Space station-nature of orbit?
  • Thread starter humanist rho
  • Tags
    Orbit Space
In summary, the conversation discusses the change in orbit of a space station by firing its engine radially outward. The choices for the new orbit are a larger circle, a smaller circle, an ellipse, or a parabola. The equations used to calculate the velocity for a circular orbit are modified for elliptical orbits by considering the radial and tangential components of the velocity vector. The concept of delta-vee is also mentioned, with a reminder to start with a Free Body Diagram and resolve the vectors to solve for the velocity.
humanist rho
95
A space station moving in a circular orbit around the Earth goes into a new bound orbit by firing its engine radially outaward.This orbit is...
Choices are;
(a) A larger circle
(b)A smaller circle
(c)An ellipse
(d)a parabola
I think it'll be a larger circle or parabola.
But donno how to work it out.
What is the free-body diagram of an object in a circular orbit?
The engine applies thrust radially outward - what does that do to the free body diagram?
Do the engines fire continuously or for a short while?
The change in velocity is important to this.
What can you say about the kind of velocity needed for a circular orbit?
(velocity is a vector - talk in terms of tangential and radial components)
What can you say about the kind of velocity needed for a parabolic orbit?
... an elliptical one?
mv2/r = GMm/r2
v = Sqrt[GM/r] for circular orbit.
How can i modify these equations for elliptical orbit.
Hint:
1. velocity is a vector - represent as radial and tangential.
2. free body diagram
the v in your equation is purely tangential.
when the thrust is applied for a short time it changes the velocity vector ...
what happens to the radial component
what happens to the tangential component
is it possible for an object in a circular orbit to have a radial component to it's velocity?
btw: you equation gets modified as follows...
[tex]\underbrace{ma = F_g+F_{thrust}}_{\text{from FBD}} \Rightarrow \frac{mv_\perp^2}{R} = mg_R -\frac{m}{T}\Delta v_r[/tex]... the thrust is applied for a fixed time T, so creates a change in speed Δv. You'll have heard of thrust being referred to as a "delta-vee"? R is the radius of the orbit so gR is the local acceleration of gravity at R. The minus sign is because the thrust is radially outwards, making the positive direction to be radially inwards. The instantanious velocity after the thrust has been applied is given by
[itex]\vec{v}=v_r\hat{r}+v_\perp\hat{\small \perp}[/itex]
...which has magnitude [itex]v =\sqrt{v_r^2 + v_\perp^2}[/itex]
...and the angle this makes to the radius is [itex]\tan^{-1}(v_\perp / v_r)[/itex].
Lesson: start with the Free Body Diagram, then resolve the vectors.
FAQ: Space station-nature of orbit?
1. What is the nature of the orbit of a space station?
The nature of the orbit of a space station refers to the path that the space station follows around the Earth. Most space stations, like the International Space Station, have a low Earth orbit, meaning they orbit the Earth at an altitude of around 200-400 kilometers. This type of orbit allows the space station to continuously circle the Earth, completing one orbit every 90 minutes.
2. How does a space station maintain its orbit?
Space stations maintain their orbit through the use of thrusters. These thrusters are used to adjust the speed and direction of the space station, allowing it to stay in its designated orbit. Without these adjustments, the space station would eventually fall back to Earth due to atmospheric drag.
3. How long can a space station stay in orbit?
The length of time a space station can stay in orbit varies depending on its altitude, the design of the space station, and any maintenance or resupply missions that may take place. The International Space Station, for example, has been in orbit for over 20 years and is expected to remain in operation until at least 2028.
4. Can a space station change its orbit?
Yes, a space station can change its orbit. This can be done for a variety of reasons, such as avoiding collisions with other objects in space or conducting scientific experiments in different areas of the Earth. However, changing the orbit requires careful planning and the use of thrusters.
5. What happens to a space station when it is no longer in use?
When a space station is no longer in use, it is either deorbited and allowed to burn up in the Earth's atmosphere, or it is sent on a controlled descent into the ocean. This is done to ensure that the space station does not pose a hazard to other spacecraft or to people on Earth.
