Space-Time Warpage and Kinetic Energy
In summary, the mass causes space-time around it to warp, and the space-time that it's moved through de-warps.
sgolson
A mass moves through space-time at constant velocity. Space-time around this mass is warped by the mass and as the mass moves through space-time it causes unwarped space-time to warp and already warped space-time to warp more. In addition, the space-time it has moved through de-warps. Why doesn't this scenario result in kinetic energy being lost by the mass? What don't I understand here?
If the mass is changing speed (for example, oscillating or moving rapidly in a circular orbit) it will lose energy through gravitational radiation - think about how pushing a floating object up and down causes ripples to radiate out in all directions. But if the object is just moving at a constant speed, coasting, it won't lose kinetic energy. There are several ways of thinking about this; perhaps the easiest to is to consider that if the object is just coasting and subject to no external forces then, as far as the object is concerned, it's at rest so has no kinetic energy to lose. You're thinking in terms of watching an object moving past you, but from the point of view of someone riding on the object they're at rest and you're the one who's moving, in the other direction.
Thanks for your reply.
I understand everything you've said, but I don't understand why an action (mass distorts space-time) doesn't result in an equal and opposite reaction which would cause the velocity of the mass to be altered.
For a hand-wavy explanation (this is a VERY hand-wavy explanation,so don't push it too far - it's not a substitute for working through the math of frame-dependent kinetic energy)...
If you're thinking of the object at rest while you're moving, then it's surrounded by a static and unchanging curvature; nothing is changing so there's no change in kinetic energy (which is, conveniently, zero).
If you're thinking of yourself at rest while the object is moving, then the curvature is increasing in the region in front of the moving object as the distance from a point in that region to the object decreases - but at the same time the region behind the region is flattening out as the object moves away from it. The two effects cancel out so that the total amount of distortion is constant even though it's non-zero; or you could say that there is no net transfer of energy from the object to the gravitational field around it because the field is weakening in one region at the same rate that it's strengthening in another.
Obviously this wouldn't work if space-time were a physical substance that dissipates energy when it's flexed, like a rubber sheet for example. But it's not.
Nugatory, thanks again. I understand now. I didn't imagine that the de-warping space-time in the wake of the moving mass would return any and all energy to the mass that was transferred to the space-time in front.
But one more question:
You write "or you could say that there is no net transfer of energy..."
Do you mean to say that there is, in fact, a transfer of energy; or that there might be but we don't know for sure; or that there really isn't but if it helps me get my head around this issue then I can go ahead and think of it that way but that I shouldn't express that view should I ever go beyond a bachelor's degree?
Gravitational waves can and do carry away kinetic energy from a system. However, the lowest order of radiation for gravitation is quadrupole, which means that you need something like a spinning barbell to radiate gravitationally. An object in linear motion is not even a dipole source, let alone a quadrupole source.
An object in linear motion has, relative to a fixed point, a dipole moment that's linearly increasing with time. But of course it doesn't radiate. It's an example of a nonradiative motion.
The moving object also has a quadrupole moment that grows quadratically with time, but this is also nonradiative, since quadrupole radiation is proportional to the third derivative of the moment.
Yes, that's why I said dipole source rather than dipole moment.
The last :smile:
FAQ: Space-Time Warpage and Kinetic Energy
1. What is space-time warpage?
Space-time warpage refers to the bending or distortion of the fabric of space and time caused by the presence of mass and energy. This concept is a key component of Einstein's theory of general relativity.
2. How does space-time warpage affect kinetic energy?
Space-time warpage can affect kinetic energy by altering the path of an object as it moves through space. This can cause changes in the object's speed, direction, and even its mass. It is also believed that space-time warpage can contribute to the phenomenon of time dilation, where time moves at different rates for objects in different locations.
3. Can space-time warpage be measured or observed?
Yes, space-time warpage can be measured and observed through various experiments and observations. For example, the bending of light around massive objects like stars and galaxies is a direct result of space-time warpage. This phenomenon has been confirmed through observations such as the famous 1919 solar eclipse experiment.
4. How does kinetic energy play a role in space-time warpage?
Kinetic energy is a form of energy that is associated with the motion of an object. In the context of space-time warpage, an object's kinetic energy can contribute to the overall mass and energy of a system, which in turn can affect the warping of space and time. Additionally, the energy of an object can also contribute to the curvature of space-time, as described by Einstein's famous equation E=mc².
5. Can space-time warpage be manipulated or controlled?
Currently, there is no known way to manipulate or control space-time warpage. However, some theories and experiments, such as the Alcubierre drive, propose potential methods for manipulating space-time to allow for faster-than-light travel. However, these theories are still highly speculative and have not been proven to be possible in practice.
