Speaking at conferences with partially incorrect results
  • Thread starter hunt_mat
In summary, your supervisor may not be happy with the results of your work, but you should still try to talk to him about it.
hunt_mat
1,798
33
Hi,
I am due to give a half an hour talk at a conference. I have some analytical and some numerical results that I want show. For one part of the work the numerics works fine but there is another part of the work where the general shape (I an computing waves in interfaces) is correct but the but the values at the end points are incorrect.
My quandary is this, do I explain the method, show the results and explain why the results are wrong or do I leave that part out of the talk entirely?
Not too sure if this is the correct forum.
I'd include the results and explain why you think they are incorrect. One reason for presenting that is that you may help someone else that is seeing the same thing, and that would make for a useful Q&A.
That was my thoughts too but I wanted other peoples point of view.
hunt_mat said:
Hi,
Absolutely present *all* the results, especially if you understand *why* the "values at the end points are incorrect" (or even if you have a few good guesses). Other people may be interested in knowing the appropriate limits of your simulation. Never try to conceal something- someone may ask you about those results, and then you are stuck.
Clearly, emphasize the better results, but being able to say (for example) "using this method does not work over here, most likely because of [...], but we think we can extend the region of validity by [...]" is a good thing.
The method should work, this is PhD work I am doing. The field is fluid dynamics, so the numerics should be bang on, the fact that I am not getting the correct boundary values is somewhat embarrassing. I tried to talk to my supervisor but he isn't answering my e-mails.
It probably depends what sort of conference it is, but I think there is a difference between "these results seem to be wrong but I don't understand why" (i.e. they don't match boundary conditions when they should, they don't match experimental data, etc) and
"I know these results are wrong, becaose I made a mistake".
I don't think anybody would have a problem with the first scenario, but there isn't any value in presenting the second. If you do get into that situation, just be honest and say some of your results you intended to present are missing because you discovered an error, but you haven't had time to rerun them before the conference.
Presenting resultswhen you know why they are wrong is at best wastiing everybody's time, and at worst may confuse the message you want to get across about your correct results.
You may be able to include the corrected results in the conference procedings, even though you couldn't present them "live".
As I said, I think that the general shape is correct but that it should be shifted up by a given value.
If it is clearly not correct yet, you can leave your current result out and mention the approach you are using in your outlook section, this might get you some audience response which can help you solve it later on.
Otherwise, you definitely need to talk to your supervisor about this. Don't send emails, calling is the quickest way to get some feedback.
My supervisor is notoriously bad for e-mailing and I don't have his number. hence the request for advice here.
FAQ: Speaking at conferences with partially incorrect results
What are "partially incorrect results" in the context of speaking at conferences?
In this context, partially incorrect results refer to research findings or data that are not entirely accurate or reliable, but may still hold some value or potential insights.
Why would someone want to speak at a conference with partially incorrect results?
While it may seem counterintuitive, speaking at conferences with partially incorrect results can still be beneficial for researchers. It allows for the opportunity to share preliminary findings and gather feedback from other experts in the field, which can ultimately improve the accuracy and validity of the research.
How should one approach presenting partially incorrect results at a conference?
It is important to be transparent and honest about the limitations of the results. Acknowledge and address any potential errors or uncertainties, and provide clear explanations for why the results may be partially incorrect. This can help to maintain credibility and open up opportunities for constructive discussions.
What are some tips for effectively communicating partially incorrect results at a conference?
One tip is to focus on the potential insights or implications that can still be drawn from the results, rather than dwelling on the inaccuracies. Additionally, using visuals such as graphs or charts can help to clearly demonstrate the extent of the error and make the information easier to understand for the audience.
How can one handle potential criticism or skepticism when presenting partially incorrect results at a conference?
It is important to be open to feedback and constructive criticism, and to engage in respectful discussions with those who may have differing opinions. Remember that presenting partially incorrect results is a normal part of the scientific process, and it is ultimately about learning and improving the research.
