Sound Intensity doubles if number of noise sources double?
In summary, when the number of noise sources doubles, the sound intensity increases, but it does not simply double due to the logarithmic nature of sound intensity measurement in decibels. Instead, the increase in intensity is approximately 3 dB when two identical sound sources are combined, which is a perceptible but not a doubling effect in terms of loudness.
Kashmir
468
74
Hello All.
I looked at a question "A noisy machine in a factory produces sound with a level of 80 dB. How many identical machines could you add to the factory without exceeding the 90-dB limit?"
The solution in link below assumes the intensity will increase n fold if I add n machines.
Why is it true that an n fold increase in number means n fold increase in intensity?
Isn't intensity proportional to Amplitude square, so if two machines are perfectly in phase the intensity will quadruple and not double ?
https://homework.study.com/explanat...actory-without-exceeding-the-90-db-limit.html
How could two noisy machines in a factory be perfectly in phase? You're overthinking this.
For the sound of the machines to add in amplitude will require them to be in-phase. Even if the machines rotate together, they are still located in different positions, so that the distance from the observer to each machine will be different. This means that the sound from the machines will add with random phase. In such a case the intensity, or power flux density, is added rather than the amplitude.
The increase in intensity expressed in decibels will then be 10 log N, where N is the number of machines. Had the machines rotated together (in synchronism) and been equally spaced from the observer, the amplitudes would have added and the increase in intensity (power flux density) would be N squared, or equal in decibels to 20 log N.
Likes Kashmir
Kashmir said:
Hello All.
Just a couple of practical considerations:
The relative locations of the machines and the subject or instrument perceiving the sound should be relevant for such question.
In a factory, the production flow and manipulation of materials, forces machines to be far apart.
Also walls, exposed ceiling insulation, partitions, and the space ocupied by each machine, tend to produce shielding or reflecting effects on the sound propagation.
Thank you 😊.
But lets say they are in perfect phase doesnt the intensity being N squared violate energy conservation?
If individual intensity is ##I## then they'll be quadrupled ##4I## that means we are getting 4 times the energy produced by each source individually?
No. It's the same amount of energy, just distributed differently: less goes into energy wasted heating the air through which the sound travels and more is delivered directly directly to the human eardrums and other surfaces on which the sound waves impinge.
Kashmir said:
Thank you 😊.
You're considering something like maximum energy density, not total energy.
Could you please explain this further if possible? Thank you
FAQ: Sound Intensity doubles if number of noise sources double?
1. What is sound intensity?
Sound intensity is defined as the power per unit area carried by a sound wave. It is typically measured in watts per square meter (W/m²) and represents how much sound energy passes through a certain area in a given time.
2. How does sound intensity relate to the number of noise sources?
When the number of noise sources doubles, the total sound intensity increases. This is because each source contributes to the overall sound energy in a given area. If all sources emit sound at the same intensity, the combined effect results in a doubling of the sound intensity.
3. Does doubling the number of sources always result in double the sound intensity?
Yes, under ideal conditions where all sources are identical and emit sound uniformly, doubling the number of sources will lead to a doubling of sound intensity. However, in real-world scenarios, factors such as distance, interference, and environmental conditions can affect this relationship.
4. How is sound intensity measured?
Sound intensity is typically measured using a sound level meter, which can quantify the sound pressure level (SPL) in decibels (dB). The intensity can be calculated from the sound pressure using the formula: intensity (I) = (pressure²)/(density × speed of sound).
5. What are the implications of increased sound intensity in environments?
Increased sound intensity can lead to higher noise levels, which may have various implications, including potential hearing damage, increased stress levels, and disturbances in wildlife. Understanding sound intensity is crucial for noise control and public health considerations.
