rhody
- 3
http://lhcsound.hep.ucl.ac.uk/page_library/SoundsLibrary.html"
This above link that has 17 different sounds:
and
http://www.physorg.com/news196520209.html"
Rhody...
P.S. They use every trick in the book to give the data analysis team(s) every advantage not to miss anything, quite clever.
and
"When you are hearing what the sonifications do you really are hearing the data,” said Archer Endrich, a composer and software engineer working on the project. “It's true to the data, and it's telling you something about the data that you couldn't know in any other way.”
Some of the data comes from Atlas, one of six detectors at the LHC. Atlas uses a calorimeter to measure the energy of the particles that collide inside of it. The calorimeter consists of seven concentric layers, each of which can be represented by a note. The note’s volume and pitch depend on the amount of energy deposited in that layer and its location in the layer, respectively. As physicist Lily Asquith explained, large amounts of energy make louder sounds than small amounts, while energy closer to an observer will have a higher pitch than energy located further away.
Rhody...
