George Keeling
- 41
This is a refinement of a previous thread (here). I hope I am following correct protocol.
I am studying Spacetime and Geometry : An Introduction to General Relativity by Sean M Carroll and have a question about commutators of vector fields. A vector field on a manifold can be thought of as differential operator which transforms smooth functions to smooth functions on the manifold. For a vector field X and a function f(xi) we write
X(f) = g, where g is another function. We then define the commutator of two fields X and Y as
[X,Y](f) = X(Y(f)) - Y(X(f)
In the exercise I am working on, we are asked to find two vector fields whose commutator does not vanish. An important step is to show that if the commutator vanishes for one non-trivial function f, it vanishes for all non-trivial functions. This is implied by the question but not proven. (f = a constant everywhere would be trivial)
See above
I proved it this way using 'Reductio ad absurdum'.
Our starting point is f is non-trivial and [X,Y](f) = 0. We have another function g is non-trivial and [X,Y](g) ≠ 0.
We already know that commutators are linear (from the previous exercise), so
[X,Y](f + g) = [X,Y](f) + [X,Y](g)
or
[X,Y](f + g) = [X,Y](g)
Therefore f is trivial, which breaks our starting assumption, with which there must be some error. The only non trivial possibility is that [X,Y](g) = 0. QED?
Is my solution correct?
Is there a more obvious solution? (I.e. Am I missing something? See below)
I would like a good definition of 'non-trivial'.
In another thread on Commutator of two vector fields (here), I read "[X,Y] describes how far the endpoints of a rectangle vary if you go along X followed by Y or the other way around. Commuting vector fields mean the two path end at the same point". This does not mention a particular function. I think it supports my conclusion.
See above
or
