Space expansion in our perspective?
In summary, the conversation discusses the concept of expanding space and its implications on a local scale, specifically within a room. It is explained that the distance between galaxy clusters is increasing due to the expansion of space, but this does not apply to stationary objects such as the walls of a room. The concept of inward peculiar velocity is also mentioned, and it is noted that the expansion of space is a mathematical description rather than a physical property. The conversation also touches on the role of dark energy in the acceleration of galaxies away from each other.
  • #36
DaveC426913 said:
Well, if you say so, but the reason it came up at all was because properties were being attributed to this fabric analogy as if it was real and could affect reality.
Hey. Two words was my contribution. And I mitigated it with an emoticon. :biggrin:
As I said, fabric is merely a descriptive word, an adjective to describe a slice of our 4 Dimensional Spacetime. Call it what you want, but hey, nearly every theory in existence attributes properties to this cross section of Spacetime. Relativity says that spacetime is affected by mass and energy, QFT gives empty spacetime (the vaccuum) energy and energy density. The way we describe the 'fabric' of spacetime certainly affects reality, and no more will I argue this point.
DaveC426913 said:
As the balloon expands, the distance between the pennies increase, yet the pennies do not increase in size. Why? Because the forces holding the atoms of the penny together utterly dwarf the forces of the balloon pulling it apart
Utterly, as of what we know, false.
Ich said:
Acceleration is equivalent to something repulsive, and we call that something Dark Energy.
The galaxies are moving away since the big bang kick-off. Your walls are not moving away, because nobody kicked them.
Finally we reach the correct conclusion. Thank you Ich.
Astronomy news on Phys.org
  • #37
The description in expanding coordinates is mathematically the simplest, and it successfully makes use of the cosmological principle - which means, they become quite natural if you "add the assumption that this happens everywhere in the universe".
ok, so did the term "space expansion" come from the fact that mathematically describing the motion of galaxies worked better in an expanding coordinate system?
Is there physical evidence that space is expanding or is it just a result of the math?
The concepts of distance and velocity are quite tricky at really large scales,
As I said, the concept of velocity is not well defined on large scales.
Why is this? Relitivity?
  • #38
I think so. In these coordinates, if you calculate the expression for "change in proper distance", you get a very simple and suggestive formula. Like "recession = motion of space + motion through space". This took a life on its own, it seems.
There is ample evidence for redshift being more or less proportional to distance. Which means that the universe may be described well as objects more or less at rest in an expanding coordinate system. I don't know how that pertains to evidence for "expanding space".
Yes.
For example, in special relativity you may have heard that it's tricky to http://en.wikipedia.org/wiki/Velocity-addition_formula#Special_case:_parallel_velocities". In cosmological coordinates, you add them without correction nonetheless. That's easy and appropriate, but the result definitely has nothing to do with "velocity" in the SR sense. Especially, v<c does not apply. That's just the effect of an unusual coordinate system.
Then, in GR, matter determines geometry. You don't even have that static background on which to base your misunderstandings. Is distance changing, or is the light we took to measure distance delayed by some matter that intervened? There's not way to decide such questions.
  • #39
Thank you Ich.
My curiosity is temporarily satisfied. :)
  • #40
Expansion is a pathetically weak 'force' compared to the other forces of nature - gravity, nuclear and electroweak. It is overwhelmed by these forces until until things become so vastly distant their effects become negligible.
  • #41
Nobody knows the correct answer to this question...
