Spacecraft Deep Impact - Comet's mass
In summary, on July 4, 2005, the NASA spacecraft Deep Impact impacted Comet Tempel 1, which is about 9.0 km across. Observations showed that dust with a speed as low as 1.0 m/s was able to escape the comet. To calculate the mass of the comet, assuming a spherical shape, you can use the equation V=sqrt((2GM)/r). For part b, you need to determine how far from the comet's center the debris will be when it has lost 70% of its initial kinetic energy at the surface.
treverd
On July 4, 2005, the NASA spacecraft Deep Impact fired a projectile onto the surface of Comet Tempel 1. This comet is about 9.0 {\rm km} across. Observations of surface debris released by the impact showed that dust with a speed as low as 1.0 {\rm m/s} was able to escape the comet.
1)Assuming a spherical shape, what is the mass of this comet? ( The escape speed for an object at the surface of Earth is 11.2 {\rm km/s} ).
2)How far from the comet's center will this debris be when it has lost 70 {\rm \%} of its initial kinetic energy at the surface?
I have absolutely no idea what to do. any help would be appreciated.
I know that for part a it is V=sqrt((2GM)/r)
but then how I calculate the lost kinetic energy.
You know that it is 70% of it's intial value...
1) To calculate the mass of the comet, we can use the formula for escape velocity, which is given by V=sqrt((2GM)/r), where V is the escape velocity, G is the gravitational constant, M is the mass of the comet, and r is the radius of the comet (which is given as 4.5 km, since the comet is 9.0 km across and we are assuming a spherical shape). We can rearrange this equation to solve for M, which gives us M=(V^2*r)/2G. Plugging in the values, we get M=(11.2 km/s)^2*(4.5 km)/(2*6.67*10^-11 N*m^2/kg^2), which gives us a mass of approximately 6.06*10^13 kg for the comet.
2) To calculate the distance from the comet's center at which the debris will have lost 70% of its initial kinetic energy, we can use the formula for kinetic energy, which is given by KE=1/2*m*v^2, where KE is the kinetic energy, m is the mass of the debris, and v is its velocity. We can also use the conservation of energy principle, which states that the initial kinetic energy must equal the final kinetic energy plus the final potential energy. Since the debris is escaping the comet's gravitational field, its final potential energy will be zero. Therefore, we can set the initial kinetic energy equal to the final kinetic energy, and solve for the distance at which the debris will have lost 70% of its initial kinetic energy.
To do this, we can set up the following equation:
1/2*m*(1.0 m/s)^2 = 1/2*m*(v)^2
Where v is the velocity at the distance we are trying to find, and m is the mass of the debris (which we can assume to be the same as the mass of the comet, since the debris is very small compared to the comet). We can then solve for v, which gives us v=sqrt((1.0 m/s)^2*2), which is equal to approximately 1.41 m/s.
Now, we can plug this value for v into the equation for escape velocity, and solve for the distance (r) at which the debris will have lost 70% of its initial kinetic energy. This gives us r=(v^2*r
Related to Spacecraft Deep Impact - Comet's mass
What is the purpose of the Spacecraft Deep Impact mission?
The purpose of the Spacecraft Deep Impact mission is to study the composition and structure of a comet by deliberately crashing a spacecraft into it. This will provide valuable information about the formation of our solar system and the role that comets play in it.
How much mass does the comet targeted by Spacecraft Deep Impact have?
The comet targeted by Spacecraft Deep Impact, named Tempel 1, has an estimated mass of approximately 7.9 billion tons, or 7.2 trillion kilograms.
What type of instrument did the Spacecraft Deep Impact carry to study the comet's mass?
The Spacecraft Deep Impact carried a medium-resolution camera, an infrared spectrometer, and a navigation camera, all of which were used to study the comet's mass and composition.
Why is it important to study the mass of comets?
Studying the mass of comets can provide valuable information about the formation and evolution of our solar system. Comets are made up of materials that have remained relatively unchanged since the beginning of our solar system, so by studying their mass, we can learn more about the conditions and processes that led to the formation of our planets and other celestial bodies.
What were the results of the Spacecraft Deep Impact's impact on the comet?
The impact caused a large crater on the surface of the comet and ejected a large amount of material into space. The data collected by the spacecraft's instruments showed that the comet's mass was primarily made up of ice and dust, with smaller amounts of rock and other materials. This provided valuable insights into the composition and structure of comets, and the role they play in our solar system.
9K
16K
  • Aerospace Engineering
