Sound diminishes from x to y over what distance?
  • Thread starter Thread starter gmmstr827
    Sound
At a rock concert, a dB meter measured 130 dB at a distance of 2.2 meters from the speaker, leading to a calculated power output of 10 W/m². To determine the distance for a sound level of 85 dB, the intensity ratio was analyzed, revealing that the distance would be approximately 391.22 meters. The calculations involved using the intensity formulas and the relationship between sound intensity and distance, factoring in the dB difference. The discussion highlighted the importance of understanding how decibel levels relate to sound intensity and distance. Ultimately, the solution demonstrated that sound diminishes significantly over distance, requiring careful calculations to find reasonable values.
gmmstr827
At a rock concert, a dB meter registered 130 dB when placed 2.2 m in front of a loudspeaker on the stage. (a) What was the power output of the speaker, assuming uniform spherical spreading of the sound and neglecting absorption in the air? (b) How far away would the sound level be a somewhat reasonable 85 dB?
I = 10^(ß/10)*I_0 where I_0 = 1*10^-12 W/m^2
I_1 = I_2/(4πr^2)
a)
I = 10^(ß/10)*I_0
I = 10^(130 dB/10)*10^-12
I_2 = 10 W/m^2
b)
Convert dB to W/m^2:
I = 10^(ß/10)*I_0
I = 10^(85 dB/10)*10^-12
I_1 = 3.16 * 10^-4 W/m^2
Solve for r in formula: I_1 = I_2/(4πr^2) >>> r = √(I_2/(4πI_1))
r = √(10 W/m^2/(4π(3.16 * 10^-4 W/m^2))
r = 501824 m
Part b) is obviously way too large to be right. I need a formula that incorporates the original distance. Any ideas?
I_1 = I_2/(4πr^2)
a)
I = 10^(ß/10)*I_0
I_2 = 10 W/m^2
b)
I = 10^(ß/10)*I_0
r = 501824 m
An easier way to approach part (b) is to look at the difference in dB, and convert that into the ratio of the intensities. Since the intensity varys by 1/r^2, having the ratio of the intensities will give you the ratio of the r^2, and that let's you find the 2nd r value.
Give that a try, and show us your work...
130 dB - 85 dB = 45 dB
I = 10^(45/10)*10^-12 W/m^2
I = 3.16*10^-8 W/m^2
So (3.16*10^-8 W/m^2) / (10 W/m^2) = 3.16*10^-9
and (2.2 m) / (x m) = 3.16*10^-9 m
x = 6.96 * 10^8 m
which is even larger than the answer I got before >.<
Are you saying I'm actually going to use the formula I_1 = I_2/(4πr^2) here? Or 1/r^2 (which would still give an outrageous value if I plug the answer into that)?
After a quick search I found the following equation:
I_{2} = I_{1}\frac{r_{1}^{2}}{r_{2}^{2}}
See if that works?
x = 6.96 * 10^8 m
Don't worry about plugging in the power numbers. They just ask you how much farther away you need to go to be 45dB quieter.
-45dB = 10 log (I2/I1)
What is the ratio of I2 to I1?
What does that imply for the ratio of the distances from the source speaker?
See if that works?
3.16*10^-8 W/m^2 = 10 W/m^2 ((2.2 m)^2 / r^2)
r = 39136.2 m
Hm, better, but still a huge distance =/
(3.16*10^-8 W/m^2) / (10 W/m^2) = 3.16*10^-9, or, ignoring the power numbers, 10 times the distance? So it would be 22 meters?
See if that works?
Use the second equation to find the ratio of the Intensities (sound powers). Then use the first equation to find the ratio of the distances. That gives you the second distance...
Perhaps you mean I'm not supposed to plug in anything for I_1 and I_2? That's the only way it would make sense I suppose. Solving for that gets me a ratio of I_2 / I_1 of sqrt(10)/100000.
If I plug that into I_2 / I_1 = r_1^2 / r_2^2 with r_1 = 2.2 m, I get a distance of about 391.221 m, which looks reasonable.
So the answer is about 391.22 meters? The part I didn't understand was that I wasn't supposed to substitute anything in for I_2 / I_1 in your second equation, which wouldn't have given any variable to solve for. Thank you!
You got it. The nice thing about dB is that you can represent very large ratios with them, and still have manageable numbers.
If they had asked for the distance where the intensity was 40dB down, that is 10^4 = 10,000 times less. Square root of that is 100, so you would have been 100 times farther away than 2.2m. Since this problem listed 45dB down, the distance was a bit further than 100 times farther away.
19K
