Sound waves question - vibrations and amplitudes
In summary, a tuning fork vibrates 235 times in 3.1 seconds with an amplitude of 0.59mm. Using the given information, we can determine the frequency to be 75.81Hz and the period to be 0.013s. The distance the end of one of the fork tines travels in one second is 178.9mm. This is calculated by multiplying 4 (the number of amplitudes in one vibration) by 0.59mm (the amplitude) and then by 75.81 (the frequency).
FlorenceC
24
A tuning fork vibrates 235 times in 3.1 seconds with an amplitude of 0.59mm. Determine..
i) its frequency
ii) its period
iii) the distance the end of one of the fork tines travels in one second
for i) The answer I got is f=75.81Hz
ii) The answer I got is 0.13s
iii) ?
hz is 1/s so 235/3.1s
period is 1/frequency s
You may want to check your calculation for part (ii) again! I think it is 0.013s
I think a little more info is needed for part (iii) because you don't know where it is starting from. Do we want to find the distance it travels after 1 second from it's equilibrium position or from its maximum displacement?
I'm going to guess equilibrium, since this is only gr. 11 physics. The supply teacher said there are 4 amplitudes in 1 vibration, so the distance is 4*0.59*frequency. I tried it, but I got an unreasonable answer and I don't think there are 4 amplitudes in a vibration.
Another reasonable guess is that it means on average (which is fact what you computed).
Starting from equilibrium, how far will it travel in the first quarter period? How far in the second quarter?
What answer did you get?
First quarter = 44.73 mm
Second quarter = 89.4 6mm
How did you get those numbers? The amplitude is only 0.59 mm.
For the first quarter, there is 1 amplitude, so (1*0.00059*75.81)
For the second quarter, there are 2 amplitude, so (2*0.00059*75.81)
I multiplied by the frequency to get the answer for 1 second.
Displacement is not the same as the distance travelled. If you go to school 500 m far, you walk 500 m and your displacement is also 500 m. If you go there and back, your displacement is zero, but you walked 1000 m, your "distance travelled" or "distance covered" is 1000 m. The tip of the fork travels from equilibrium to maximum displacement (amplitude) during a quarter of the period. Then it moves backwards, reaching zero displacement in quarter period again, but traveling A distance again, so the distance traveled in half period is 2A. The whole distance traveled in one period is 4A. The number of periods in one second is equal to the frequency. So the total distance traveled in one second is? ehild
ehild
so the answer is 4*0.00059*75.81 = .1789m or 178.9mm
Yes it is, but round it to three significant digits.
ehild
I had asked how far in one quarter period, i.e. one quarter of a complete oscillation.
You had expressed doubts that it traveled four amplitudes in each period; I was trying to get you to see that it does.
ehild
I finally understand it now. Thank you so much ehild and haruspex.
FAQ: Sound waves question - vibrations and amplitudes
1. What are sound waves?
Sound waves are a type of mechanical wave that travel through a medium, such as air or water. They are created by vibrations and carry energy from one location to another.
2. How are sound waves produced?
Sound waves are produced when an object vibrates, causing the molecules in the surrounding medium to vibrate as well. These vibrations create a series of compressions and rarefactions which travel through the medium as a sound wave.
3. What is the difference between frequency and amplitude in sound waves?
Frequency refers to the number of vibrations per second and is measured in Hertz (Hz). Amplitude refers to the magnitude of the vibrations and is measured in decibels (dB). In simple terms, frequency determines the pitch of a sound while amplitude determines the volume.
4. How do vibrations and amplitudes affect the quality of sound?
The vibrations of an object determine the frequency of the sound wave, which in turn affects the pitch of the sound. Amplitude, on the other hand, affects the volume of the sound. Higher amplitude results in a louder sound, while lower amplitude results in a quieter sound.
5. How do sound waves travel through different mediums?
Sound waves can travel through any medium that has particles for the waves to interact with. This can include solids, liquids, and gases. However, the speed of sound will vary depending on the properties of the medium, such as its density and elasticity.
