SONET protocol for data transmission over fiber optics
In summary: ASA (Asynchronous Transfer Mode) is a TDM method that is used in the SONET standard. It is a bit like time-division multiplexing, but with an asynchronous serial stream instead of a serial stream.The 810 bytes are the payload for an STS-1 frame.
fog37
1,568
108
hello forum,
I have read about SONET which seems to be a physical layer protocol to transport data over fiber optics.
SONET is a TDM (time division multiplexing method). TDM means that that time divided into slots and shared between different users. For example, given three users A, B and C, the transmission would be ABCABCABC...
That said, I would think SONET works the same way. The SONET frame is 810 bytes. I am sure those bytes contain extra information (header, etc.) besides the actual data. Do those 810 bytes contain data from multiple different sources or from the same source? For instance, I imagine different laser sources (each with its own wavelength) being WDM together but each individual wavelength carries SONET frames which carry each TDM type traffic...
It is said that the frame is composed of 9 rows of 90 columns of 8-bit bytes. I am not sure how to interpret ths row/columns structure. It is easier to see the 810 bytes arranged sequentially. I think that is how they are physically transmitted...
thanks,
fog37
The bytes are pretty disordered. "The protocol is a heavily multiplexed structure, with the header interleaved between the data in a complex way."
You will have to look for a standard to see, for example, how a DS3 payload is formatted into an STS-1 payload.
three STS-1 frames can be interleaved to form an STS-3 frame.
Receiving SONET frames and reconstructing the underlying payloads is always confusing.
May I mention that in SONET and the European equivalent, which is SDH (Synchronous Digital Hierarchy), the underlying concept is that different users data are interleaved in words, not in bits. This means that it is easy to extract (or drop off) one user from a large pay load, without the need for a multiplexer mountain.
Another feature of the system, which is in contrast to Ethernet, is that it talks to every repeater and node, so that a physical fault on the network can be geographically located. In the case of Ethernet, physical locations are not reported and an automatic re-routing might be occurring as a result of a fault which is not apparent to the network operator. For this reason, large Ethernet payloads are often carried on Sonnet/SDH bearers.
Thanks tech99.
what is a word? I am familiar with packet, frame, datagram...
fog37 said:
Thanks tech99.
My apologies, I should have said byte interleaved for SDH and Sonet.
Actually, in telecom speak, it is called octets.
Related to SONET protocol for data transmission over fiber optics
1. What is SONET protocol?
SONET (Synchronous Optical Network) is a standardized digital communication protocol used for transmitting large amounts of data over fiber optic networks. It provides a way to multiplex multiple data streams into a single, high-speed connection.
2. How does SONET work?
SONET uses a synchronous time-division multiplexing (TDM) technique, where data from different sources is divided into frames and transmitted over the fiber optic network. It also uses a hierarchical structure to organize the data streams, with higher-order signals containing multiple lower-order signals.
3. What are the benefits of using SONET protocol?
SONET offers a number of benefits, including high-speed data transmission, flexibility in network design, and the ability to support multiple services such as voice, video, and data. It also has built-in fault detection and restoration capabilities, making it a reliable choice for data transmission.
4. What is the difference between SONET and SDH?
SONET and SDH (Synchronous Digital Hierarchy) are very similar protocols, with the main difference being the type of electrical signals used. SONET uses electrical signals, while SDH uses optical signals. Both protocols are compatible and can be used in the same network.
5. How is SONET used in modern networks?
While SONET was originally developed for use in long-distance telecommunications networks, it is still widely used in modern networks for data transmission over fiber optics. It has been adapted for use in local area networks (LANs) and wide area networks (WANs) and is commonly used in high-speed internet connections, video conferencing, and cloud computing.
  • General Engineering
15K
  • Beyond the Standard Models
