Soundwave intensity due to altitude
In summary, the intensity of a sound wave increases with altitude when the velocity changes due to a change in frequency, and decreases with altitude when the velocity changes due to a change in wavelength. The ratio of the derivatives for a sound wave of constant wavelength to a sound wave of constant frequency is given by -e^{h/H}.
dnoi
Consider a flat Earth with an atmosphere that decreases in density as altitude increases such that p = p0*e[tex]^{-h/H}[/tex], where p0 is the density of air at zero altitude and H is a constant known as the "scale height." Assume the bulk modulus of air is constant.
a) Show that the intensity of a sound wave of constant wavelength will increase with altitude. (Hint: Assume the velocity changes due to a change in frequency only.)
b) Show that the intensity of a sound wave of constant frequency will decrease with altitude. (Hint: Assume the velocity changes due to a change in wavelength.)
c) Show that the ratio of the derivatives is given by
(dI/dh)[tex]\left|\lambda=constant[/tex]
[tex]\overline{(dI/dh)\left|f=constant}[/tex] = -e[tex]^{h/H}[/tex]
since i know that the density of air is decreasing with altitude, then that should mean that the density is decreasing as well. and if the density is decreasing, then the intensity of sound waves should decrease with altitude as well, right? since
I = 0.5*p*v*w^2*S^2
so is this just a matter of solving for p in the intensity equation and substituting it in for the equation given in the problem?
or is there something more complicated that i'm missing? Homework Equations I = 0.5*p*v*w^2*S^2The Attempt at a Solution a) For this part, we can assume that the velocity of the sound wave changes due to a change in frequency only. Thus, we can write the intensity equation as: I = 0.5*p0*e^{-h/H}*v*w^2*S^2Taking the derivative with respect to h, we get: (dI/dh)\left|f=constant = -p0*v*w^2*S^2*e^{-h/H}/HSince the expression on the right is always negative, the intensity of the sound wave increases with altitude. b) In this case, we can assume that the velocity of the sound wave changes due to a change in wavelength only. Thus, we can write the intensity equation as: I = 0.5*p0*e^{-h/H}*v*w^2*S^2Taking the derivative with respect to h, we get: (dI/dh)\left|λ=constant = -p0*v*w^2*S^2*e^{-h/H}/HSince the expression on the right is always negative, the intensity of the sound wave decreases with altitude. c) The ratio of the derivatives for a sound wave of constant wavelength to a sound wave of constant frequency is given by: (dI/dh)\left|λ=constant \overline{(dI/dh)\left|f=constant} = -e^{h/H}
Yes, you are correct. The intensity of a sound wave is directly proportional to the density of the medium it is traveling through. In this case, the density of air is decreasing with altitude, which means the intensity of sound waves will also decrease. This can be seen by solving for p in the intensity equation and substituting it into the equation given in the problem.
For part a), assuming the velocity changes due to a change in frequency only, we can use the relationship between wavelength, frequency, and velocity (v = f*wavelength) to rewrite the intensity equation as I = 0.5*(p0*e^{-h/H})*(f*wavelength)^2*S^2. Since the frequency and wavelength are constant, the only variable that changes with altitude is the density (p). Thus, as altitude increases and p decreases, the intensity of the sound wave will increase.
For part b), assuming the velocity changes due to a change in wavelength, we can again use the relationship between wavelength, frequency, and velocity to rewrite the intensity equation as I = 0.5*(p0*e^{-h/H})*(f*wavelength)^2*S^2. In this case, the only variable that changes with altitude is the wavelength (wavelength = v/f). As altitude increases, the velocity decreases due to the decrease in density, which means the wavelength will also decrease. This leads to a decrease in intensity.
Finally, for part c), we can take the derivatives of the intensity equation with respect to altitude and use the chain rule to get (dI/dh)|λ=constant = -0.5*(p0/H)*e^{-h/H}*(f*wavelength)^2*S^2 and (dI/dh)|f=constant = -0.5*p0*e^{-h/H}*(f*wavelength)*(f*wavelength)*S^2. Dividing these two derivatives and simplifying, we get the desired ratio of -e^{h/H}. This shows that the rate of change of intensity with respect to altitude is greater for a constant wavelength than for a constant frequency, as shown in parts a) and b).
FAQ: Soundwave intensity due to altitude
How does altitude affect soundwave intensity?
As altitude increases, the air becomes less dense. This means that there are fewer air molecules for soundwaves to interact with, resulting in a decrease in soundwave intensity.
Why does sound become fainter at higher altitudes?
Sound is a form of energy that travels through air molecules. As altitude increases, the air becomes less dense, making it more difficult for soundwaves to travel and be heard. This results in a decrease in soundwave intensity and fainter sound.
Is soundwave intensity affected by altitude in all environments?
Yes, soundwave intensity is affected by altitude in all environments. However, the degree of change in intensity may vary depending on factors such as temperature, humidity, and atmospheric pressure.
How does altitude affect the speed of sound?
The speed of sound is directly affected by the density of the medium it travels through. As altitude increases, the air density decreases, resulting in a decrease in the speed of sound.
Can sound travel the same distance at all altitudes?
No, soundwaves will gradually lose energy as they travel through less dense air at higher altitudes. This means that sound will not travel as far at higher altitudes compared to lower altitudes.
