Sound waves distorted in certain speaker enclosures?
In summary: So it would be difficult to generalize about what is better or worse in this category. However, I would say that it is harder to find better studio monitors now than it was a few years ago.
jc01
my theory may be sloppy and wrong - but here it goes
when people start talking about speakers and their enclosures there are generally two types used, ported and sealed. sealed being just that, and airtight box with a speaker in it. but a ported box is far from air tight instead they put a hole in a box so that when the speaker travels out it can suck air in and when the speaker travels in it pushes air out( http://mobile.jlaudio.com/graphics/ENC/W6v2HOWedge_Tech.jpg?0.418361100534004"for a pic of a ported box).
now here is my question. if the speaker pushes out a compression, then technically wouldn't a a rarfacation be pulled in at the same time, causing there to be canceling/distorting of a wave (at least in theory)? but i know for a fact it is no cancled these boxes are know to be louder, why?
Louder but less accurate unless sufficient electronic feedback is used to compensate for the lack of dampening factor. This can be done in the speaker's electronics, or in the amplifier. The amplifiers that do this are expensive though.
With a typical ported system, in the base range the effect is to "muddy" up the sound. A crisp thwack, becomes a lengthened whoooom. The worst sound is high level base from a car or van, because the vehicle's body will resonate with the lower frequencies.
Most home theatre speakers use ports for the base and sub-woofers, and are underdamped, since for movies rumble is rumble and doesn't need to be musically accurate. It is still possible to find more musically oriented speakers, but the price is higher now because this has become a niche market. Some of these are still ported, but use electronic dampening (or rely on special amplifier setups) to prevent overshoot. Finding good acoustic suspension speakers is really tough these days.
The most accurate speakers are true studio monitors, but the high powered ones are expensive. These are classified in terms of volume, from lowest to highest, they are called near field, middle field, far field. Also a lot of speakers claim to be studio monitors, but few truly are of studio monitor quality.
Good commercial disco speakers are acoustic suspension, less efficient, but they're intended to be used with high powered amplifiers, sometimes 1400 watts or more per speaker at 8 ohms impedance or higher (18 inch woofers eat up a log of power). The sound is loud is enough that placement is tricky. Often these are suspended by chains from the roof in order to reduce resonating the floor or walls. They also use well padded enclosures. These are also next impossible to find. Cerwin Vega makes low quality home speakers, but their high end commercial disco speakers are very good (assuming they still make them).
Personally I have a pair of Energy Veritas 2.8 speakers, which handle 400 to 500 watts per channel, impedance is about 4 ohms each. These are ported and many consider them good enough to use as reference monitors. However the base on my old acoustic suspension Saras, rated at 200 watts per channel, with impedance of 6.5 ohms, have a slightly tighter base.
You nead a relativly "dead" room to keep from resonating the walls and floors when there is loud base. Also you don't want a lot of sound reflecting off of hard surfaces. I nixed my wifes idea of having a wooden floor in our family room for this reason.
Below is a to the standard line of Cerwin Vega pro speakers. The disco speakers are combinations of these and/or custom made. The Vision series is a good example. They include a truss (suspended) setup in one of the pictures (in the discos I've seen chains were typical). The 3 way system and the 18 inch sub woofer pair recommend power of 1400 watts at 8 ohms, with peak power handling at 2800 watts.
http://www.cerwinvega.com/products/newpro/index.html
I'm not that familiar with which true studio monitors are really good, other than last time I checked these were running around $5,000 (US) or higher per speaker.
FAQ: Sound waves distorted in certain speaker enclosures?
1. What causes sound waves to become distorted in certain speaker enclosures?
There are several factors that can contribute to sound distortion in speaker enclosures. One of the main causes is inadequate size or design of the enclosure, which can result in sound waves bouncing around inside and causing interference. Other factors include poor quality speaker components, incorrect placement of speakers, and impedance mismatch between the speakers and the amplifier.
2. How can I prevent sound distortion in my speaker enclosure?
To prevent sound distortion, it is important to choose the right size and design for your speaker enclosure. It is also crucial to use high-quality speaker components and ensure proper placement and wiring of the speakers. Additionally, using an amplifier with the correct impedance for your speakers can help prevent distortion.
3. Can sound distortion in speaker enclosures damage my speakers?
Yes, sound distortion can potentially damage your speakers if it occurs frequently or at high volumes. This is because the internal components of the speaker can become strained and overworked, leading to potential damage or even failure. It is important to address any sound distortion issues as soon as possible to avoid damaging your speakers.
4. Why do some speaker enclosures produce more sound distortion than others?
The amount of sound distortion produced by a speaker enclosure can vary based on its design, size, and components. Generally, smaller and poorly designed enclosures are more likely to cause sound distortion due to limited space for sound waves to propagate and potential interference from internal components. Additionally, lower quality speaker components can also contribute to more sound distortion.
5. Can sound distortion in speaker enclosures affect the sound quality?
Yes, sound distortion can significantly impact the sound quality of your speakers. It can cause the sound to become muffled, harsh, or distorted, making it difficult to listen to music or other audio. Sound distortion can also affect the accuracy and clarity of the sound, which can be particularly problematic for professional audio applications.
