Special Relativity and Entanglement
In summary, the conversation discusses the implications of Special Relativity on Entanglement and the difficulty in determining which measurement of an entangled photon caused its wave collapse. The Copenhagen Interpretation and Many Worlds Interpretation are mentioned as potential explanations, with MWI offering a solution by eliminating the concept of wave function collapse.
  • #36
DevilsAvocado said:
... or do I need the salvation of higher powers to make it work ...?
This "salvation of higher powers" sounds like it might come in handy. Where can I download that? I think I might need it. :wink:
  • #37
DevilsAvocado said:
Sure, if you just give me a link to that silly little time machine of yours, I'll install it right away.
I can't do this for license reasons; I only have a confidential alpha version (and, understandably, it is still full of bugs).
I suggest you simply wait...
  • #38
Seek and ye shall find.
(There are a lot of 'buggy' homepages out there ... with mighty alpha versions etc ... :wink:)
  • #39
Okay. :zzz:
  • #40
Have you ever been walking down a pavement (sidewalk :wink:) and you see someone coming the other way and being polite you step to one side to give way to the other person ... but they do exactly the same thing and you are still on collision course? Sometimes this even happens multiple times in the same interaction.:eek: Well in the context of the OP with both entangled particles, there is a similar problem if both particles are detected *exactly* at the same time. Which particle "gives way"? Now the walking down the pavement problem does not usually happen with vehicles on the highway or ships at sea because there are "rules of the road or sea" to prevent this happening, like always give way on the right or always give way to the larger slower moving ship, etc. So *maybe* there are rules of the road for quantum particles? I am not proposing a new theory, just discussing some "visualisations" as an aid to discussions on how people see things.
Lets say, that one of a pair of entangled particles has some sort of "priority" so that there is a sort of master and slave arrangement and that the master is selected at random at the creation of the entangled pair. For example if we have of pair of circularly polarised photons, they have opposite polarisation, so one will have the vertical component of its wave a 1/4 wavelength ahead of its horizontal component while the other will have its vertical component 1/4 wavelength behind its horizontal component, so this is one way that a master particle can be determined without introducing any new hidden variables. Now if in one frame the particles are detected at widely separated locations simultaneously, there there can be found a reference frame in which the master photon is detected later than the slave photon. This requires that in that reference frame, the master photon would have to communicate backwards in time with the slave photon. This seems to create a problem because how is a master photon to determine whether to communicate forwards in time or backwards in time to the slave? One possible solution is to consider LET which is widely acknowledged to be fully compatible with SR in its predictions. In LET the Lorentz Ether is absolute and is the fixed (but undetectable) background that everything moves relative to. Now if the master photon transmits its sub quantum signals instantaneously in the Lorentz Ether reference frame, then this signal will be correctly transformed to the required future or past going direction under a standard Lorentz transformation so that the master photon requires no "knowledge" of whether to transits forwards or backwards or time, because the Lorentz transformations of LET (and SR) correctly handle all that. This is not a formal discussion, but since this thread seems to have stalled somewhat, I thought I would put some ideas out there to revitalise discussion.
Please note that I am not in any way suggesting that the "communications" between entangled particles can in any way be used to send information or matter super-luminally and forwards or backwards in time at the macro or human level. That is demonstrably not the case.
  • #41
yuiop said:
If each time Bob tosses a coin the universe splits into two universes, one where Bob got a head and one where he got a tail, then after 100 coin tosses there will be 2^(100) = 1.267E30 new universes. MWI is not very economical on resources. :smile.
This doesn't matter since only one of them is real. Quantum fantasies are extremely cheap. You should spend your energies on more worthwhile subjects!
  • #42
thenewmans said:
At a philosophical level, I understand that QM must break some classic principal we hold dear. But why must local realism be the most common victim? I get the feeling it's a popular whipping boy simply out of some lack of knowledge. It seems to me like an unnecessary assumption.
Bell's proof demonstrated mathematically that it is impossible for any theory with properties that correspond to what physicists mean by "local realist" to replicate the predictions of QM (the properties are defined more precisely in the proof, but basically any theory where your description of the world can be broken down into a set of local facts, and the local facts at any given point in spacetime depend only on other facts in the past light cone of that point).
  • #43
DevilsAvocado said:
You should also ask K^2 this question: In MWI, when there’s a 50/50 outcome both always gets 'materialized' in different branches (worlds). Now, if you toss a coin a 100 times you expect to get approx 50 heads & tails, right?
But in one of these MWI branches some poor bastard will always get 100 tails, every time he performs this 'experiment'!
What is K^2’s advice to this guy? Just forget about it?? Or rewrite all laws on probability?? Or just show the "MWI-sign" if anybody ask 'difficult' questions??
:smile:
Similarly, if the universe is infinite in spatial extent, then for any given experiment there are going to be an infinite number of planets where that experiment is performed (including an infinite number where its performed by people who at the moment the experiment started were exact physical duplicates of the experimenter over here), and the law of large numbers says that some small fraction will get anomalous results like 100 tails in a row. Do you think this is a proof that the universe must be finite, and if not, do you think this forces us to "rewrite all laws on probability"?
  • #44
Yeah, I realize now that I mean just localism. Not both. I guess what I mean is that when the wave collapses (or when the worlds divide), if you say something happens instantly over a distance, it sounds to me like you're giving up on SR and localism instead of some other principle like realism or counterfactual definiteness.
  • #45
yuiop said:
MWI is not very economical on resources. :smile:
I hear you! :smile: And we’re just discussion one silly little coin... On the other hand... if you calculate the lighting fast and enormous huge "WMI revenue" from tossing a single coin?? Man! If we just could find "the door" to those branches – we would be billionaires!o:)
(sorry, silly joke :blushing:)
yuiop said:
If the experiment is repeated there is a 1/2(100) chance that the Bob that got 100 tails the first time around will get 100 tails the second time around which is (very) far from saying that the same Bob will get 100 tails every time the experiment is carried out.
True. But as long as there’s the smallest chance, there will always be an extremist 'left-wing' and 'right-wing' -Bob on the binary tree, which has the "worst luck" in the whole "MWI universe"... :cry: (:wink:)
  • #46
Jesse, I know you master these matters much better than me. I’m basically a "fruitcake", fond of asking 'exasperating' questions :smile:. Hope you get picture and enjoy 'play along'...
First ('exasperating') question:
How do you split (branch) an infinite universe in finite time?
Second question:
I get that in an infinite universe "strange things" ought to happen "all the time" – like http://en.wikipedia.org/wiki/Boltzmann_brain" . I also get that the probability for Bob tossing 100 tails in a row in our "local universe", is extremely small.
Now, there is always gazillions of "tossing" going on in our "local universe" – why do we never see any sign of this weirdness "here"!? I mean, of all the probabilities that’s out there – everyone seems to cluster around the mean value in the probability distribution. Why are the no Boltzmann brains, or Bob-100-tails in our "local universe", or anything else that’s totally nuts? Not one thing?? :eek:
Okay, the "http://en.wikipedia.org/wiki/Wow!_signal" " looks strange, I admit that, but surely there should be a lot more 'bizarre stuff' going on, shouldn’t it...??
Third question:
If you 'believe' in MWI – why do you struggle with EPR-Bell? Doesn’t MWI remove all 'questions' regarding EPR-Bell?
  • #47
I tried that question earlier here on PF, and 'extended' it to having the two photons going parallel (heavily isolated of course ;) to the apparatus – to 'enforce' simultaneous decoherence, at *exactly* the same time!
And the answer was HUP, Heisenberg will not give us the precision needed to measure one single photon... if I remember it right... :rolleyes:
In fact I think this is the case... the photons are called the "signal" and "idler", for historical reasons, but I don’t think there’s any real difference between them though...
[PLAIN]http://qixote.org/research/hqpdc/pdc.png
And the 'magic' happens where the beams intersect:
[URL]http://www.tongue-twister.net/mr/physics/photons.jpg[/URL]
DrC knows all about this.
Yes, and besides SR and the "FTL wall" we have the QM No-communication theorem:
[PLAIN said:
http://en.wikipedia.org/wiki/No-communication_theorem]No-communication[/PLAIN] theorem
In quantum information theory, a no-communication theorem is a result which gives conditions under which instantaneous transfer of information between two observers is impossible. These results can be applied to understand the so-called paradoxes in quantum mechanics such as the EPR paradox or violations of local realism obtained in tests of Bell's theorem. In these experiments, the no-communication theorem shows that failure of local realism does not lead to what could be referred to as "spooky communication at a distance" (in analogy with Einstein's labeling of quantum entanglement as "spooky action at a distance").
If we put MWI aside for a moment; you can use any argument you want on the 'nature' of the QM state before measurement like; foliation, dBB quantum equilibrium, or any 'fancy stuff' – when the wavefunction/photon has ended the 'journey' it hits the detector and becomes 'real', a 'click' in the apparatus. As far as I understand it’s very hard to squeeze this apparatus back to the microscopic 'QM world'. It’s macroscopic and it’s real and we can use our eyes to see the 'click' when it happens, in the domains of SR.
As concluded before – it’s normal for two observers in SR to disagree on whether events separated in space are simultaneous, or A before B, or B before A – it’s all relative to the frame of reference: http://en.wikipedia.org/wiki/Relativity_of_simultaneity"
"Einstein included two lightnings striking both ends of the train simultaneously, in the stationary observer's inertial frame. In this experiment, moving observer would conclude that the two lightning events were not simultaneous."
http://upload.wikimedia.org/wikipedia/commons/9/96/Einstein_train_relativity_of_simultaneity.png"
Now imagine that Mr. Green and Mr. Blue performed an EPR-Bell experiment... and instead of lightnings hitting the two observers, there’s measuring apparatus for entangled photons...
I hope you get 'the picture'... :rolleyes:
  • #48
I don't really understand the question--what does the spatial extent of the universe have to do with the time of splitting? And I think "splitting" is only an approximate notion, though the question of what it means to talk of different "worlds" in the MWI is one I don't fully understand.
DevilsAvocado said:
Second question:
I dunno, isn't that kind of like asking "why is it always someone else, not me, who wins tens of millions of dollars in lottery jackpots"? Obviously it could be you, but the fact that tens of millions of people play and only one or two win these huge jackpots seems to make it "natural" to expect you're probably not going to be the winner. Perhaps you could think of it in terms of the self-sampling assumption, a type of anthropic reasoning which says if there are a large number of observers in some class you also belong to, you should reason as if your place had been "randomly selected" from the set of all observers--for example, if I am part of an experiment where I know 100 subjects were given a certain medication while 50 subjects were given a placebo, but I don't know which group I'm in, I should assume there is double the chance that I was given the medication than the chance I was given the placebo. For more on the logic of the self-sampling assumption, see the website of philosopher Nick Bostrom, anthropic-principle.com.
DevilsAvocado said:
Third question:
I don't know that I "believe" it although from what I understand of the different interpretations it seems most elegant and plausible to me. And I don't know if I'd say I "struggle" with EPR-Bell, although I find it interesting...I would say that although the MWI gives me a general idea of how one could explain EPR in a "local" way, I don't understand the issue of the derivation of probabilities and the "splitting" of different "worlds" well enough to say that the MWI in its current form gives a definitive solution.
  • #49
Yes, I agree that it seems preferable to have a local explanation...I don't know if the assumption that there is only one result for each experimenter counts as "realism", so that the many-worlds interpretation is non-"realist", or if the MWI must be seen as a separate loophole, but I think at least in principle some variant of the MWI could explain the results in a purely local way, see the simple "toy model" I wrote up in [post=1557143]this post[/post].
  • #50
thenewmans said:
DevilsAvocado, thank you for helping me with this. Where would we all be without DrChinese? I hope he feels the appreciation.
You have said a key phrase for me here. Sometimes I hear myself saying something similar and I feel as if I'm painting myself into a corner. And this is the essence of my original post. It seems to me that your statement implies things like a direction, simultaneity and a preferred inertial frame of reference. From an SR point of view, describing events usually requires selecting an inertial frame of reference. But changing that frame does not change what actually happened. In other words, if someone travels past Alice at 95% C just as Alice measures the photon, does that “something” (wave collapse?) travel FTL from his point of view as well? As I follow this line of reasoning, it only gets worse.
Now this may be derived from my mis guided interpretation of QM and will probably label me the nut-case of the forum, however i also think that there must be something happening that is faster then light. But i don't think that its a signal or anything else that is traveling in a straight line connecting the two entangled parts. We have observed that electrons have the ability to (in layman's terms) blink in and out and "disappear". We see the world as three dimensions but what if there really was a 4th (or 11 if you buy into that theory as well) and the electrons were disappearing out of our 3 dimensional sight and bypassing space time to make the change. I always think of it like seeing two particles on a piece of paper. One on the top of the paper and the other on the bottom. The fastest way to connect the two particles is not to make a straight line between them but to fold the paper in half so that they are touching. ( does this make me crazy??)
  • #51
Yes, you’re completely loony. But, you’re in good company. I think of things like this on occasion that I don’t post simply because I’d rather not assume a particular interpretation or untestable theory. I’ve heard of fundamental particles blinking in and out but I’ve never looked into it. I’ve always assumed that means its location is not actually known or that the conservation of mass and energy would prevent that. So if an electron blinks out, a gamma ray would be left behind. It’s more likely for an electron and an anti-electron (called a positron) to collide and 2 gamma ray pop out. This maintains the law of conservation. It’s like E=MC^2. This is part of how PET scans work.
Now here’s another fun idea for cooking your noodle. Ever since Dirac predicted positrons, physicists have theorized that they are actually electrons moving backwards through time. And that may be the case with all anti-particles. Photons and other force carriers (energy) have no anti-particles.
I have this idea kicking around in my head that I have yet to admit. I keep thinking that there’s some component of photons that moves backwards in time along the photon’s path carrying the measurement back to the source. Perhaps it’s not the measurement but the spin. I don’t know. In the case of entangled photons, the spin gets set at the source so that both photons always have the correct spin. This avoids the problem of hidden variables since the spin is still affected by the measurements. In some way, this explains the double-slit experiment as well. So you’re not the only crazy one here.
  • #52
So basically what i am getting out of this is that I AM in fact crazy like everyone else who buys into this QM stuff but am only one of the few that are just crazy enough to actually write down our preposterous ideas?
  • #53
To be honest, I’ve seen your idea discussed here before. I don’t recall how the discussion went. So I hope someone more knowledgeable than I replies to your post. And most members post far out ideas on occasion, even the ones with little honor badges. It’s all part of the fun.
