Space Requirements for Industrial Cabinets
In summary, the conversation discusses the issue of clearance top and bottom when mounting in a cabinet, particularly in regards to air flow and manufacturer warranties. The use of wireways and limited space in the cabinet may also play a role in the layout and potential challenges for the electrician. It is advised to consult with the manufacturer or a lawyer for any legal questions regarding warranty.
Som_P
Quick question. If the manufacturer's specs ask for clearance top and bottom when mounting in the cabinet, does that usually mean actual open space? For example, I am using Watlow Power Controllers that require 4 in. of clearance top and bottom. I have about 2 in. spacing with a 2x3 in. wireway above and below. The Watlows are probably 5-6 inches deep and the wireway is 3 in. deep. Would this affect the air flow and nullify any manufacturer warranties?
Usually.
depends on the designs and the room - does the wireway affect air-flow? - is it your information that the clearance is needed for air-flow?
That would be a legal question - you should put it to the manufacturer or their agents... or a lawyer.
That's what I was hoping to find out; if the wireways affect air flow. Using wireways that are slotted and also will only be about 50% full.
The problem is the overall layout. Customer specified cabinet size so space is limited. May be a tight squeeze for all components. Electrician may not be happy.
Related to Space Requirements for Industrial Cabinets
What is the recommended amount of space needed for an industrial cabinet?
The recommended amount of space needed for an industrial cabinet varies depending on the size and type of cabinet. However, as a general rule, there should be at least 2-3 feet of clearance around the cabinet for easy access and maintenance.
What factors should be considered when determining space requirements for an industrial cabinet?
Several factors should be considered when determining space requirements for an industrial cabinet. These include the size and dimensions of the cabinet, the type of equipment or materials that will be stored inside, and any additional space needed for proper ventilation or access.
How much clearance is needed for the doors of an industrial cabinet to open?
The amount of clearance needed for the doors of an industrial cabinet to open will depend on the size of the cabinet and the type of doors. In general, swing doors will require more clearance than sliding doors. It is recommended to allow for at least 2-3 feet of clearance for swing doors and 1-2 feet for sliding doors.
Can an industrial cabinet be placed against a wall?
In most cases, an industrial cabinet can be placed against a wall. However, it is important to consider the dimensions of the cabinet and the wall to ensure there is enough clearance for the doors to open and for proper ventilation. It is also important to follow any safety codes or regulations that may require a certain amount of space between the cabinet and the wall.
Is there a minimum height requirement for an industrial cabinet?
There is no specific minimum height requirement for an industrial cabinet. However, it is important to consider the height of the cabinet in relation to the height of the individuals who will be using it. The cabinet should be easily accessible and not require excessive reaching or bending to retrieve items.
