Special cases for sine and cosine sum
In summary, the special cases for the formulas when $n = 0, 1,$ and $2$ are that when $n = 0$, the sums for cosine and sine are equal to $1$ and $0$, respectively. When $n = 1$, the sum for cosine can be simplified to $2\cos^{2}\frac{\theta}{2}$ and for sine, it is equal to $\sin\theta$. And when $n = 2$, the sum for cosine can be simplified to $2\sin\left(\frac{3}{2}\theta\right)\cos \frac{ \theta}{2}$ and for sine, it is equal to $2\sin\left(\frac
Dustinsfl
2,281
State the special cases of the above two formulas for $n = 0, 1,$ and $2$.
These should be familiar formulas.
I don't see what is so special and familiar about when n = 2 or for cosine n = 1.When $n = 0$, we have
\sum\limits_{k = 0}^0\cos k\theta = \frac{\sin\left(\frac{\theta}{2}\right)}{\sin\frac{\theta}{2}} = 1
and
\sum\limits_{k = 0}^0\sin k\theta = \frac{\sin\left(\frac{ \theta}{2}\right)}{\sin\frac{ \theta}{2}}\times 0 = 0.
When $n = 1$, we have
\sum\limits_{k = 0}^1\cos k\theta = \frac{\sin\theta}{\sin\frac{ \theta}{2}}\cos\frac{\theta}{2} = \sin\theta\cot\frac{\theta}{2}
and
\sum\limits_{k = 0}^1\sin k\theta = \frac{\sin\theta}{\sin\frac{\theta}{2}}\sin\frac{ \theta}{2} = \sin\theta.
When $n = 2$, we have
\sum\limits_{k = 0}^2\cos k\theta = \frac{\sin\left(\frac{3}{2}\theta\right)}{\sin \frac{ \theta}{2}}\cos\theta
and
\sum\limits_{k = 0}^2\sin k\theta = \frac{\sin\left(\frac{3}{2}\theta\right)}{\sin \frac{ \theta}{2}}\sin\theta.
and
and
and
Hi dwsmith, :)
I don't understand what you meant by the "above two formulas". Is there anything missing here? :)
Kind Regards,
Sudharaka.
It was the formulas for cosine and sine.
$\sum\limits_{k = 0}^n\sin k\theta = \frac{\sin\left(\frac{n + 1}{2}\theta\right)}{\sin\frac{\theta}{2}}\sin\frac{n}{2}\theta$
and
$\sum\limits_{k = 0}^n\cos k\theta = \frac{\sin\left(\frac{n + 1}{2}\theta\right)}{\sin\frac{\theta}{2}}\cos\frac{n}{2}\theta$
and
For \(n=1\) in the cosine summation you can express the result using only a cosine function as,
\[\sum\limits_{k = 0}^1\cos k\theta = \frac{\sin\theta}{\sin\frac{ \theta}{2}}\cos\frac{\theta}{2} = 2\cos^{2}\frac{\theta}{2}\]
Similarly for \(n=2\) in the sine summation,
\[\sum\limits_{k = 0}^2\sin k\theta = \frac{\sin\left(\frac{3}{2}\theta\right)}{\sin \frac{ \theta}{2}}\sin\theta=2\sin\left(\frac{3}{2}\theta\right)\cos \frac{ \theta}{2}\]
Apart from these minor simplifications, I don't see anything further that could be done to the results that you have obtained.
Kind Regards,
Sudharaka.
These are special cases because they represent the sums of cosine and sine functions with a specific number of terms, rather than an infinite number of terms. They are also familiar because they are commonly used in trigonometry and have specific values that are often memorized, such as $\sin\frac{\pi}{2} = 1$ and $\cos\frac{\pi}{2} = 0$.
FAQ: Special cases for sine and cosine sum
What are the special cases for sine and cosine sum?
The special cases for sine and cosine sum are when the angles are multiples of 90 degrees (or π/2 radians), resulting in simplified values for the sum. These values are known as the "special angles" and include 0, 30, 45, 60, and 90 degrees (or 0, π/6, π/4, π/3, and π/2 radians).
How do I use the special cases for sine and cosine sum in trigonometric equations?
The special cases for sine and cosine sum can be used to simplify trigonometric equations involving these functions. For example, if the equation contains sin(45°) and cos(45°), they can be replaced with √2/2, resulting in a simpler equation to solve.
Can the special cases for sine and cosine sum be applied to all trigonometric functions?
No, the special cases for sine and cosine sum only apply to sine and cosine functions. Other trigonometric functions such as tangent, cotangent, secant, and cosecant do not have special cases for sum.
How do the special cases for sine and cosine sum relate to the unit circle?
The special cases for sine and cosine sum can be visualized on the unit circle, where the angles of 0, 30, 45, 60, and 90 degrees (or 0, π/6, π/4, π/3, and π/2 radians) correspond to points on the circle with coordinates (1,0), (√3/2, 1/2), (√2/2, √2/2), (1/2, √3/2), and (0,1), respectively.
Are there any other special cases for sine and cosine sum?
Yes, there are other special cases for sine and cosine sum, including when the angles are negative or larger than 360 degrees (or 2π radians). In these cases, the values for the sum can be found using the periodicity of these trigonometric functions.
