Space Time fabric graphic is misleading
In summary, the physicist's view is that the graphic representations of gravity wells and space time as a flexible fabric are misleading and incorrect.
megacal
82
This has been bothering me for some time, and would like to get a physicist's view of it.
If my understanding or contention is in error, please correct me (gently). I only have under grad
physics from 1970, and was a microbiologist, though am interested in quantum physics, cosmology.
My contention is, all the graphic representations of gravity wells, and space time as a flexible fabric are very misleading, and incorrect.
The distortion of space time must extend in ALL dimensions, xyzt, about the distorting mass, from a proton to a black hole. The "depth" of the well is really the extent of the gravitational field, and is infinite in all directions,
though is so weak that it cannot be measured at some point.
We effect Andromeda and vice versa. The whole universe is connected by gravity.
Is that correct?
Thanks in advance.
Space news on Phys.org
It leads to a lot of misunderstandings, yes. Unfortunately it isn't possible to draw the kind of manifolds that general relativity uses accurately. You can produce useful maps of highly symmetrical cases, but their interpretation is not necessarily intuitive.
Usually what is being plotted in the "rubber sheet" model is Flamm's hyperboloid, which is a representation of what you might reasonably call "two dimensions of space at a given time" around a gravitating mass. Unfortunately it's not that relevant to why gravity works around Earth (it's a second order effect at best). What you really need is one dimension of time and one of space. And that's difficult to draw and doesn't have the intuitive curved-surface-makes-paths-curve interpretation.
So, yeah. See https://xkcd.com/895/
Likes Klystron and FactChecker
That is probably correct although "all" is a very strong word. I have never seen a graphical representation like that which was anything more than a crude hint at the reality. But it is a very useful crude hint.
Is that correct?
Yes. But for any practical purpose (or even impractical) our solar system does not influence Andromeda. Andromeda is 2.5 million light-years away. I am not expert enough to know if the Milky Way has any influence that far away.
All analogies are incorrect at some level else they would not be analogies they would be actual descriptions, BUT ... they are often reasonable attempts to convey, TO LAYMEN, in layman's language something that could only be faithfully conveyed in a way that would make their eyes glaze over (thus the cartoon that ibix pointed to). See for example the link in my signature.
Likes Klystron
Thanks all, especially for the cartoon link...very clever & humorous.
"...they are often reasonable attempts to convey, TO LAYMEN, in layman's language something that could only be faithfully conveyed in a way that would make their eyes glaze over" -phinds
Yes, I felt my eyeballs rolling up into my head as I got a short way into Sean Carroll's "A No-Nonsense Introduction to General Relativity".
I wonder what Newton would say about it. Amazing things to ponder about & wonder at.
Thank you for all your helpful replies.
FAQ: Space Time fabric graphic is misleading
What is the Space Time fabric graphic?
The Space Time fabric graphic is a visual representation of the concept of space-time, which is a mathematical model used to explain the relationship between space and time in the universe.
Why is the Space Time fabric graphic considered misleading?
The Space Time fabric graphic is considered misleading because it is often depicted as a literal fabric or sheet that is bent or warped by the presence of massive objects, giving the impression that space and time are physical objects that can be manipulated.
How does the Space Time fabric graphic differ from the actual concept of space-time?
The Space Time fabric graphic is a simplified visual representation of the complex concept of space-time, which is better described by mathematical equations and models. The graphic also fails to accurately represent the non-physical nature of space and time.
Can the Space Time fabric graphic be useful in understanding space-time?
While the Space Time fabric graphic may help to visualize the concept of space-time, it should not be taken as a literal representation. It is important to understand that space and time are not physical entities that can be bent or manipulated like a fabric.
Are there any other visual representations of space-time that are more accurate?
There are other visual representations of space-time, such as 3D models and simulations, that may be more accurate than the Space Time fabric graphic. However, it is important to remember that these visualizations are still simplified versions of a complex concept and should not be taken as literal representations.
