Special Relativity Force and Linearization
In summary, the conversation discusses a particle moving close to the speed of light and being subjected to a first order perturbation. The main difficulty lies in linearizing the equation of motion, which involves expanding \gamma and its derivative in powers of the velocity.
zachzach
258
Consider a particle moving at close to the speed of light with [tex]v \approx c \ \hat{z}[/tex]. A small oscillatory force [tex]F(t)[/tex] acts on the particle. Consider [tex]F(t)[/tex] to be a first order (eg. linear) perturbation which will not effect [tex]v_o[/tex], only [tex]v_1[/tex], the first order component of v. Linearize the equation of motion and find the acceleration when [tex]F(t)[/tex] is perpendicular and when [tex]F(t)[/tex] is parallel to [tex]v_o[/tex].
[tex] \vec{F}(t) = \dfrac{d}{dt}(\gamma m \vec{v})[/tex]
My trouble is with linearizing the equation.
[tex] \vec{F} = m\vec{v} \dfrac{d \gamma}{dt} + m \gamma \dfrac{d\vec{v}}{dt}[/tex]
Then linearize each term so:
[tex]\vec{v} \dfrac{d \gamma}{dt} = \vec{v}_o\dot{\gamma}_o + \dfrac{d}{d \vec{v}} [\vec{v}\dot{\gamma} ] \mid_{\vec{v}= {\vec{v}_o, \dot{\gamma}= \dot{\gamma_o}}}(\vec{v} - \vec{v}_o) + \dfrac{d}{d \dot{\gamma}}[\vec{v} \dot{\gamma}] \mid_{\vec{v}= {\vec{v}_o,\dot{ \gamma}= \dot{\gamma}_o}} (\dot{\gamma} - \dot{\gamma}_o) = \vec{v}_o\dot{\gamma_o} +\dot{\gamma}_o (\vec{v} - \vec{v}_o) + \vec{v}_o(\dot{\gamma} - \dot{\gamma_o})[/tex]
And then do the next term similarly. Is this the correct way to linearize?
You also need to expand [tex]\gamma[/tex] (and its derivative) in powers of the velocity.
Related to Special Relativity Force and Linearization
What is Special Relativity Force?
Special Relativity Force is a concept in physics that explains how objects with mass interact with each other through the exchange of energy and momentum. It is a fundamental force that is described by the theory of Special Relativity, which was developed by Albert Einstein in the early 20th century.
What is the difference between Special Relativity Force and other forces?
Special Relativity Force is different from other forces, such as gravity or electromagnetism, because it is a fundamental force that is seen as the underlying cause of all other forces. It is also unique in that it is the only force that can act at a distance, meaning that objects do not have to be in direct contact for the force to be exerted.
What is Linearization in Special Relativity Force?
Linearization in Special Relativity Force refers to the process of simplifying complex equations and concepts in order to make them more manageable and easier to understand. In the context of Special Relativity, linearization is often used to approximate the behavior of objects moving at speeds close to the speed of light, which can be difficult to calculate using the full equations of the theory.
How does Special Relativity Force affect time and space?
Special Relativity Force has a significant impact on the concept of time and space. According to the theory, time and space are relative and can change depending on an observer's perspective and relative motion. This means that time can pass at different rates for different observers and that distances can appear to be different depending on the observer's frame of reference.
What are some practical applications of Special Relativity Force?
Special Relativity Force has several practical applications in modern technology, such as in the development of GPS systems and particle accelerators. It also plays a crucial role in understanding the behavior of subatomic particles and the structure of the universe. Additionally, the principles of Special Relativity are used in various fields, including astronomy, telecommunications, and nuclear energy.
