Astrofiend
- 37
OK - the problem is thus:
In an inertial frame two observers (called a & b) travel along the positive x-axis with velocities Va and Vb. They encounter a photon traveling in the opposite x-direction. Without using the Lorentz transformations, show that the ratio of the energies of the photon observed by observers a & b is given by:
[tex]
\frac{E_a}{E_b} = \sqrt{\frac{1+V_a}{1+V_b}.\frac{1-V_b}{1-V_a}}
[/tex]
[tex]
E_o = -p_o.u_o
[/tex]
where E_o is the observed energy of a photon with 4-momentum p_0, by a given observer moving with 4-velocity u_o.
I set up the 4-velocities of observers a & b as:
[tex]
u^\alpha_a = (\gamma_a,\gamma__a V_a ,0,0)
[/tex]
[tex]
u^\alpha_b = (\gamma_b,\gamma__b V_b ,0,0)
[/tex]
and the 4-momentum of the photon as:
[tex]
p^\alpha = (p^t,p^x, 0,0)
[/tex]
With these 4-vectors set up, the energies of the photon for each observer should just be the dot product of each 4-velocity with the negative of the 4-momentum of the photon - i.e:
[tex]
E_o = -p_\alpha .u^\alpha = - \eta_\alpha_\beta p^\alpha .u^\alpha
[/tex]
where [tex] \eta_\alpha_\beta [/tex] is the metric.
so
[tex]
E_a = \gamma_a p_t + \gamma_a V_a p_x \\
[/tex]
[tex]
E_b = \gamma_b p_t + \gamma_b V_b p_x
[/tex]
Then, I used the fact that for a photon,
[tex]
p^\alpha.p^\alpha = 0 \\
[/tex]
[tex]
i.e. -p_t^2+ p_x^2 = 0 \\
[/tex]
so
[tex]
p_t = p_x
[/tex]
and we get:
[tex]E_a = \gamma_a p_t + \gamma_a V_a p_t = \gamma_a p_t (1+V_a) \\
[/tex]
[tex]
E_b = \gamma_b p_t + \gamma_b V_b p_t = \gamma_b p_t (1+V_b) \\
[/tex]
so
[tex]
\frac{E_a}{E_b} = \frac{\sqrt{1-V_b^2}(1+V_a)}{\sqrt{1-V_a^2}(1+V_b)}
[/tex]
...which is where I'm falling down. As I said before, I'm after the relation
[tex]
[/tex]
Can anyone see what I'm doing wrong? Have I made a mistake somewhere, or is there some mathematical trick to take me further from where I am to the required answer? I've stared at this for a while now and can't work out why it's falling down.
Any help would be greatly appreciated.
