Special Relativity and Biological Clocks.
In summary: So, if you used a signal other than light, would you even have time dilation ? Why must all clocks be based on light ?A biological clock surely doesn't use light to keep time, does it ?I think the pedagogical problem is that time dilation, twin paradox and diffential aging is introduced in terms of reference frames and coordinate times. In my opinion one should better start with the proper times of the
siddharth5129
94
Hi.
So the whole premise of special relativity seems to me to be hinged on the immutability of the speed of light, the fact that it is the same for every inertial frame of reference, and the fact that information and energy cannot travel faster than this.
What really puzzles me is this whole traveling forward in time thing. While I can appreciate the use of the twin paradox as a pedagogical device, would a moving frame of reference at a comparable to light speed actually affect how fast a biological system in that frame ages? Has this ever been observed ? Would the living system's biological clock actually slow down relative to an observer on the Earth ? Would his sense of time perception alter to make it feel as if he's spending say 2 years on the shuttlecraft, while his twin back home feels like he's spent 50 waiting for him ?
Special relativity made perfect sense to me until this came along.
From the derivation of the time dilation equation that my textbook shows, the crucial argument seems to me to hinge on the fact that the light ray follows different paths when viewed from one frames of reference or another, and because of the fact that it's speed remains the same, the time measurements must be different. So, if you used a signal other than light, would you even have time dilation ? Why must all clocks be based on light ? A biological clock surely doesn't use light to keep time, does it ?
I think the pedagocial problem is that time dilation, twin paradox and diffential aging is introduced in terms of reference frames and coordinate times. In my opinion one should better start with the proper times of the two observers.
The measuring device for proper time is a co-moving clock, e.g. a wristwatch, or the biological system itself. Starting at the same point in spacetime two observers follow different paths through spacetime and eventuelly meet "some time later" to compare their proper times (wristwatches, greyed hairs, face wrinkles, ...). In this description we avoid the introduction of a "globally valid time", "exchanged light signals" and all that stuff. We do never compare times - unless the two observers meet at the same spacetime point after their journeys.
The question "would the living system's biological clock actually slow down relative to an observer on the Earth ?" becomes irrelevant. Each observer feels his aging as usual. There is no measurable effect. Only after comparing their proper times both agree that something strange happened to them.
The effect can be (and has been!) measured with high accuracy - but unfortunately it's so tiny that it's not observable for biological systems.
Why does light have to be this 'ultimate' signal then ? What if we use sound for all our timekeeping ? Do the postulates of relativity not hold if the signal is mechanical rather than electromagnetic ?
And i'll make my other question more specific then. Would a person who travels for 20 years at light speed, finally arrive at his starting location (assuming that there's no acceleration or deceleration anywhere ) and see that the Earth has aged 448 years ? This would imply that his biological clock has, in some real way, slowed down. What if the timekeeping mechanism in his body is something other than electromagnetic ?
Thanks for all your time :)
siddharth5129 said:
Hi.
Yes.
I don't think anyone has done the long-term experiment described no.
But can you think of any reason a tick on a biological clock should be any different from a tick of an atomic clock? Is biology not subject to physics?
This was actually an historical objection to relativity.
Vitalists etc argued that biological processes are fundamentally different so whatever your wristwatch says, your body has it's own notions of time.
The reason a light signal is used in the thought experiment is to make the physics simple and the concepts clear.
The current state of knowledge is that biological organisms are subject to the same physical laws in the same way as anything else. If it holds for the light-clock, it must hold for all clocks - including biological ones.
But it doesn't hold for sound clocks does it ? If the speed of sound is different in different inertial frames of reference, then sound clocks wouldn't display time dilation ? I say this because the argument in my textbook that derives the time-dilation relation seems to hinge on using a light clock and the fact that the speed of light is the same in both the Earth frame of reference and the train frame of reference. Am i mistaken in saying that that speed of sound is indeed different in both frames of reference because sound is a mechanical wave ? In that case, 'sound' clocks shouldn't display time dilation at all, right? What if the signal is merely a transverse wave on an infinitely long string? If the timekeeping mechanism in the body is electromagnetic, then I have no problem with this argument, but is it ?
It seems to me that not using light would fundamentally alter the physics of the whole problem ? So light must be fundamental in some way (Is it because of the invariance of maxwell's equations under lorentz transformations or something ?) and not just to make the physics simple.
Appreciate all the help. Thanks a ton.
You have to distinguish between aging and exchange of light signals.
Think about the following: instead of exchanging light signals you could exchange the wirstwatches themselves. Unfortunately during the journey of the watch the watch itself ages. So when twin A receives the watch of twin B and compares the two times she can not distinguish between the time interval attributed to her twin's journey and the time interval for the watch after having been sent from B to A.
With light signals this is different: the proper time along a light-like path is always zero!
So in a sense there is no aging of light and one can use it to compare proper times w/o distorting them. That's why one is using light signals when explaining special relativity. But please keep in mind that the effect does not depend on the exchange of light signals. It's a purely geometrical effect, and there's no need to exchange light signals at all.
Aging itself is governed by other physical processes (human cells) and for each macroscopic physical system there are typical time scales w/o any direct reference to speed of light.
You mean near speed of light, not at speed of light.
Yes, this is what could happen (and it's of course possible to take accelerated motion into account)
They do not slow down from the local perspective of one twin observing herself in a mirror during the journey.
I'm sorry. I'm still very confused. What if the twin in the space shuttle bounces a ball to keep time (say there's no air friction ). Since this is a periodic phenomenon, it's a valid way to keep time. But an observer on Earth will record the same time interval for any two events that the observer in the space shuttle records if time is kept in this manner. Hence no time dilation, and no length contraction. This makes absolutely no sense, so what am I missing here ?
I'm sorry, I don't understand at all what you mean by 'aging of light' .
This is not correct - time dilation applies to the bouncy ball method too.
It gets a bit more complicated that the ball's speed is not invariant.
It doesn't matter whether you use a light clock, a bouncing ball, a watch or the biological system itself. During the journey no twin will observe anything special. After the journey they can compare the number of bounces of their balls and will find that they differ - as predicted by special relativity.
What do you mean by "recording a time interval" for these far distant events? How are these time intervals measured? Are you now talking about observing them via light signals?
the shuttle carrying the ball moves at a speed v relative to the Earth observers frame, so after every bounce, the observer on Earth sees the ball moving at a horizontal speed v in addition to the vertical speed it has. So Though the ball follows a longer path as seen from the observer on earth, it also has an additional speed to compensate. So they should both measure the same time interval between bounces. This doesn't happen with light because light has the same speed in both reference frames, and since light follows a longer path when seen from the Earth observer's frame of reference, it should give him a larger time interval between the events registering on a counter. So shouldn't the bouncy ball method give you no time dilation ? Where has my reasoning gone wrong ?
Suppose there's something like a massless wristwatch which could move along a light-like path of a photon. The proper time measured by this watch is always zero. Objects moving at the speed of light have zero proper time.
Attention: please make sure that you understand the difference between proper time (which is a purely local concept and which is exactly the time measured by clocks) and coordinate time (which is a global concept but requires additional assumptions like synchronized clocks located at every point of space). The twin paradox can be described w/o referring to coordinate time at all.
By 'recording a time interval' I mean counting the number of ball bounces.
So you're saying you could derive the time dilation equation by using the bouncy ball method too ? Has this been done anywhere ?
This is not true. In relativistic kinematics it's no longer allowed to add velocities as usual.
http://en.wikipedia.org/wiki/Velocity-addition_formula
Let's say the shuttle moves at speed v in horizontal direction w.r.t. to earth. And let's assume the ball moves at speed w in vertical direction w.r.t. the shuttle. Then you would conclude that the velocity of the ball w.r.t. Earth is described by the vector (v,w). This is wrong! The exact formulas for relativistic addition of velocities can be found in the Wikipedia article.
Thanks. But this assumes that time dilation is true. My concern is with showing that it is true. So, why exactly would the vector quantities not add vectorially as in the galilean sense ? Can we show that they shouldn't add vectorially near light speeds without invoking light clocks ? Can we use regular household pendulum clocks and show that the galilean addition of velocities near light speeds doesn't hold ?
Thanks for all the replies. Really appreciate it.
But that's not the same thing.
Counting the number of bounces certainly measures something invariant. The number of bounces of the ball in the shuttle is the same when observed in the shuttle or when observed from Earth via light signals.
Recording the time interval means that you measure the time between two bounces using an additional watch. You don't need a watch to count bounces.
The time between two bounces of two identical balls (one on Earth and one in the shuttle) is identical - provided that the first ball on Earth is observed by a observer on Earth on a watch located on earth, and provided that the second ball in the shuttle is observed by an observer in the shuttle on a watch located in the shuttle.
The time interval between two bounces of the ball in the shuttle differs when observed a) by an observer on Earth and a watch located on the Earth and b) by an observer in the shuttle on a watch located in the shuttle.
Where' your problem? There's a formal derivation of time dilation which has been confirmed experimentally. At which step do you see problems?
Thanks. That clears up a lot of things for me. I'm just confused about why use light to derive lorentz transformations. Does it have to do with the fact that we 'see' everything? Isn't information available to us via sound as well? Why not use sound to derive everything ? In that case would you conclude that time dilation must happen? I don't see how.
Does this derivation use light clocks? I would just like to see an argument that isn't hinged on the use of light clocks. Could you send me a link where they derive it formally without the use of light clocks ?
The bouncing of a ball is a periodic event. So counting the number of bounces is the same as using a watch is it not? A watch essentially counts a recurring periodic event. So if you say that the number of bounces is invariant, then I have in fact devised a clock which is invariant at near light speeds, have i not ? This is exactly my point, the way i see it, all these arguments seem to be predicated on the mechanism used to measure a time interval. If my mechanism is mechanical ( counting the number of ball bounces ) then time dilation doesn't seem to hold. It seems to hold only when you count light reflections to measure time. I still feel like I'm missing something.
Time dilation is routinely computed via the Lorentz transformation. Here is a link to a derivation of the Lorentz Transform without using light clocks. http://mathpages.com/rr/s1-07/1-07.htm. It is a little more mathematical, you need to know about the determinant of a 2x2 matrix, but not much more than that.
The derivation proper begins about 75% of the way down, starting at the paragraph beginning: "For a typical derivation of the Lorentz transformation in this axiomatic spirit, . . .".
But remember no experiment at all can be used to distinguish an inertial frame from any other, this ball bouncing is an experiment, a mechanical one.
If both obsrvers agreed on the time, you could say which one of them is moving 'absolutely'.
Edit: you can also add that a biological system of course is a physical entity which can be regarded as an experiment, in the same sense the ball bouncing is one.
siddharth5129 said:
Hi.
You might want to think how you'd model "a biological clock".
Is this something that you can measure experimentally, or is it something philosophical, like "do humans experience time in the same way that a clock does" that can'b be decded by experience.
I will say that there isn't any known difference in the measurement of rates of clocks that can be measured (for instance by comparing one clock to a different sort of clock). They all appear to keep the same time, though some are more precise than others. So it would be odd if biological systems were "special" in their notion of time from any known physical phenomenon.
As far as your other questions go, someone in a moving rocketship wouldn't notice anything out of the normal (in any way that could be measured at least), this is one of the principles of relativity - the laws of physics aren't any different in motion, all motion is relative.
If you have a pair of clocks, part of the twin paradox is that which clock is running fast and which is slow depends on how you compare them.
Have you read anything about the relativity of simultaneity? From your questions, I would suspect that perhaps you have not, or have missed something if you have.
I would recommend http://www.aapt.org/doorway/TGRU/articles/Vokos-Simultaneity.pdf, though I'm not sure its necessarily at the right level, hard for me to tell. It's notoriously hard though to communicate the idea of the relativity of simultaneity, and the authors have studied the issue, so I'm hoping their approach will help. The main issue is that the paper is aimed more at instructors, than students.
Lorenz tranformation, time dilation and SR do in no way depend on light, observations using light or anything like that. SR is a purely geometric framework.
Suppose there are no massless photons at all. Suppose we do not have eyes to register photons. Suppose we do not have wristwatches. Suppose we do not even have a concept called "time". Suppose we make the same experiment with two identical bouncing balls, one on Earth and one in the spaceship. Suppose neither twin does ever observe the other twin's ball. All what they are doing is counting bounces. When the spaceship leaves they start counting, when it returnes they stop counting. The twin on Earth counted N bounces during the absence of of the second twin; the twin in the spaceship counted N' bounces during the journey. All what they are doing relies on local facts (bounces, which could be registered acustically, sensors, ...). From N and N' they can derive a concept called proper time: τ and τ', respectively. The number of bounces N and N' differ, and so do the (derived) proper times. The difference τ - τ' agrees with the formula derived from SR. That's time dilation in it's bare form.
Thanks. That derivation seems to intensely mathematical for me, but i shall try to figure it out. So the whole thing can be traced back to the fact that physical laws should be invariant under certain kinds of transformations ?
Yes, unfortunately!
Time dilation should be explained via proper times. The experiment of bouncing balls can be analyzed w/o ever referring to Lorenz transformation. There is absolutely no need to introduce Lorenz transformation b/c this only complicated things more than necessary, and it may be interpreted as a hint that time dilation is a special case of Lorenz transformation - which is not the case.
tom.stoer said:
Yes, unfortunately!
I see where you're coming from, and agree to a certain extent, but the concepts of spacetime interval and proper time emerge directly from the derivation I linked to. That derivation starts from simply addressing the space-time asymmetry of Galiliean relativity, without mentioning the speed of light directly, and the LT, velocity composition and invariance of proper time all emerge naturally.
AIUI to explain things directly via proper time, you need to postulate the spacetime interval (please correct me if I am wrong). For me, this is too far along to accept as a (pedagogical!) starting point. It's a personal preference . . .
I agree to what you are saying. And yes, it's a personal preference ;-)
My intention is to focus on invariant observables (events like bounces, proper times etc.) instead of artificial entities like synchronized clocks, non-invariant properties like coordinate time, Lorentz trf. etc.
Most questions I've seen are due to this historical detours - which I would try to avoid.
Your reasoning is internally consistent and logical - however, it leads to a conclusion that is not true in Nature. This is quite common - there are a lot of pure-reason arguments that are perfectly correct and reasonable and everything but which are not true in Nature.
This is why we use empiricism to figure out what is true in Nature and not pure reason alone.
The equivalent to the bouncy-ball experiment has been done - the "bouncy ball" is usually a metastable atomic state or a nuclear decay or vibrations on a crystal lattice.
If you start out with two bouncy-ball clocks stationary next to each other, and then send one of them off with a twin, then the moving bouncy-ball starts bouncing more slowly according to the twin with the stationary bouncy-ball clock.
Indeed - and you can d it yourself - but it is more difficult because you need to take into account the invarience of the speed of light in some way. This is what your pure-reason approach failed to do.
It is easier to show that the bouncy ball must be subject to time dilation.
You have already said that you accept time dilation as measured by light clocks - as a special property of light clocks or something - so you can use an analysis which compares the bouncy-ball beats to the light-clock ticks.
i.e. say a bouncy-ball clock and a light clock are stationary wrt each other - an observer also stationary wrt to these clocks sees that the bouncy-ball clock has a constant period as measured by the light clock. We can tell time by either one.
Now imagine two of these setups, identical, but moving at a relative velocity of wrt each other.
These setups are, therefore, in inertial frames ... so there should be no way of being able to tell which one is "really" moving. This is just Newtonian physics. All I'll assume here is Newtonian physics and and that time dilation only applies to the special light clocks that were used to derive it.
So there are two observers - and each observer sees the other one as moving. Which means that the other observer's light clock will run slow according to time dilation.
Yet, says your analysis above, the moving bouncy ball-clock still agrees with the stationary one.
Can you see how this is a contradiction?
If I am moving and you are stationary - then you see my light clock run slow but my bouncy-ball still bounces at the same rate as yours. This means that my light-clock runs slow wrt my bouncy ball - so I can see the effect of time dilation - which tells me that I am the one who is really moving.
But in my reference frame, you are the one who is moving. So you must see the same thing ... i.e. you must see your light clock runs slow wrt your bouncy-ball.
If you do not, then we can tell it is me who is "really" moving... which contradicts the initial assumption that the frames are inertial - moving at a constant relative velocity.
All this is cleared up if bouncy-ball clocks keep time with the light clocks.
The experiment is to send a bouncy-ball on a trip ... like I said before, we've done that.
The results agree with special relativity.
Related to Special Relativity and Biological Clocks.
1. What is special relativity?
Special relativity is a theory proposed by Albert Einstein in 1905 that explains the relationship between space and time. It states that the laws of physics are the same for all observers in uniform motion, and the speed of light is constant in all inertial frames of reference.
2. How does special relativity affect biological clocks?
Special relativity predicts that time is not absolute and can be affected by factors such as velocity and gravitational fields. This means that biological clocks, which are based on the regularity of natural processes, can be influenced by these factors and may run at different rates for different observers.
3. Can special relativity explain time dilation in living organisms?
Yes, special relativity can explain time dilation in living organisms. Time dilation is the phenomenon where time runs slower for an object in motion compared to an object at rest. This has been observed in experiments with atomic clocks on airplanes and satellites, and it has been shown to also occur in living organisms.
4. How does special relativity impact the aging process?
Special relativity predicts that time runs slower for objects in motion, which means that a person traveling at high speeds will age slower than someone at rest. However, this effect is only significant at speeds close to the speed of light, so it does not have a noticeable impact on the aging process for humans.
5. Can special relativity explain why time seems to pass faster as we get older?
No, special relativity cannot fully explain why time seems to pass faster as we get older. This is because special relativity only applies to objects in motion, and our perception of time passing faster as we age is likely due to psychological and physiological factors rather than physical laws.
