Source of energy in fusion reactions
In summary, nuclear fusion and fission reactions involve the conversion of mass into energy. In fusion, four hydrogen nuclei fuse to form a helium nucleus, releasing energy in the process. However, the total energy on the left side is calculated to be less than that of the product nucleus, leading to confusion about where the energy is coming from. This is due to the conversion of two protons into neutrons and the release of positrons and neutrinos, which carry away some of the energy. The binding energy curve and semi-empirical binding energy formula can help explain this phenomenon, as they show that fusion reactions release energy at lower atomic masses while fission reactions absorb energy at higher atomic masses.
ananthu
106
In the case of nuclear fission, when U-235 splits into Ba,Kr and three neutrons , then it is shown that the total mass of the products on the right side of the equation is slightly less than that of the reactants on the left side. So this missing mass-the mass defect – is converted into energy and released. But in the case of a nuclear fusion reaction, when 4 hydrogen nuclei fuse together and form a helium nuclei there also energy is released ie.27.6 MeV per fusion. But how this mechanism can be explained?
Because in this reaction the total energy on the left side is calculated as 4.4 MeV and that of the product nuclei ie. He, is given as 28 MeV. Here the energy on the right hand side is found greater than that of the left side. Logically in this reaction it appears as if the energy is only absorbed, but not released. Then how we do we get the energy released in the fusion reactions as in the case of fission reactions?
Can anybody kindly explain this contradiction in a simple manner?
If you calculate the masses on the left and right side, you'll see that the helium nucleus (plus positrons) is lighter than the 4 protons together. It is very similar to fission in that respect.
The total energy in the process is of the order of 4 GeV, not MeV, but most of that remains in the nuclei.
Also keep in mind that "4 protons -> Helium-4" as single process does not exist.
Also remember that somewhere along the way, two protons have been converted to two neutrons, and the positrons and neutrinos thus produced will be happy to carry away some of the energy in the form of kinetic energy.
Look up "binding energy curve" and "semi-empirical binding energy formula." Generally speaking (there are exceptions), at lower atomic masses, fusion releases energy and fission absorbs energy. At higher atomic masses, it's the other way around.
FAQ: Source of energy in fusion reactions
What is fusion energy?
Fusion energy is a type of nuclear energy that is created through the fusion of two or more atomic nuclei. This process releases large amounts of energy, similar to the process that powers the sun.
Where does fusion energy come from?
Fusion energy comes from the fusion reactions that occur in the core of stars. These reactions fuse together lighter elements, such as hydrogen, to form heavier elements, releasing energy in the process.
What is the source of energy in fusion reactions?
The source of energy in fusion reactions is the conversion of mass into energy, according to Einstein's famous equation E=mc^2. This means that a small amount of mass is converted into a large amount of energy during a fusion reaction.
How is fusion energy different from other types of energy?
Fusion energy is different from other types of energy because it is a very clean and efficient form of energy. It produces no greenhouse gas emissions and does not generate any radioactive waste. It also has the potential to provide a nearly limitless supply of energy.
What is the current state of research on fusion energy?
Scientists and researchers around the world are actively working on developing fusion energy as a viable source of clean energy. While there have been significant advancements in fusion technology, it is still in the experimental stage and has not yet been commercially implemented. More research and development is needed to make fusion energy a practical energy source.
