Understanding Spacetime in QM and QFT: Time Treatment and Particle Tracking
In summary, the conversation discusses the treatment of time and space in quantum field theory when dealing with particles and fields. It also touches on the difference between quantum mechanics and quantum field theory and the use of operators in QFT.
lucas_
413
23
spacetime is classical and continuous.. so when quantum system form superposition or entanglement, how is time treated esp in qft? how does spacetime keep track of the particles of fields? or how does the fields or particles able to jump in spacetime.. how is this handle in qm or qft?
Spacetime is classical and continuous in relativistic qft.
but particles are connected to spacetime.. how can particles just appear and disappear anywhere in spacetime.. isn't it spacetime are supposed to where particles or fields can move
You should find quite a few discussions around this theme in the "Beyond the Standard Model" section (that is, if you are interested in treatments of spacetime in QFT beyond flat spacetime, not sure if this is the case).
A paper that seems relevant is (copied from the biblio thread there)
http://arxiv.org/abs/1502.06539
Fields as Bodies: a unified presentation of spacetime and internal gauge symmetry
David Wallace
(Submitted on 23 Feb 2015)
Using the parametrised representation of field theory (in which the location in spacetime of a part of a field is itself represented by a map from the base manifold to Minkowski spacetime) I demonstrate that in both local and global cases, internal (Yang-Mills-type) and spacetime (Poincaré) symmetries can be treated precisely on a par, so that gravitational theories may be regarded as gauge theories in a completely standard sense.
for now.. I just want to understand how qft deals with flat spacetime... so when the fields are in superposition, how did they treat the time and space in the equation, as superposition too? or did they untangle or separate the 2 (fields from and spacetime)?
The fields are not in superposition. In quantum theory, the field are observables, so they basically correspond to where classical observers can be in classical spacetime. There is still the quantum state which can be in superposition, and this state is not anywhere in space, but is in Hilbert space, and assigned to an entire surface of simultaneity.
What is the difference between the quantum states in terms of eigenvalues etc between QM and QFT? For example, do we have the same position, momentum, energy? and why does QFT put operator in every point of space instead of values?
Related to Understanding Spacetime in QM and QFT: Time Treatment and Particle Tracking
What is spacetime in quantum mechanics and quantum field theory?
Spacetime is the four-dimensional space that combines the three dimensions of space with the dimension of time. In quantum mechanics and quantum field theory, spacetime is a fundamental concept that describes the location and evolution of particles and fields.
How is time treated in quantum mechanics and quantum field theory?
In quantum mechanics, time is treated as a parameter that is external to the system and does not change. In quantum field theory, time is treated as a dynamic variable that is part of the system and can be affected by interactions between particles and fields.
What is the difference between classical and quantum treatments of time in spacetime?
In classical physics, time is treated as a continuous and absolute variable that flows uniformly. In quantum mechanics and quantum field theory, time is treated as a discrete and relative variable that can be affected by the presence of particles and fields.
How is particle tracking done in quantum mechanics and quantum field theory?
In quantum mechanics, particle tracking is done by solving the Schrödinger equation, which describes the evolution of a quantum system over time. In quantum field theory, particle tracking is done by using Feynman diagrams to calculate the probability amplitudes of different interactions between particles and fields.
What are the implications of understanding spacetime in quantum mechanics and quantum field theory?
Understanding spacetime in quantum mechanics and quantum field theory has several implications, including the ability to accurately describe the behavior of particles and fields at a fundamental level, as well as the potential to reconcile the theories of quantum mechanics and general relativity.
