Space is "Entangled", says Leonard Susskind
In summary, Fredrik seems to be saying that space itself is made of virtual particles, and that this is one of the main points he is trying to make in the video. However, he is not sure how whole fields can be entangled. It is unclear to me what entanglement is, and whether it is a state in which every point in the field is entangled with every other point in the field, or something else. It is unclear to Fredrik how to recover an observer invariant description out of this, and he seems to be confused.
friend
1,452
In the following youtube video,
at 1:10:15, is he saying that space itself is "entangled" by means of the virtual particles of the vacuum energy being entangled? It sounds like this is one of the main points he is trying to make in the video. But if this is so, then isn't he saying that space itself is made of virtual particles, particles that transverse distances of space?
I know some here really hate the idea of virtual particles and think of them as just a popular euphemism for the entities of quantum field theory. But I have to wonder how whole fields can be entangled. I thought only particles could be entangled.
That what happens when you are doing theoretical physics too long, you stop differentiating between what is virtual and what is real...:-)
Likes ISamson and Demystifier
One way to think about it is that we get slightly different theories at different energy scales. The energy scale is a continuous quantity, and analogous to a "spatial dimension". It turns out that in specific cases, this is analogy seems to hold in fair detail. For example, the Ryu-Takayanagi formula relates the entropy of entanglement at the boundary of space to an area in space.
https://www.scientificamerican.com/article/tangled-up-in-spacetime/
https://www.quantamagazine.org/tensor-networks-and-entanglement-20150428/
Likes junjunjun233
It's not clear to me in these two papers what exactly is entangled and causes spacetime to emerge. Its content (matter and energy) or some yet to be discovered "atoms of space(time)"?
Likes giovannifois
No, all quantum objects can be entangled. Even the vacuum is entangled, which is the origin of Reeh-Schlieder theorem.
Likes Haelfix
IMO, as the concept of entanglement is observer dependent in an wide sense, and entanglements between widely separated systems correlate "instantaneously" it almost throws in our faces that locality in ordinary 4D-spacetime and locality the more general "information space" so to speak can mix, and thus we have an observer dependent way of "mixing" internal and external degrees of freedom. While hard to grasp it hits the core of the foundational issues still not resolved, right?
Ie. what are external and what are internal degrees of freedom is ultimately observer dependent. We need to accept that, and find a way from there to emergence of the effectively objective spacetime symmetries.
/Fredrik
I have a sense of how particles can be entangled. But I still don't understand how a field can be entangled. Is this a state in which every point in the field is entangled with every other point in the field? Or is it that one point in a field may be entangled with maybe one other point in that field? Or is it something else entirely?
Yes. But in the case of vacuum, the degree of entanglement decreases with distance.
That would also be entanglement, but I don't know any explicit case of that.
Note sure if got the question, but what susskind said is that two quantum entangled black holes is like a wormhole, connecting two separated points.
I think it helps a little to think of entanglement is simply a dependence between outcomes of different measurements, for a given observer. So its kind of the measurements that are entangled. I principle this can be a measurement of ANYTHING. And this is a observer dependent constructon. This is why i think its confusing to say that "fields are entangled". If by fields we mean an observer defined quantum field that i may be more sound, but if its some classical or otherwise vague field whose "measurement" is not clear, it prefer to refrain from the terminology.
But how to recover some observer invariant description out of this, seems to me like a very hard task, and stil open question. I consider susskinds speak to have the purpose to make us think of this.
Did he expect us "understand" this?? I suspect not. Getting confused and embrace the confusion is probably a first good step. And i feel very confused.
/Fredrik
I think I can understand this in terms of a field. For if I know everything about one point in a field, where it is, its velocity, its acceleration, then I think I can say something about the waves of the whole field, right? But that would be the case classically as well. So I'm not sure where the quantum entanglement comes in. It would seem that the uncertainty principle would blur any information I would suppose about the whole field based on what I know at a single point. Is this uncertainty principle why I would lose entanglement with distance?
No. Entanglement between different degrees of freedom is caused by interaction between those degrees of freedom. It diminishes with distance (in the case of vacuum) essentially because the effect of interaction diminishes with distance.
What is "interacting"? I though only particles interacted with other particles. How can one point of a field interact with another point of a field, if it is not a particle? Thanks.
Yes, I am puzzled by this as well. I'm glad you asked.
Guys, have you ever been reading a book on field theory? Even classical field theory (like classical electrodynamics) counts. According to field theory, it is fields that interact. Particles can be thought of as special quantum states of fields.
Likes craigi and Urs Schreiber
By the way, some references that discuss in a bit more technical detail the entanglement entropy of fields that is being referred to in these kind of discussions are listed here
Got it: It is the entanglement of the field; even in the CFT vacuum one has AdS spacetime in the bulk.
Incidently this thread started in the qm section that imo more belongs in here.
https://www.physicsforums.com/threads/dear-qubitzers-gr-qm.926149/
A recent pondering from susskind takes EPR~ER to the next level and suggestd GR ~ QM
I just saw it and haven't read it yet but - give or take the details how susskind envisions the implications in the string world - i definitely share the vision that space is emergent from the information picture. In its extreme i think it may even hold a possible solution to the landscspe problem but that is yet another huge step
/Fredrik
Am I the only one who has a feeling that Susskind starts to sound like a crackpot? What will be the next step? classical physics = quantum physics? And after that, physics = consciousness?
Well, the paper is clearly not a hard/excplicit paper, i see it more as informal waving argument that suggests a direction of thinking. So i tend to judge it for what i think it is tended?
And given how little progress that has been made om the topic you learn to appreciate even the smallest glimpses.
I agree that qm = gr isn't the best headline, neither do i see any new thinking in his examples. My own approach that i admittedly still has a long wat togo would rather involve a reconstuction of a measurement theory (QM) in a way that spacetime emerges causated by data compression in the observer system.
( Btw, i partially enjoyed your 2013 solipsist HV paper... for an analogous reason. I think is along the right path. I plannned to start a thread on that as well but didkt get time yet.)
So my own perspective is open minded and "understanding" - this is hard stuff and i see only constructivity in whete researchers post soft papers as they can give ideas.
For a mathematician i suspect susskinds paper is all baloney but he isn't a crsckpot in eyes. But he has the ballls to publish a soft paper? Rather a soft ball in the right direction than hard balls in the wrong direction. Unless you are just into mathemqtics. Then the way of doing things rank higher than doinh the right thing.
/Fredrik
Likes smodak
Well by the criterion here in physicsforums where moderators judge physical claims without maths as crackpot, then yes he is a crackpot.
But perhaps in hypography forums he won't be judged so harshly... :-D LOL
No. I've had the same feeling with some of his students. I can even remember collegues of mine walking away during talks, because it was one hour of handwaving speculation.
Sometimes that can lead to nice observations. But let's not overdo it :P
Likes Demystifier
You probably know this, but it's worth clarifying that you do not need interactions for entanglement. Even a free quantum field theory has an entangled vacuum state.
Yes, but I actually wanted to say that what we call "free" field is actually an interacting field. Namely, the term ##(\nabla\phi)^2## in the "free" field Lagrangian density is actually an interaction in the same sense in which harmonic oscillator potential proportional to ##x^2## is an interaction. Indeed, you probably know that "free" field can be thought of as a series of an infinite number of coupled harmonic oscillators.
Could you please explain what you mean by "observer dependent"? Thank you.
A concept or procedure to produce a number during a measurement is observer dependent if different observers follow the same "prescriptions" from their perspective and later compare their numbers they disagree.
A typical constructing principle for physical law is that laws of physics - to the extent that they are objective - must be seen the same to all observers.
When apparent disagreements appear, objectivity are often restored once we find the transformations that relate observers views and the laws can be formulated in the objective way. That was the case with sr and gr as well. But the observer dependence I've talked about relate observers that can't be generated just by simple diffeomorphisms. There is no known symmetry for this.
/Fredrik
Related to Space is "Entangled", says Leonard Susskind
What does it mean for space to be "entangled"?
According to Leonard Susskind, entanglement refers to the idea that space is not just a passive background for objects to exist in, but it is an active participant in the behavior of those objects. This means that the properties of space itself can affect the behavior of objects within it.
How does entanglement of space impact our understanding of the universe?
The concept of entanglement challenges traditional notions of space as a fixed and independent entity. It suggests that space is interconnected and can influence the behavior of objects within it, leading to a new understanding of the universe as a dynamic and interconnected system.
Can entanglement of space be observed or measured?
Currently, there is no direct way to observe or measure the entanglement of space. However, scientists are working on developing new techniques and technologies that may allow for its detection in the future.
How does the concept of entanglement relate to quantum mechanics?
Entanglement is a fundamental principle of quantum mechanics, which describes the behavior of particles at the smallest scales. It suggests that particles can become entangled with each other, sharing a connection that affects their behavior even when they are separated by large distances.
What implications does the idea of entanglement have for the nature of reality?
The concept of entanglement challenges our traditional understanding of reality as a collection of independently existing objects. It suggests that everything in the universe is interconnected and that the properties of space itself play a significant role in shaping the behavior of objects. This has profound implications for our understanding of the fundamental nature of reality.
  • Beyond the Standard Models
  • Quantum Physics
  • Quantum Physics
