Sound card sampling rate 1.2msps?
In summary: Yes, those are standard terms in digital signal processing.Can you elaborate on ksps and msps? Is it some standard unit I am missing? sps for samples? Most sound cards I know use kHz as a unit.Msps would be megasamples per second. ksps is 1,000,000 samples per second.You might be able to interlace the two channels on the sound card to record one channel at twice the rate. You would need to interlace the sampling, and I do not know how to program that.An alternative would be to use a low-cost Software Defined Radio as the front end.
Fred Wright
375
226
TL;DR Summary
Is it possible to sample sound at 1.2msps?
I am designing an experiment for pam-ook which acquires a radio audio signal to the mic input of my laptop. I process the signal using c++ code employing an audio library (PortAudio) which provides the data stream. I require a sampling rate of 1.2msps but the sound card in my laptop has a maximum sampling rate of about 240ksps. Is there a way to increase its sampling rate to 1.2msps? I have searched online for peripheral sound cards but none meet my requirement.
Can it be done? Certainly. Can it be done in software with hardware that doesn't support it? Certainly not.
Since this is two orders of magnitude above human hearing, you will need specialized equipment.
Sampling rates of sound cards are in general designed to meet what our ears are capable of hearing (plus some more for better editing/quality), so if you need faster sampling you will probably need a specialized AD converter.
ksps = kilo samples per second. Yes, those are standard terms in digital signal processing.
Likes Borek and jim mcnamara
Thank you for your response. msps means mega samples per second and ksps means kilo samples per second. I was hoping to avoid using a specialized ADC but I think the only solution to the problem is to integrate an ADC with a DSP and build a prototype board which is beyond my budgetary constraints.
Fred Wright said:
Summary: Is it possible to sample sound at 1.2msps?
Virtually impossible. You'd need to redesign the hardware and probably the firmware too.
What is the datarate of your OOK and PAM (4-PAM?) signals? What is your RF carrier frequency for this transmission? What does your current RF receive circuit look like? How many bits of resolution do you need for your processing of the baseband signals? How deep does your memory need to be (how many samples do you want in order to process the RX signal)?
Are you just wanting to use your laptop sound card because it is a handy A/D circuit? Obviously its sample rate is too low for what you want, so have you looked at Arduino or other microcontroller (uC) based solutions?
Likes jim mcnamara
msps would be millisamples per second.
An SDR would be able to handle the conversion rate and the radio frequency input.
What is the frequency of your signal ?
Likes hutchphd
Are you sure that is needed?
That "specialized" ADC is the heart of this design. I doubt that you can avoid it. OTOH, a high performance uController, like BeagleBone isn't expensive and could be integrated with a good ADC. It wouldn't be an easy project. It would require a lot of SW and some hardware expertise, but it wouldn't have to be very expensive.
PS: I'd bet you can buy the whole thing on silicon from someone like analog.com or TI.com, although I'm too lazy to look for it.
Maybe spend some time on google researching "software defined radios"? That was my initial impression of your problem. Maybe you can buy the hardware and reconfigure it? The HAM radio world is a big place; lots of tinkerers there. They may be able to help you better than us.
I found an ADC that would do the trick but requires 70mHz clk. I will look into BeagleBone (Arduino is too slow). Thanks for the tip.
Pico Scopes can do what you want. You will have to use their API rather than the audio API.
I have never used them myself.
BoB
Likes DaveE
Fred Wright said:
70mHz
Please, you were already told m is not M.
Likes Vanadium 50 and berkeman
No doubt I being simplistic here, but it looks as if the mic input is expecting an analogue audio signal?
Yes indeed the mic input expects an analog signal. The system I designed uses c++ audio libraries to retrieve the A/D digitization from the laptop sound card. The scheme is to use a beat frequency oscillator on the rf receiver with a high audio frequency and sample and process the ask-oop data stream running at 1200 baud. Unfortunately, my sound card will only support 240 baud. The solution I see is to use a high sample rate ADC coupled to a digital host and stream the data over a USB port. I would have to write circular buffers for the data stream as well as a lot of other work which was avoided by using the audio libraries.
The Texas Instruments AFE5807 is an 8-channel 12 bit ADC analog front end that does 80 Msps. They are about $50 each, or $300 for an evaluation board. Commercial use is ultrasound.
So why do you need MHz sampling rates?
To achieve accuracy in the processing algorithm.
Thanks, I'll look into that.
What is the datarate of your OOK and PAM (4-PAM?) signals? What is your RF carrier frequency for this transmission? What does your current RF receive circuit look like? How many bits of resolution do you need for your processing of the baseband signals? How deep does your memory need to be (how many samples do you want in order to process the RX signal)?Are you just wanting to use your laptop sound card because it is a handy A/D circuit? Obviously its sample rate is too low for what you want, so have you looked at Arduino or other microcontroller (uC) based solutions?
@Fred Wright --Why are you being so evasive in your replies and why have you not answered my on-topic questions? Please reply in detail to each of my questions, or your thread will be closed. This is very frustrating; we want to help you, but if you refuse to specify your system requirements and make us guess, that is bad and wastes our time.
I apologize for wasting your time. I didn't think I was being evasive. I posted the data rate and didn't think the frequency of the rf carried was relevant to my problem. I received some good advice so I humbly advise that you close the thread so that others don't waste their time on my nonsense.
I have no idea what you are saying. I will close this thread now to avoid wasting other users' valuable time and take this to PMs tomorow.
Okay. If you want to discuss your design more, feel free to PM me so I can try to help out.
FAQ: Sound card sampling rate 1.2msps?
What is the significance of a sound card's sampling rate?
The sampling rate of a sound card refers to the number of times per second that the sound card takes a snapshot of the audio signal. It is important because it determines the quality and accuracy of the recorded sound. A higher sampling rate means more data points are captured, resulting in a more detailed and accurate representation of the original sound.
What does 1.2msps mean in terms of sampling rate?
1.2msps stands for 1.2 million samples per second, which is the sampling rate of the sound card. This means that the sound card is capable of taking 1.2 million snapshots of the audio signal every second.
Is a higher sampling rate always better?
Not necessarily. While a higher sampling rate can result in better quality audio, it also requires more storage space and processing power. Additionally, the human ear can only perceive a certain range of frequencies, so a sampling rate beyond a certain point may not make a noticeable difference in sound quality.
Can the sampling rate be adjusted on a sound card?
Yes, most sound cards allow for the sampling rate to be adjusted. However, the maximum sampling rate is limited by the hardware capabilities of the sound card.
How does the sampling rate affect the file size of a recorded audio?
The sampling rate directly affects the file size of a recorded audio. A higher sampling rate means more data points are captured, resulting in a larger file size. For example, a 1-minute audio recording at a sampling rate of 1.2msps will have a larger file size than the same recording at a sampling rate of 600ksps.
