Sound and supersonic motion - a question from Feynman's lectures
In summary, in chapter 51 of volume 1 of Feynman's lectures, he discusses the relationship between sound and supersonic motion. He explains that any object moving faster than the speed of sound will generate sound waves on each side, while objects moving slower than the speed of sound only create disturbances in the medium. Feynman mentions the presence of shock waves in supersonic motion, but does not provide a justification for this claim.
dEdt
288
Sound and supersonic motion -- a question from Feynman's lectures
In chapter 51, volume 1 of the FLP, Feynman writes
Incidentally,...it turns out, very interestingly, that once [an] object is moving faster than the speed of sound, it will make sound...Any object moving through a medium faster than the speed at which the medium carries waves will generate waves on each side, automatically, just from the motion itself.
Unfortunately he didn't give a justification for this claim. I was hoping someone in Physics Forums could fill this gap in.
I don't like it at all. Sound is just disturbances in the medium and a moving object most certainly disturbs the medium at subsonic speed.
Presumably he had in mind sound waves. (This is clear from the context the quote appears in). Subsonic objects definitely disturb the air around them but they don't create sound waves like supersonic objects.
Sound waves ARE disturbances in the air. The sonic boom shock wave is just the piling-up of all the disturbances on top of each other.
He is alluding to the presence of shock waves, which are essentially a form of sound waves that result simply from an object moving through a gas at supersonic speeds.
Yes, but he seems to be implying that objects moving at subsonic speed don't also "generate waves on each side".
Ok so the only difference between subsonic and supersonic motion is that the small air disturbances created by the motion reinforce each other to form a shock wave in supersonic flight, but don't in subsonic flight?
Related to Sound and supersonic motion - a question from Feynman's lectures
1. What is supersonic motion?
Supersonic motion is when an object or fluid moves at a speed greater than the speed of sound. This typically occurs at speeds above Mach 1, which is approximately 343 meters per second in dry air at room temperature.
2. How does sound travel through different mediums?
Sound travels through different mediums by causing molecules to vibrate and create waves that propagate through the medium. The speed of sound varies depending on the density and elasticity of the medium. For example, sound travels faster in solids than in liquids or gases.
3. What is the difference between supersonic and subsonic speeds?
The main difference between supersonic and subsonic speeds is the speed at which the object is traveling. Subsonic speeds refer to speeds below the speed of sound, while supersonic speeds refer to speeds above the speed of sound. Additionally, the behavior of air around the object changes at these speeds, with shockwaves and other supersonic effects occurring at supersonic speeds.
4. How does supersonic motion affect sound?
Supersonic motion can have a significant impact on sound. As an object moves through the air at supersonic speeds, it creates shockwaves that can cause loud sonic booms. These shockwaves also distort and compress sound waves, making it difficult to hear or understand sound coming from the object.
5. What are some real-world applications of supersonic motion?
Supersonic motion has many practical uses, such as in the aerospace industry for supersonic travel and military aircraft. It is also used in high-speed trains, wind tunnels, and other engineering applications. Additionally, studying supersonic motion can help scientists better understand the behavior of fluids and sound waves, leading to advancements in various industries.
  • Science and Math Textbooks
