Sound and Heat - Whats the difference
In summary, Sound is produced when metal atoms vibrate about their mean positions. Heat is produced when the metal absorbs thermal energy from an external source.
RohansK
37
Sound and Heat -- Whats the difference
When we hear sound from a metal object ( like a tuning fork or a huge bell with gong) when they are striked by an external means we say that the atoms of the metal vibrate about their mean positions and so set the air around them also in compressive mode. This creates compressions and rarefactions in the air producing sound waves.
Fine, this theory does make sense and we do hear sound due to the vibrations in the metal.( a bell, a tuning fork or any string instrument like guitar is a perfect example of this).
BUT,
Isnt it true that the atoms similarly vibrate around their mean positions when the metal is subjected to an external heat source. When we say that we supply heat to a metal the atoms absorb the heat energy and start to vibrate around their mean positions. And the amplitude and freqeuncy of the vibration are the indication of its thermal energy and tempreature.
The point is that in both the cases ( that of heating and striking the metal with some external means to produce sound) both involve the same action ie the vibrations of atoms around their mean positions.
1. Then what is the exact difference between these vibrations that we hear sound in one case and feel the heat in the other when in both cases the atoms do the same thing ie they vibrate.
2. So why don't we hear sound from a iron bar which is being heated to red hot but still we don't hear any sound from it, though the atoms are vigorously vibrating.
3. Similarly why don't we feel heat when we strike a tuning fork but hear sound alone, again the atoms only being vibrating.
What is the differnce in the vibrations that differentiates between the production of Sound and heat despite the basic behaviour of the atoms being the same in both cases.
What produces sound and what produces heat.
Science news on Phys.org
Hi Rohan. Because thermal vibrations are random with the atoms all more or less "doing there own thing" the amplitude is very small (approx 10^-11 m) and the frequency very large (10^12 Hz is a typical figure at room temperature though obviously it depends on the atomic mass).
The bottom line is that human hearing extends to about 10^4 Hz so there is no chance of "hearing" 10^12 Hz.
uart said:
Hi Rohan. Because thermal vibrations are random with the atoms are all more or less "doing there own thing" the amplitude is very small (approx 10^-11 m) and the frequency very large (10^12 Hz is a typical figure at room temperature though obviously it depends on the atomic mass).
Does this imply that if we built a detector capable of 'hearing' 10^12 Hz it would detect hot objects? So there is another way of detecting something's heat other than detecting the IR photons it emits?
Anyway thanks to the OP, this question was actually pretty interesting, PF is awesome :)
Thanks Uart. Your answer is convincing as far as the frequency range audible to humans and the requency of the heated metal atoms is concerned.
But then what exactly is the reason that influences the difference in the amplitude and the frequency of the vibrations of atoms in both the cases. Ie what is the reason that make the amplituude go high and frequency low in the case of creating sound.
And what makes the frequency high and amplitude low in case of heating the metal.
What is the physical reason or fundamental that brings about this change in each case.
And also there is an interesting incidence where there is heat produced as well as sound created when there is a plastic collision ( impact) between two bodies. This can be the typical example of conservation of momentum problem where tthe two bodies moving collide with each other and the impact is inelastic ie the second body plastically deforms the first one on impact and they both stick together as one unit and move forward.
Here the plastic defromation produces a sound ( when they collide hard) and also heat is given out at deformation.
Then how does sound and heat both are produced at the same time and why. Can somebody explain how these both things occur the same time and Also what would be the condition of the vibrating atoms regarding frequency and amplitude of the atoms .
How do both low and high frequency ( for sound and heat ) are produced at the same time and how does the energy of impact distribute itself to produce both types of frequencies.
Another example would be when a heavy object falls on ground from a height and we hear a sound (dh..a a..pp) and also experience some heat at the spot of impact.
How does this occur.
RohansK said:
Thanks Uart. Your answer is convincing as far as the frequency range audible to humans and the frequency of the heated metal atoms is concerned.
But then what exactly is the reason that influences the difference in the amplitude and the frequency of the vibrations of atoms in both the cases. Ie what is the reason that make the amplitude go high and frequency low in the case of creating sound.
When you hit something to make sound (like a spoon hitting a tin-can or whatever) then you're setting a huge bunch of molecules moving all in the same direction, that's the big difference.
As for alexgmcm's previous question about detecting 10^12 Hz sound, firstly it doesn't transmit though air in quite the same way as a regular sound wave would. The vibrating atoms in the hot metal will impart random motion to the adjacent air molecules (which is really just regular conduction heating) and then we would need to "hear" that molecular velocity.
Because this molecular velocity is so random and the molecule mass so small compared with macroscopic things (like a microphone diaphragm or the cochlea in our ears for example) you get very little net motion imparted to these macroscopic scale things. There are air molecules striking all the time - very randomly from all different directions - so overall their contribution to large scale motion is extremely small.
It's interesting however that these molecular level vibrations do really manifest themselves on an (almost) macroscopic level in Brownian motion. Brownian motion is where extremely small particles (like very small grains of pollen or dust) get imparted with random thermal motion when suspended in an otherwise completely "still" fluid. It's caused by that fact that statistically the random motions of all the colliding molecules don't quite cancel completely - and the smaller the object the more pronounced will be the net "macroscopic" imbalance.
(I'm no expert on hearing so the following is speculative) but I suppose that if some of the hair-cells in our Cochlea were small and fine enough to undergo significant Brownian motion then we really would be about to "hear" temperature. I'd guess it would just sound like a background noise that increased with increasing air temperature. I think it's even possible that this process already does actually occur within our ears but at a level below the threshold of human hearing. This would be a good thing too, as it would be a hell of a nuisance if we really could hear temperature as noise.
The natural frequency of a solid, such as a tuning fork, is determined by the inertia of the atoms and the the bonds between them, not by the source of the disturbance. The disturbance determines the initial time and therefore the phase of the vibration. Therefore the sound of the tuning fork depends on the entire lattice having been hit at a particular time and in a particular direction by the hammer, causing it to vibrate as a whole body. However, heat involves many small collisions at random times and in random directions. After the superposition of the one big concerted disturbance and the many small random disturbances, it's only the orderly mode of vibration that will be able to produce the orderly compression waves in the surrounding air, which we hear. In addition to sound waves, the eardrum is also tapped lightly at random times due to thermal energy, but the sense of hearing isn't activated by that. Instead, the sense of touch responds to thermal energy, e.g. the air feels hot.
if large vibrations caused by heat can melt and boil objects
can large sound vibrations do the same
also, if heat and sound are both vibrations,
how can heat pass through a vacuum but sound cant
Heat can be transferred in more ways than just conduction. In space it us transferred via radiation.
so heat is not just a vibration?
This is a very interesting thread. Does kinetic heat always travel in waves? I always just assumed that particles vibrated randomly on their own, transferring momentum to other particles that came in contact with them? If kinetic heat indeed always is organized into wave transfers, what is the maximum frequency such a wave can have and still be heat? Does a perfectly sound-absorbent material convert the sound into heat upon absorption then?
i just remembered something i read about quantum theory
it said that everything is both a wave and a particle
this works for light so i assume it must have something to do with
heat being a vibration (wave) and a particle (radiation from the sun)
also i read something about developing a sound laser
which might have something to do with this :)
Heat will face the same limitations as sound in a vacuum - no matter no conductance.
Great thread.
Related to Sound and Heat - Whats the difference
1. What is the difference between sound and heat?
Sound is a form of energy that is produced by vibrating objects and travels through matter as waves. Heat, on the other hand, is the transfer of thermal energy from one object to another. While both involve energy and can be measured in units of temperature, they are fundamentally different forms of energy.
2. How is sound different from heat in terms of their propagation?
Sound requires a medium, such as air, water, or solids, to travel through. It cannot travel through a vacuum. Heat, on the other hand, can travel through a vacuum via radiation. It can also be transferred through conduction, where heat moves through a solid object, or convection, where heat is transferred through a liquid or gas.
3. Is sound a form of heat?
No, sound is not a form of heat. While sound waves can cause an increase in temperature due to friction, it is not considered a form of heat. Sound waves can also be absorbed or reflected, whereas heat is always transferred from a hotter object to a cooler one.
4. How do sound and heat interact with each other?
Sound and heat can interact with each other in various ways. For example, sound waves can create changes in temperature due to friction, as mentioned earlier. Heat can also affect the speed of sound, as it causes changes in air density. This is why sound travels faster in warmer air compared to colder air.
5. Can sound be converted into heat?
Yes, sound can be converted into heat through friction. When sound waves travel through a medium, they cause particles to vibrate, which in turn creates heat due to friction. This is why objects can feel warm after being exposed to loud sound waves for a prolonged period of time.
  • Thermodynamics
10K
  • Thermodynamics
  • Thermodynamics
  • Classical Physics
  • Mechanics
