Special Relativity - Events and Frames of Reference
In summary, the conversation discusses the concept of events and frames of reference in relation to special relativity. The main question is whether an event occurring at a specific point in one frame of reference would be fixed at the same point in another frame of reference. The participants also discuss the need to think "relatively" and offer tips for understanding special relativity intuitively. The conversation concludes with a discussion about a hypothetical scenario involving lightning strikes on a moving train and how different frames of reference would measure the distance between the strikes.
Pezz
Hello everyone :). I'm new here and wasn't sure where to post my physics question so here I am in the homework help section as my question is homework related...
The problem I'm having is of very basic nature however I might have some trouble wording it. I understand an event is something that happens independent of frame of reference. Let's say we have two frames S and S' with a relative speed of v along the x axis. If an event occurs at some point x, and we figure out x', when looking separately at each frame of reference the event would be at a fixed point in each frame correct? I mean if S is looking at S' and an event occurs at x = 10, S sees S' moving toward the event. When we figure out x' for S', would the event be fixed in that frame at x' or would there be any movement between the frame and the event in the S' frame... I hope I got across my question and thank you in advance for any attempts at an answer :P...
Welcome to PF;
The trick here is to be very careful about your wording.
Events do not occur only at a particular position, but also at a particular time.
The event that something occurs a distance x from S (the S-frame observer) also occurs at time t.
S' is moving towards x.
According to S', the event occurs at position x' and at time t', and S is moving away from x'.
The point x is stationary in S and x' is stationary in S' - the cause of the event need not be stationary in either.
Later you will be using the word "event" to mean the point in space-time rather than the thing that happens there ... the thing that happens just becomes a handy label for the point.
Every frame can assign specific coordinates to the event, sure. Everyone has a birthday in every system ;).
Thanks for the responses, it clears some stuff up.
I think I'm overthinking the whole thing but it's only been a week since I've been introduced to all of these concepts of length contraction, time dilation etc. I hope it becomes clearer with time, I guess I'm just not used to thinking "relatively". I've lived all my life thinking in Galilean transformations haha...
Are there any tips that you guys could give me in how to approach this whole thing. I want to understand the equations and the concepts from a more intuitive standpoint. I know how to formally derive the Lorentz transformation equations and use them, but I wish to actually understand them and the whole concept of special relativity intuitively.
You basically have to get used to it by doing examples.
There was a time when Galilean relativity and vectors were wierd.
You may like to try: http://www.physicsguy.com/ftl/html/FTL_intro.html
... that's just the intro - there are 4 parts which concentrate on the concepts and how they fit.
Thanks for the link. I will definitely start reading it tomorrow as it's getting late here and I'm about to go to sleep. Before I go off, I thought of one thing that doesn't make sense to me and I know that there is an error in my thought process but I just can't seem to find it...
Say a lightning bolt strikes at x in the S frame, and x just happens to be a location on top of a very fast moving train with an observer S' inside of it. Observer S determines that the distance between the mark the lightning bolt leaves and the observer S' is a distance d. Using Lorentz transformations we would get an x' that is larger than d. Shouldn't x' = d? Would S' see the lightning bolt hit a different part of the train?
The only answer I can think of is that S sees the train as shorter and thus measures a shorter distance...
If the train is stationary in S', then it is moving in S.
A way to make the situation clear is to say that there are two lightning strikes, one at each end of the train, and they strike so that they leave a burn mark on the train, and also on the tracks.
The key to understanding what each party measures is to realize that events which are simultaneous in one frame are not simultaneous in all frames.
The reading I gave you covers several such situations.
Related to Special Relativity - Events and Frames of Reference
What is special relativity?
Special relativity is a theory developed by Albert Einstein that describes the relationship between space and time. It explains how physical laws and measurements appear the same to all observers in uniform motion, regardless of their relative velocities.
What is an event in special relativity?
An event in special relativity refers to a specific point in space and time, such as the location and time of a lightning strike. It is important in this theory because different observers may perceive the same event differently, depending on their relative motion.
What is a frame of reference in special relativity?
A frame of reference in special relativity is a coordinate system used to measure and describe the motion of objects. Each observer has their own frame of reference, and different frames of reference can result in different measurements of space and time.
How does special relativity challenge Newton's laws of motion?
Special relativity challenges Newton's laws of motion by introducing the concept of time dilation and length contraction, which change the way we perceive space and time in relation to objects in motion. It also shows that the laws of physics are the same for all observers in uniform motion, regardless of their relative velocities.
What are the implications of special relativity?
Special relativity has many implications, including the famous equation E=mc^2, which shows the relationship between energy and mass. It also explains the phenomenon of time dilation, which has been confirmed through experiments with high-speed particles. Additionally, it has led to the development of other theories, such as general relativity, which describes gravity and the curvature of space-time.
