Zero1010
- 40
- 2
- Homework Statement
- Spatial wave function for two particles
- Relevant Equations
- ##\psi^{+}(x_{1}, x_{2})=\frac{1}{\sqrt2}[\psi_{n}(x_{1})\psi_{k}(x_{2})+\psi_{k}(x_{1})\psi_{n}(x_{2}))##
##V_{A}(x) = \sqrt\frac{2}{L} sin (\frac{\pi x}{L})##
##V_{B}(x) = \sqrt\frac{2}{L} sin (\frac{2\pi x}{L})##
Hi,
I just need someone to check over my work. I am having trouble with the next part of this question and I just wanted to check that this part was correct first.
I have two particles in an infinite square well (walls at x=0 and x=L). I need write an expression for the spatial wave function. From the question I know that the spatial part is symmetric (spin is antisymmetric and the particles are fermions) so will be given by
One of the particles is in the ground state and the other is in the first excited stat. Normalised eigenfunctions given in the question are:
Therefore for the spatial part I have:
##\psi^{+}(x_{1}, x_{2})=\frac{1}{\sqrt2} [\sqrt\frac{2}{L} sin (\frac{\pi x_{1}}{L})\sqrt\frac{2}{L} sin (\frac{2\pi x_{2}}{L}) + \sqrt\frac{2}{L} sin (\frac{2\pi x_{1}}{L}) \sqrt\frac{2}{L} sin (\frac{\pi x_{2}}{L})]##
Which gives the spatial wavefunction:
##\psi^{+}(x_{1}, x_{2})=\frac{1}{\sqrt L} [ sin (\frac{\pi x_{1}}{L}) sin (\frac{2\pi x_{2}}{L}) + sin (\frac{2\pi x_{1}}{L})sin (\frac{\pi x_{2}}{L})]##
Does this make sense or am I missing something? Can I simplify this further?
Thanks in advance for help. This forum has been amazing.
Thanks
Thanks
