Spatial curvature - effect on objects
  • Thread starter nutgeb
  • Tags
    Curvature
In summary, a physical object moving through a spatial curvature gradient (as distinguished from spacetime curvature gradient) will not automatically experience an internally stress-free change in its physical dimensions consistent with the changing background spatial geometry. However, the changing spatial geometry can introduce irresistible internal stresses into the object.
nutgeb
294
My understanding is that a physical object moving through a spatial curvature gradient (as distinguished from spacetime curvature gradient) will not automatically experience an internally stress-free change in its physical dimensions consistent with the changing background spatial geometry. But the changing spatial geometry can introduce irresistible internal stresses in the object.
Consider a VERY large, simple wagon wheel (with rim, spokes and hub) in free fall inward toward the event horizon of a BH. The wagon wheel was originally constructed very far from the BH. It's a supermassive BH, so the tidal effects are not important near the horizon. (Also, assume that the wheel is free falling at much less than the BH's escape velocity.)
As the radial distance from the wheel to the BH decreases, the spatial curvature progressively increases. Increasing spatial curvature causes the proper length of the wheel's spokes to become longer relative to the circumference of the rim; or it can be thought of as causing the circumference of the rim to decrease relative to the length of the spokes. The circumference increasingly becomes [tex]< 2\pi r[/tex].
The wheel's own geometry does not change automatically, in a stress-free way, along with the changing background spatial geometry. However, the changing spatial geometry introduces inexorable internal stresses into the wheel. The wheel was constructed (in essentially flat space) with its circumference equal to [tex]2 \pi[/tex] times its proper radius. But such a [tex]2\pi r[/tex] planar object cannot exist in space that has significantly positively curved geometry. Therefore, stresses will be introduced that cause the wheel's spokes and hub to deform (bend) out of the plane (causing the wheel to become bowl-shaped), or cause the wheel to fragment (break apart). It's like projecting the surface of a globe's hemisphere onto flat paper -- gaps will appear in the circumference.
Conversely, if the wheel originally was constructed near the BH (in highly curved space), and then is moved away from it, its original circumference was [tex]< 2 \pi r[/tex]. Therefore the stresses resulting from the curvature gradient will cause the rim of the wheel to deform out of the plane, or will fragment the wheel. In this case it's like trying to wrap a flat sheet of cardboard around the hemispherical surface of a globe -- there will be extra material at the outer edge of the cardboard that can't lie flat without folding.
Is this description correct?
I should have qualified my examples with the condition that the wheel components are completely inelastic. If on the other hand the wheel components are stretchy/compressible, the wheel's deformation out of the plane, or fragmentation, could be reduced or avoided entirely.
Any Born Rigidity objections to this scenario can be rendered insignificant by disassembling the very large wheel into small pieces near the BH, and then individually moving them away from the BH. When it is later reassembled far from the BH, it will prove impossible to fit the pieces back into the wheel's original shape, due to the fact that the background spatial curvature has changed while the shapes and sizes of the pieces have not.
So no one disagrees with my conclusion, particularly as stated in the quote above?
Related to Spatial curvature - effect on objects
1. What is spatial curvature?
Spatial curvature refers to the curvature of space in the universe, which is a fundamental concept in the theory of general relativity. It describes how the three-dimensional space around us is curved by the presence of massive objects, such as planets, stars, and galaxies.
2. How does spatial curvature affect objects?
Spatial curvature affects objects by causing them to follow curved paths in space. This is because the curvature of space is directly related to the distribution of mass and energy in the universe. Objects with more mass will create a stronger curvature, causing other objects to follow a curved path towards them.
3. How is spatial curvature measured?
Spatial curvature is measured using a mathematical parameter called the curvature constant, which is denoted by the letter k. This constant can take on three values: positive, negative, or zero. A positive value indicates a closed, positively curved universe, while a negative value indicates an open, negatively curved universe. A value of zero indicates a flat universe.
4. What are some observable effects of spatial curvature on objects?
One observable effect of spatial curvature on objects is gravitational lensing, which is the bending of light by massive objects due to the curvature of space. Another effect is the redshift of light from distant galaxies, which is caused by the expansion of the universe and the resulting spatial curvature. Additionally, the distribution of galaxies in the universe can also be affected by spatial curvature.
5. Can spatial curvature be altered or manipulated?
No, spatial curvature is a fundamental property of the universe and cannot be altered or manipulated. It is a result of the distribution of mass and energy in the universe and is an integral part of the theory of general relativity. However, the amount of spatial curvature in the universe can change over time as the universe expands or contracts.
