Space-like trajectory in Schwarzschild spacetime
The discussion focuses on analyzing space-like trajectories in Schwarzschild spacetime, specifically how to derive the smallest radial coordinate \( r \) reachable by a mass \( M \). The Schwarzschild metric is applied, leading to the condition \( ds^2 > 0 \). Participants suggest using an effective potential approach and the conservation of energy and angular momentum to simplify the problem. The equation derived relates the radial motion to an effective potential, which can help determine the closest approach distance \( r_0 \). The conversation emphasizes the importance of correctly applying the Schwarzschild metric and understanding the implications of space-like paths.
crime9894
For Schwarzschild metric, consider a mass M following space-like trajectory.
The relativistic energy of the mass at infinity is E.
Show that there is smallest value of r, the radial coordinate, reachable by the mass, and find its value.
As shown below
I'm not sure how to approach this question.
So I start off with the fact the path taken is space-like,
$$ds^2>0$$
Input the Schwarzschild metric,
$$−(1−\frac{2GM}{r})dt^2+(1−\frac{2GM}{r})^{−1}dr^2>0$$
Where I assume the mass doesn't move in angular direction.
How should I continue?
crime9894 said:
Homework Statement:: For Schwarzschild metric, consider a mass M following space-like trajectory.
Relevant Equations:: As shown below
$$ds^2>0$$
Are you assuming any space-like path or space-like geodesics?
Did you mean to use ##M## in the metric? Isn't ##M## the mass of the moving body?
I assume that the limiting case of these trajectories is a null trajectory, i.e. a trajectory followed by a light ray. As per usual, it would help to cast the problem in terms of an effective potential. Assuming the trajectory is confined to the equatorial plane ##\theta \equiv \pi/2## (which is always possible to achieve by means of a rotation of the coordinate system), write\begin{align*}
0 = g_{\mu \nu} u^{\mu} u^{\nu} &= g_{tt} \left( \dfrac{dt}{d\tau} \right)^2 + g_{rr} \left( \dfrac{dr}{d\tau} \right)^2 + g_{\phi \phi} \left( \dfrac{d\phi}{d\tau} \right)^2 \\
&= -f(r) \left( \dfrac{dt}{d\tau} \right)^2 + f(r)^{-1} \left( \dfrac{dr}{d\tau} \right)^2 + r^2 \left( \dfrac{d\phi}{d\tau} \right)^2 \ \ \ (\dagger)
\end{align*}with ##f(r) \equiv 1-2m^*/r##. Recall that this metric implies two Killing vectors ##\xi = \partial / \partial t## and ##m = \partial / \partial \phi##, and therefore two conserved quantities \begin{align*}
E &\equiv -u \cdot \xi = -g_{\mu \nu} u^{\mu} \xi^{\nu} = -g_{tt} u^t \xi^t = f(r) \dfrac{dt}{d\tau} \ \ \ (\sim \mathrm{energy})\\
L &\equiv u \cdot m = g_{\mu \nu} u^{\mu} m^{\nu} = g_{\phi \phi} u^{\phi} m^{\phi} = r^2 \dfrac{d\phi}{d\tau} \ \ \ (\sim \mathrm{angular \ momentum})
\end{align*}which allows you to substitute ##\dfrac{dt}{d\tau} = \dfrac{E}{f(r)}## and ##\dfrac{d\phi}{d\tau} = \dfrac{L}{r^2}## in ##(\dagger)##, \begin{align*}
\boxed{\dfrac{1}{2} \dot{r}^2 + \dfrac{L^2 f(r)}{2r^2} = \dfrac{1}{2} E^2 }
\end{align*}with ##\dfrac{L^2 f(r)}{2r^2} \equiv V(r)## an effective potential. Can you figure out how to use this equation to investigate the positions ##r_0## of closest approach?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
Thread 'Stacked blocks & pulley system'
I've posted my attempt at a solution but I haven't gone through the whole process of putting together equations 1 -4 yet as I wanted to clarify if I'm on the right path My doubt lies in the formulation of equation 4 - the force equation for the stacked block. Since we don't know the acceleration of the masses and we don't know if mass M is heavy enough to cause m2 to slide, do we leave F_{12x} undetermined and not equate this to \mu_{s} F_{N} ? Are all the equations considering all...
