Spanning Spaces with Linear Combinations
In summary, vectors V and W are linearly dependent and span the same plane, but they are not necessarily in the same direction.
IrinaK.
33
I like Serena said:
Hi Christina! Welcome to MHB! :)
If all vectors are a multiple of each other, they form a line through the origin.
If 2 vectors are independent, that is, not a multiple of each other, they "span" a plane.
If 3 vectors are independent, that is, the 3rd can not be written as the sum of multiples of the other 2 vectors, they "span" all of R3.
Note that if the 3rd vector can be written as the sum of multiples of the other 2 vectors, that vector effectively belongs to the plane those 2 vectors "span".
We say that the 3rd vector is a "linear combination" of the other 2.
Hello!
Christina, thank you for this thread. I also have the same issue.
I like Serena, I would be grateful for your further help.
If given vectors are (1,2,3) and (3,6,9) that have v3 = v1+v2, does it mean that the whole V vector or W vector lies only on XOY plane (two dimensional) and OZ is not applicable, or this is an incorrect assumption? I have just started linear algebra and lack some basic understanding.
Thank you!
Hi,
To solve your problem it would be nice if you could explain the variables you're using. What is v1? v2? v3? V vector? W vector?
Siron said:
Hi,
Siron,
I assume that v1, v2, v3 are for vector V (first one in my example) and vector W is the second one. I didn't think that it is important to state that :)
Hi,
This is my guess of what you want to ask.
You got, two vectors, namely $v=(1,2,3)$ and $w=(3,6,9)$.
They both have $v_{3}=v_{2}+v_{1}$, or using common notation, $z=x+y$.
And you ask if they lie in the plane $XOY$, I understand that this is the plane formed by the $X$ and $Y$ axis, this is $XOY=\{(x,y,z)\in \Bbb{R}^{3} \ : \ z=0\}$.
The answer to this is NO, for being in this plane they should have $z=0$.
But they both lie in the same plane, the plane given by the first equation, which is $\pi =\{(x,y,z)\in \Bbb{R}^{3} \ : \ x+y=z \}$ (Remember that the dimension of a subspace is the dimension of the ambient space minus the number of linearly independent equations used to define the subspace, which in this case is 1).
Furthermore, this doesn't implies that $v,w$ define a plane, actually $w=3v$, it is, they are linearly dependent, so they both define a line. $\langle v,w\rangle=\langle v\rangle $
Hello! Great question. In this case, since v3 can be written as a linear combination of v1 and v2, it means that v3 lies on the same plane as v1 and v2. This plane would be the XOY plane, since the vectors v1 and v2 are in the XOY plane and their sum (v3) would also be in the same plane. However, this does not mean that the entire V or W vector is limited to only the XOY plane. The remaining components of the vectors (z component in this case) can still vary and extend into the OZ direction. This concept is important in linear algebra as it helps us understand how different vectors can span different subspaces within a larger vector space. I hope this helps clarify your understanding. Keep up the good work in your studies!
FAQ: Spanning Spaces with Linear Combinations
What is the concept of "Spanning Spaces with Linear Combinations"?
The concept of "Spanning Spaces with Linear Combinations" is a fundamental idea in linear algebra that involves creating new vectors by combining existing ones using a set of scalars (real numbers). This technique allows us to explore the properties and relationships between vectors in a higher-dimensional space.
How do you determine if a set of vectors spans a space?
To determine if a set of vectors spans a space, we can use the concept of linear independence. If the set of vectors is linearly independent, then it spans the entire space. However, if the set of vectors is linearly dependent, it may only span a subspace of the larger space.
What is the significance of linear combinations in spanning spaces?
Linear combinations are essential in spanning spaces because they allow us to create new vectors by combining existing ones. This means that we can generate an infinite number of vectors within a given space, which helps us understand the properties and behavior of the space.
How can you use linear combinations to solve systems of linear equations?
Linear combinations can be used to solve systems of linear equations by representing each equation as a vector and then creating a linear combination of these vectors. This process allows us to find the values of the variables that satisfy all of the equations simultaneously.
Can linear combinations be used in other areas of mathematics or science?
Yes, linear combinations are widely used in various fields of mathematics and science. They are particularly useful in fields such as physics, where they can be used to describe the behavior of systems and analyze data. They are also used in various computer science applications, such as machine learning and computer graphics.
