Space Expansion and Light question
In summary, the Hubble redshift effect, also known as the Hubble law, is caused by the expansion of space and can be observed as an increase in wavelength and decrease in frequency of light as it travels through vast distances. This effect was a key factor in discovering the expansion of the universe and is still used today to study the universe's expansion rate. Other theories, such as the Tired Light hypothesis, have been proposed, but have been ruled out due to inconsistencies with the observed data.
hagendaz
As a steady stream of light particles (or any other form of measurable energy) from some distant star, say a billion light years away, makes its way toward us, shouldn’t space expansion cause consistent and measurable gaps to form between each light particle, causing a blinking effect? The farther its origin the larger the gap between each particle…
Astronomy news on Phys.org
Wow.
The effect you're describing is known as the Hubble redshift. You see, light can be thought of as a wave with a given frequency, and like you say, the gaps get larger because something is far away and space is expanding in between, so the frequency goes down. This correlates to an increase in wavelength (known as a redshift). It's not exactly a blinking, but it is a very measurable effect.
The detection of this effect is what caused astronomers to discover that the universe is expanding in the first place! And furthermore, that the rate of expansion is directly proportional to the distance (which you also concluded).
Did you come up with this on your own? It's very interesting if you did, using the fact that space is expanding to kind of reverse prove the Hubble redshift.
This equation is known as Hubble's law, and you can read about it here:
http://en.wikipedia.org/wiki/Hubble_law
Actually, I did come up with that question on my own, but to be honest it was born of my skepticism of the idea that space is expanding… I guess I am forced to be less skeptical now! Thanks for the link! Most of it is way, way over my head…
So, not to completely abandon my now reduced skepticism…is it possible for light to degenerate into a longer wavelength and lower frequency on its own after traveling extreme distances, thus producing the same results? Similar to the degeneration of ripples on a pond radiating from the impact of a thrown stone.
Is it possible that the light, having passed through ever increasing amounts of space dust over extreme distances is responsible for slowly shifting the light to red (similar to a sunset effect)
Or perhaps some sort of gravitational prism effect over extreme distances….
Another really great question. (These are really awesome by the way)
Dust does tend to absorb bluer light which tends to shift the spectrum of a given object towards the red, so one always has to make sure that an observed redshift is not simply because of dust between the source and observer.
Your question about light degenerating into a longer wavelength after traveling extreme distances is a good one as well! This is a theory known as Tired Light, whereby photons, after traveling for a while, lose some energy (and thus increase in wavelength). It was pushed hard by the advocates of the steady state theory (the main opposition to the expanding universe model), but has since fallen out of favor because it doesn't fit the observed data as well as Hubble's Law does. Again, you can read more about this at:
http://en.wikipedia.org/wiki/Tired_light
The photon can be absorbed and re-emitted by dust possibly, but I do not think photon itself can not get tired or change itself because it travel in speed 'c', so the clock on the photon is frozen, I mean if the photon carry a clock it should be frozen forever so there is no time elapse from photon point of view, therefore photon can not age. This is just one possible explanation and I agree the photon will change its wave length as space expands.
Your analysis is correct when analyzing light as a particle but when looked at as a wave, the tired light hypothesis might seem to make sense. (Of course it has now been ruled out but it's important, I think, to understand competing models to explain phenomenon and why they don't work as well)
Related to Space Expansion and Light question
What is space expansion?
Space expansion refers to the phenomenon of the universe constantly expanding and stretching outwards. This expansion is driven by the force of dark energy and is supported by evidence such as the redshift of distant galaxies.
How does space expansion affect the speed of light?
Space expansion does not directly affect the speed of light. The speed of light is a fundamental constant and remains constant regardless of the expansion of space. However, space expansion can affect the distance that light travels, leading to the phenomenon of redshift.
What is redshift?
Redshift is a phenomenon observed in light from distant objects, where the wavelength of the light is stretched out, causing the light to appear more red. This is caused by the expansion of space and can be used to measure the distance and speed of objects in the universe.
What is the role of dark energy in space expansion?
Dark energy is a mysterious force that is thought to be responsible for the accelerating expansion of the universe. It is believed to make up about 68% of the universe and its repulsive force counteracts the gravitational pull of matter, causing the expansion of space.
What implications does space expansion have for the future of the universe?
Based on current observations and theories, it is believed that space expansion will continue to accelerate, leading to the eventual "heat death" of the universe. This means that all matter will be spread out and the universe will be in a state of maximum entropy, making it unable to sustain life.
