- #36
Mortimer
- 142
JesseM said:
I don't see how dt could be an invariant unless you change the definition of dt so it's no longer what's measured on physical clocks. Surely if you pick two physical events and ask observers in different frames to measure the time between them using their own clocks, they will not all get the same answer.
Perhaps its easier to see if written like this:
[tex]c^2=(ds/dt)^2+(dx/dt)^2+(dy/dt)^2+(dz/dt)^2[/tex]
Since [tex]ds=cd\tau[/tex]
this equals:
[tex]c^2=(cd\tau/dt)^2+v_{space}^2[/tex] (1)
[tex]cd\tau/dt[/tex] is the same as [tex]v_{time}[/tex]
which follows from the relations
[tex]v_{time}=\sqrt{c^2-v_{space}^2}=c/\gamma[/tex]
and
[tex]d\tau=dt/\gamma[/tex]
The [tex]c^2[/tex] in (1) is invariant by assumption.
As to your question how to measure the velocity in the time dimension, you see here one possible physical procedure but I prefer another one which is explained http://www.rfjvanlinden171.freeler.nl/dimensionshtml/node2.html. (that saves me a lot of typing in this post)
That text essentially explains that the expression:
should actually be written as:
[tex]c\frac{d\tau/dx_5}{dt/dx_5}[/tex]
which is the ratio between the proper-time-velocity and the time-velocity in a 5D space and generally defines the velocity in the time dimension as
[tex]cd\tau/dx_5[/tex]
(because [tex]dt/dx_5=1[/tex] always)
[tex]t[/tex] is the time as measured by an observer in his own rest frame.
