Special relativity and photons
In summary: Because those are not the same as the Lorentz transform.In summary, the postulate of special relativity states that the speed of light in a vacuum is the same for all observers. This means that special relativity can only be applied to observers who conform to this condition, otherwise the postulate may be violated. Some people may use equations from special relativity to describe photons as "timeless" and having no space to travel through, but this is not accurate as there is no frame of reference for a photon. The energy equation for a photon does not require a frame of reference, as it is describing measurements made by an observer. The Lorentz transform, on the other hand, does require a frame of reference and
ViolentCorpse
190
Hello everyone!
There is a postulate of special relativity that says that the speed of light in vacuum is the same for all observers. This seems to imply (to me) that all the results of special relativity must only be used when dealing with observers who conform to the condition set by the postulate. If we don't keep this in mind, we run the risk of violating the postulate. So it confuses me when experts and non-experts alike use the equations of time dilation, length contraction etc. to assert that photons are "timeless" and have no space to travel through (it's contracted to 0).
Not only do I find it hard to imagine photons with such strange characteristics, I think (with every possibility of being wrong) that it is wrong to apply these results to something that doesn't even conform to the core postulate of relativity (for the speed of a photon in its own frame cannot be c and must be zero). But I'm only an unqualified amateur in physics and have no reason to trust my thinking enough to believe it, so I come here to ask, is it correct to apply these results to a photon? Why?
Thank you very much!
Photons are "timeless" only in the sense that "time relative to a photon" is undefined (rather than zero).
See our FAQ: Rest frame of a photon.
Likes 1 person
Violent, to restate DrGreg's correct response slightly differently, there IS no "its own frame of reference" for a photon so talking as though there is is pointless. In essence, that is exactly what you said. You came to the correct conclusion that there is no point in talking about a photon as though it had a frame of reference.
Likes 1 person
Thank you for the clarification, phinds!
There's one more thing I'd like to ask. We can use the relativistic energy equation to arrive at the result E=pc for a photon. Does deriving this result not require that the photon have an inertial frame of reference?
Thanks again!
E = pc is in your frame not the undefined photon frame.
There are some equations here which give additional perspectives:
http://en.wikipedia.org/wiki/Photon_energy#Physical_properties
This one, E = hc/λ, shows how the observed energy varies with observed wavelength ...as an observer [edit: moves] towards a light source it appears frequency shifted...
Likes 1 person
No. The ##E^2=(m_0c^2)^2 + (pc)^2## relationship describes measurements by an observer, whether inertial or not, of an object that is moving (possibly with ##v=p=0##, in which case we'd say that the object is at rest) relative to him.
Likes 1 person
Don't the time dilation and length contraction relationships too describe measurements of another frame by an observer's frame?
Not quite, because that bolded phrase above doesn't quite make sense - there's no such thing as "measurements of a frame". We measure actual physical quantities, and the time dilation and length contraction relationships tell us how one observer's measurements of these quantities are related to those of another observer who may be in motion relative to the first observer.
More generally: objects don't "have" frames, nor are they "in" frames. Frames are chosen by observers to make sense of their observations; observers generally choose to think in terms of the frames in which they are at rest.
I see Nugatory posted while I was composing...
I agree with his clarification. The Lorentz transform [with length contraction and time dilation] does convert the labels of all events [observations] as calculated in one frame to those as calculated in another frame. However, the transform applicability is limited to massive particles...those with speeds less than c and is also limited to flat spacetime...no curvature, no gravity.
Ah. And since no such transform is associated with the energy relationships, they're consistent with the postulates of SR. Right?
Nugatory: Thank you for clarifying it, but I happen to know that much. I apologize for my poorly-worded post. I should've been more exact. I was in fact trying to ask how is it that measurements involving Lorentz transforms made on a photon require a well-defined frame of reference of photons whereas the energy measurements don't, since neither class of measurements are being made in the undefined frame of the photon.
Thank you, once again, for your extremely helpful responses, people! :smile:
They do not. It's the observer who needs a frame of reference, not the observed - whether it's a photon or not.
Now I'm finding myself wondering... when you wrote "Lorentz transforms" above did you mean "the time dilation and length contraction formulas"?
Likes 1 person
Yes, that's what I meant.
jtbell said:
The familiar time dilation and length contraction equations are not the Lorentz transformation equations.
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/ltrans.html#c2
What jtbell said.
Furthermore, if you want to understand relativity, you cannot start with the time dilation and length contraction formulas. You have to understand the Lorentz transformations first (and then you can use them to derive the time dilation and length contraction formulas if you want - it's a good exercise).
Likes 1 person
Even though you can derive length contraction and time dilation from the Lorentz transformation, they're not the "whole story." The LT also includes relativity of simultaneity, which is just as important as the other two phenomena.
Taken together, the set of three:
  • Length contraction
  • Time dilation
  • Relativity of simultaneity
are equivalent to the Lorentz transformation, in physical content.
Likes 1 person
Thank you everyone!
Related to Special relativity and photons
1. What is special relativity?
Special relativity is a theory developed by Albert Einstein that explains the relationship between space and time, and how they are affected by the motion of objects. It is based on two main principles: the principle of relativity, which states that the laws of physics are the same for all observers in uniform motion, and the principle of the constancy of the speed of light, which states that the speed of light is the same for all observers regardless of their relative motion.
2. What is the role of photons in special relativity?
Photons are particles of light that play a central role in special relativity. According to Einstein's theory, the speed of light is constant and the same for all observers, regardless of their relative motion. Photons, being particles of light, always travel at this constant speed, which helps to explain many of the phenomena observed in special relativity.
3. How does time dilation affect photons?
Time dilation is a phenomenon predicted by special relativity in which time appears to pass slower for objects in motion. This means that as an observer moves faster, time will appear to be passing slower for them compared to a stationary observer. Since photons travel at the speed of light, time dilation does not affect them. This is because time dilation only occurs at speeds that are a significant fraction of the speed of light, and since photons always travel at the speed of light, time dilation does not apply to them.
4. Can photons have mass?
According to special relativity, photons are considered to be massless particles. This means that they do not have rest mass, which is the mass of an object when it is at rest. However, photons do have energy and momentum, and their energy is directly proportional to their frequency. This concept is captured in Einstein's famous equation, E=mc², which relates mass and energy.
5. What is the significance of the speed of light in special relativity?
The speed of light plays a crucial role in special relativity. It is considered to be the universal speed limit, as nothing can travel faster than the speed of light. This means that the speed of light is the maximum speed at which information can be transmitted, and it also affects how time and space are perceived by observers in motion. The constancy of the speed of light is one of the fundamental principles of special relativity and has been confirmed by numerous experiments.
