ampere's Law by directly using the Biot Savart Law?
Alas, my text just present's Ampere's Law as a fait accompli. Looking at the chronology, I suspect that Ampere's Law was discovered after the Biot-Savart and hence may have been derived from it. My text starts with the integral form of Ampere's Law and then derives the differential form using Stokes' Theorem.
idk if I'm right, but it appears to me that (via Stokes theorem), if the differential form is true then the integral form is definitely true, but if the integral form is true, it doesn't mean that the differential form is true.
greswd said:
We use ∇ x B = μ0 J
We measure B, not curl B, at some distance of the wire.
Curl of a vector field is defined at a certain point as the limit of the line integral along a closed curve surrounding that point, divided by the area enclosed by the curve, when the area goes to zero. http://mathworld.wolfram.com/Curl.html
If the line integral of B happens to be equal to μ0 times the enclosed current, it does not necessarily mean that the limit (curl) exist at the point in question.
If you determine curl B outside the wire you get zero.
FAQ: Something wrong with Ampere's Law?
What is Ampere's Law?
Ampere's Law is a fundamental law of electromagnetism that relates the magnetic field around a closed loop to the electric current passing through that loop. It is named after the French physicist André-Marie Ampère.
What is the significance of Ampere's Law in physics?
Ampere's Law is significant because it helps us understand the relationship between electricity and magnetism. It is one of the four Maxwell's equations that describe the behavior of electric and magnetic fields, and it is crucial in the study of electromagnetism and its applications in technology.
Can Ampere's Law be derived from other laws of electromagnetism?
Yes, Ampere's Law can be derived from other laws of electromagnetism, specifically from the Biot-Savart Law and the Lorentz Force Law. It can also be derived from Maxwell's equations in integral form.
What is the difference between Ampere's Law and Gauss's Law for magnetism?
Ampere's Law relates the magnetic field to the electric current, while Gauss's Law for magnetism relates the magnetic field to the magnetic charge. In other words, Ampere's Law deals with the behavior of magnetic fields around electric currents, while Gauss's Law for magnetism deals with the behavior of magnetic fields around magnetic charges.
Are there any limitations or exceptions to Ampere's Law?
Yes, there are some limitations and exceptions to Ampere's Law. It only applies to steady currents and does not take into account the effects of changing electric fields. It also does not hold true in certain cases, such as when dealing with superconductors or in the presence of time-varying magnetic fields.
