Length Perception & Spacetime Warp: Is it Warped?
In summary, the question is whether spacetime warping due to a gravity field can also affect the perception of size, specifically in the case of comparing the length of a rod near a black hole with a rod on Earth. However, there are several conceptual difficulties with this question, such as the effects of tidal forces, the method of measurement, and the assumption of a stationary rod. Therefore, there is no unique answer to this question.
Uchida
23
If I make two rods with 1 meter length here on the surface of earth, and send one of them near a black hole that is at rest relative to earth, placing it there with its length alligned in the radial direction of the black hole, would I see the rod close to the black hole with a length shorter than 1 meter, (would the black hole rod be perveived as shorter than the rod here on earth)?
Then, if I go close to the rod near the black hole, would I see it with its original lenght, while the rod on Earth would appear longer than 1 meter?
My question is: does spacetime warp due to gravity field also warp the perception of size?
How exactly are you determining the length of the rod that you’re not close to? Be precise, there are some assumptions hiding in that word “perceive”.
Likes Ibix
There are significant conceptual difficulties with this apparently simple question.
First of all, if the rod is held above the black hole by its top end then it will be under tension and will be stretched. If supported from below it will be compressed. Even if not supported in any way there will be tidal stresses affecting its length. So it would be an apples-to-oranges comparison since, even in Newtonian physics, you would not expect a stressed rod to be the same length as an unstressed one. Perhaps it's possible to accelerate every point on the rod upwards so that it has no internal stresses, at least in principle.
Another issue is how you intend to measure the length of the distant rod. For example, if you just hold a metre rule next to the rod you will find that your meter rule is the same length as your rod (give or take different material reactions to stress). If you view the rod from the side and compare the apparent angular size of the rod as viewed from a distance to a naive ray-optics calculation you will find that the rod is longer than expected, but this is largely due to the curved path of light - a gravitational lensing effect. And if you view the rod end-on and measure its length using radar you will also find that it is longer than a naive calculation, but again this is due to changed light flight times due to Shapiro delay. I haven't done the maths but it would not surprise me if all three of these approaches gave different answers.
I don't think there's a unique answer to this, in short.
Not if the rod is supposed to remain stationary. It's impossible in relativity to have a rod that is stationary and also has constant proper acceleration all along its length.
Thank you sirs for your answers.
Aparently I formulated the question using a too mundane analogy, when all I want is a fundamental answer.
So let me clarifly some assumptions before we can discuss the problem:
  • Let assume that the bar is made with a very high youngs modulus and tensile strength material, so that the stretching/rupture due to tidal forces near the black hole be negligible when compared to the total length of 1 meter.
  • For calculus purposes, one should consider that the rod is "stationary", because the measurement will me made "instantly" at a given moment. (but we know that the rod will be circularly orbiting the black hole.)
  • The distance between the observer and the rod that is far away is known at any given moment, so that at first glance, the length will be measured using apparent angular size from a side view of the rod, not considering gavitational lensing (naive aproach).
  • The mass of the black hole and the distance between the rod that its near it and the black hole center is also known, so that in a second time, the length will still be measured using apparent angula size from a side view of the rod, but considering the influence of the gravitational lensing.
  • The capacity to measure meter-scale lengths over cosmical distances should not be considered a problem, given that this question must be seen as a fundamental problem instead of a engineering one.
You can't assume this. Relativity imposes restrictions on how strong materials can be.
I think you should try and phrase your questions entirely on local physics - how do you compare a rod far away with a rod next to you?
Ok, the rod is an analogy for "linear spatial distance".
Since english is not my native language, I could not find a better way to express my problem.
Let me try to put this question on other words:
Does spacetime distortions near a black hole causes apparent length distortions if measured from a region with flat spacetime?(see image attached as reference)
This is not the sort of question you should be asking in vague ordinary language. You need to ask it in math. You need to be able to say, mathematically, exactly what you mean by "spacetime distortions", exactly what you mean by "apparent length distortions", and exactly what you mean by "measured from a region with flat spacetime".
If you are able to say, mathematically, what all those things mean, I think you will find that your question answers itself. But since there are multiple possible mathematical meanings for all of those terms, there's no way we, who can't read your mind, can tell you which mathematical meaning is the one you intend.
Likes phinds
Related to Length Perception & Spacetime Warp: Is it Warped?
1. What is length perception and how does it relate to spacetime warp?
Length perception refers to how humans perceive the size and distance of objects in their environment. Spacetime warp, on the other hand, is a concept in physics that describes how the fabric of space and time can be distorted by massive objects. The two are related because our perception of length is influenced by the warping of spacetime caused by the presence of massive objects.
2. How does spacetime warp affect our perception of length?
When an object with a large mass, such as a planet or star, is present, it warps the fabric of spacetime around it. This warping can cause light to bend and objects to appear larger or smaller than they actually are. As a result, our perception of length can be distorted when we view objects in the presence of massive objects.
3. Can spacetime warp also affect our perception of time?
Yes, spacetime warp can also affect our perception of time. According to Einstein's theory of general relativity, the warping of spacetime can cause time to pass at different rates in different locations. This is known as time dilation and has been observed in experiments involving atomic clocks placed at different altitudes.
4. Is spacetime warp a proven phenomenon?
Yes, the concept of spacetime warp is a well-established and proven phenomenon in physics. It is a fundamental aspect of Einstein's theory of general relativity, which has been extensively tested and confirmed through various experiments and observations.
5. How does our brain adjust for spacetime warp in our perception of length?
Our brain is constantly processing visual information and making adjustments to our perception. When we view objects in the presence of spacetime warp, our brain takes into account the distortion caused by the warping and adjusts our perception of length accordingly. This allows us to still accurately perceive the size and distance of objects, even in the presence of spacetime warp.
