Spacetime Interval: Is (Δs)2 = (ct)2/γ2 a Coincidence?
  • Thread starter Battlemage!
  • Tags
    Spacetime
In summary: The quantity on the right (square of the distance ##pc##) is also a relativistic invariant. It's the magnitude of the 4-vector that points in the direction of the distance moved.
Battlemage!
294
45
I was messing around with the relativistic energy equation and stumbled upon something that looks like the spacetime interval equation. So, I'm wondering if there is some deeper connection there, or if it's just an interesting coincidence. I'll just go through it really quickly.
E2 = m2c4 + p2c2
m2c4 = E2 - p2c2
m2c4 = (γmc2)2 - (γmu)2c2
m2c4 = (γmc2)2 - (γm Δx/Δt)2c2
Divide all terms by m2γ2
c42 = (c2)2 - (Δx/Δt)2c2
Divide all terms by c2/Δt2
(cΔt)22 = (cΔt)2 - (Δx)2
And that looks suspiciously like the spacetime interval with the (+ - - -) sign convention if (Δs)2 = (cΔt)22.
(Δs)2 = (cΔt)2 - (Δx)2
So the spacetime interval is really (cΔt)22?
Basically it looks like rest mass corresponds to the spacetime interval, energy corresponds to time, momentum corresponds to space, and the spacetime interval is a function of the Lorentz factor: (Δs) ∝ γ-1. (The time and space things makes sense to me since I've seen a proof that conservation of energy is related to time translations and conservation of momentum is related to space translations/rotations).
Is this a coincidence or is there a reason for it?
Thanks!
You are basically reversing one way to derive the relativistic energy equation, the starting point for which is the interval (look up the relativistic four momentum). So yes, you've got back to the interval. Typically you would say that the interval is c times the proper time, ##\Delta\tau##, which is equal to ##\Delta t/\gamma## for constant velocity (which you are assuming). It's probably better to write it using the proper time, since the way you've written it is kind of disguising the interval to look like something frame dependant when it is an invariant.
Likes Battlemage!
Battlemage! said:
E2 = m2c4 + p2c2
Rewrite as
##(mc^2)^2=E^2-(pc)^2##
The quantity on the left (square of the rest energy ##mc^2##) is a relativistic invariant.
##mc^2## is the magnitude of the energy-momentum 4-vector. Energy is the temporal component, momentum is the spatial component.
FAQ: Spacetime Interval: Is (Δs)2 = (ct)2/γ2 a Coincidence?
What is the concept of spacetime interval?
The spacetime interval is a fundamental concept in the theory of relativity that measures the distance between two events in space and time. It takes into account both spatial and temporal dimensions, providing a way to compare the intervals between events for different observers.
How is the spacetime interval calculated?
The spacetime interval is calculated using the formula (Δs)2 = (cΔt)2 - (Δx)2, where c is the speed of light, Δt is the time interval, and Δx is the distance in space. This formula is based on the principles of special relativity and is consistent for all observers, regardless of their relative motion.
What is the significance of (Δs)2 = (ct)2/γ2 in the spacetime interval?
This equation is known as the Minkowski metric and is used to calculate the spacetime interval for events that occur at different points in space and time. The term γ represents the Lorentz factor, which accounts for the effects of time dilation and length contraction in special relativity.
Is (Δs)2 = (ct)2/γ2 a coincidence?
No, the equality of these two equations is not a coincidence. It is a fundamental property of spacetime that has been confirmed by numerous experiments and observations. It serves as a mathematical representation of the relationship between space and time in the theory of relativity.
What are the implications of the spacetime interval for our understanding of the universe?
The concept of spacetime interval has revolutionized our understanding of the universe, particularly in the field of cosmology. It has shown that space and time are not separate entities, but rather interconnected dimensions that are affected by the presence of mass and energy. The spacetime interval also helps explain phenomena such as time dilation and the relativity of simultaneity, which have significant implications for our understanding of the nature of reality.
