Space elevator wondering about torque
In summary, the conversation discusses the potential impact of a space elevator on the Earth's rotation and the risk of collisions from non-geosynchronous satellites. It is theorized that the elevator may have a minute effect on the Earth's rotation, but it would be too small to be measured. The impact of a space rock or other objects hitting the top of the elevator is also considered, but it is concluded that the deflection would not be enough to cause any damage.
fahraynk
186
Say you have an elevator that reaches space. I have 2 questions :
1) say a space rock hits the top of the elevator... that would create a torque = force * distance on the ground... Wouldn't it instantly snap from any light force or space junk hitting the top of the elevator? Would the station have to instantly compensate for something like this?
If this is true, any compensating force would have to act really fast right? Because if the force is countered so that it lasts for only a millisecond maybe it won't be long enough to make the material break (maybe it needs time to pass the materials elasticity region or something). Or would it create some kind of force wave going back and forth through the tower if the force only acts for a half a second?
2) Someone was asking on facebook about the Earth slowing down like when an ice skater spreads out their arms while spinning. I think the moment of the inertia of Earth would be so great that the change from a space elevator would not have any effect. But in theory it should have SOME minute effect... So my question is... if you remove the space elevator, would momentum be conserved and that minute amount of rotational velocity the elevator might remove from the Earth would be instantly retrieved, so that the Earth's rotational speed goes back to the pre elevator speed?
Apart from the strength issue, there is the problem that a space elevator tether would be at risk of collision from every non-geosynchronous satellite, eventually.
The angular momentum situation would depend on the construction method. If it starts with a mass, placed in geosynchronous orbit then the angular momentum of the mass would have been increased by the rockets placing it in orbit. If it's made by building a tower from ground up, the angular momentum would be shared with the Earth so you would get a theoretical slowing down - but, do the sums - not detectable.
Likes Ron G and fahraynk
Large angular momentum, sure. But nothing is deflecting very much, so nothing is going to break because of the deflection.
Yes, a deflection at the top would cause a wave to propagate down the elevator. Exactly like a wave on a string.
You are right. It would, in theory, have a minute effect on the rotation speed of the Earth, too small to be measured.
When you remove the elevator, are you severing the tie and allowing it to be ejected into space? If is it ejected then the angular rotation of the Earth will remain at its reduced rate. If it is reeled back in then the angular rotation rate of the Earth will return to normal, like a skater pulling her arms back in.
Likes smokingwheels, sophiecentaur and fahraynk
Related to Space elevator wondering about torque
1. What is a space elevator?
A space elevator is a proposed structure that would allow for transportation from the surface of Earth to outer space. It consists of a cable anchored to the Earth's surface and extending into space, with a counterweight at the other end. The concept was first proposed by Russian scientist Konstantin Tsiolkovsky in 1895.
2. How does a space elevator work?
A space elevator works by utilizing the centrifugal force created by the Earth's rotation. The cable is anchored to the Earth's surface at the equator and extends into space, where a counterweight keeps it taut. Vehicles can then climb or descend the cable using a combination of mechanical and electrical power.
3. What is torque in relation to a space elevator?
Torque is the force that causes an object to rotate around an axis. In the case of a space elevator, torque is generated by the Earth's rotation and is what keeps the cable taut and able to support the weight of vehicles climbing or descending it.
4. What challenges are there for space elevators in terms of torque?
One of the main challenges for space elevators is the amount of torque that needs to be overcome. The Earth's rotation generates a significant amount of torque, and the cable must be able to withstand it without breaking. This requires strong and lightweight materials that can withstand the stress and strain of the torque.
5. Are there other factors besides torque that need to be considered for a space elevator?
Yes, there are several other factors that need to be considered for a space elevator, including the strength and durability of the cable material, the design and construction of the anchor and counterweight, and the safety and reliability of the transportation system. Additionally, the cost and feasibility of building and maintaining a space elevator must also be taken into account.
  • Astronomy and Astrophysics
