Special Relativity Knowledge Challenge (for experts only)
In summary, the conversation is about the derivation of the Lorentz equations of special relativity and the assumptions (postulates) used in the process. The first assumption narrows the field by assuming that the difference between events in one frame depends only on the difference in another. This is valid in special relativity, but not in a universe with gravitation. The derivation also assumes that x=vt and ignores the possibility of E=0, which is later treated separately. Some of the assumptions used in the derivation may require further justification, such as the invariance of the speed of light and the equality of coordinates perpendicular to the velocity. Overall, the derivation is considered good due to its generality and ease of understanding, but it
Aer
214
This is specifically targeted towards those who claim to be experts in the area of Special Relativity.
The following derivation derives the Lorentz equations of special relativity. Follow the derivation and list the assumptions (postulates) used to derive the theory. That is to say, if a postulate must exist for the use of a given equation, name the postulate and the equation number. Finally state whether you think this is a valid or invalid derivation.
Lorentz Equations Derivation
This shouldn't be too difficult for those with extensive experience in Special Relativity. Those without extensive experience are discouraged from participating, but I cannot stop you from doing so.
In my opinion, the first assumption is narrows the field (eliminates the most choices). They assume that the difference between events in one frame depends only on the difference in another. They assume:
[tex]\Delta x' = f (\Delta x, \Delta t)[/tex]
Rather then the more general case:
[tex] \Delta x' = f(x_1,x_2,t_1,t_2)[/tex]
The first case is fine for special relativity, in which the universe is the same everywhere in space and time (translational symmetry), but of course only the general case is correct in a universe with gravitation.
Notice that in the next section they use the assumption that x = vt. This is straightfoward, but I will have to read more to see why this does not conflict with the ability to handle accelerations in SR.
In equation (14) they ignore the possibility that E = 0. I had been wondering how they would avoid deriving the galilean transformations, and they did it by implicitly assuming E was not zero (although they do treat this case seperately later).
Overall, this is a good derivation because it includes a lot of generality and is not too difficult to follow.
In Eq. 12, the assumption is made that [tex]\gamma_{v2}[/tex] is here still only a function of [itex]v_2[/itex]. It may here be a function of both [itex]v_1[/itex] and [itex]v_2[/itex]. In that case the equations following Eq. 12 would be considerably more complicated. The condition derived from Eq. 14 that [itex]a[/itex] must be a constant in order to satify it, combined with the earlier assumption, replaces the classical postulate of the universality of lightspeed [itex]c[/itex] as a condition, which brings us back to Einstein. I favor the latter because that condition was empirically found, while the assumption in Eq. 12 is not proven.
The derivation includes some assumptions that are stated as if obvious.
It should be made more rigorous in this respect.
*In point 1), "We know..." is an assumption that requires justification.
*Point 4) about the group property should be justified.
Using it requires more complicated algebra than using the invariance of c.
*After specializing to 1D, he uses the assumption that an LT cannot depend on the direction of v. But a general LT does depend on the direction of v,
just not in gamma. This can be fixed up in the derivation, but not as it stands.
*"For a general LT... are equal", should be justified.
Actually, the invariance of the speed of light is an unecessary additional postulate. It follows from the equivalence of all inertial frames:
c is not just the speed of light, it is a parameter in most of the equations of EM. This is clearest in Gaussian units. In SI units, this dependence shows up in epsilon0. If the parameter c varied as the Earth moved, then most EM phenomena would vary. This is the reason for the title of Einstein's paper. From Maxwell's equations the invariant parameter c is shown to be the speed of light, thus deriving the second postulate from the first.
I've just started to look at the paper, but the same point struck me. The paper says
We know that the coordinates y and z perpendicular to the velocity are the same in both reference frames: y = y' and z = z'.
How do we know that in "the most general case"? I do not have a counterexample immediately at hand, but I'm not convinced that this assumption is true, either.
[Edited by Nereid: fixed mis-matched [ QUOTE ] tags]
You can probably apply a symmetry argument. I recall (from Mermin's little book?) an argument explaining why there is no "length contraction" in the perpendicular directions. Suppose each observer had an arm of rest length L along their transverse y-axes, with some marking device (like a pen) at the far ends. When they pass each other (assuming they are properly lined up), they would mark each other inconsistently if the transverse arms were affected by their motion.
From googling, here is a similar argument involving a hole and a bullet, part 5 in
http://cmtw.harvard.edu/Courses/Phys16/l1_latex/l1_latex.html
I think this paper is actually not as much a formal derivation as a somewhat arm-waving classroom demonstration. As such its aim is not to convince but persuade. Maybe it's also a challenge to the students to come up with just the kind of questions we have created here.
This is one of those "Lorentz Transformations without the speed of light" proofs where the value of the speed of light plays its role only in the last step. Of course, some other set of assumptions must be invoked and weaved into the storyline.
Depending on one's tastes on what one regards as fundamental or primitive or even "known by intended audience" (e.g. group structure? causal structure? electromagnetism? projective geometry? experimental facts?), one may or may not like these various approaches.
I have attached a chart from "Spacetime and Electromagnetism" by J.R. Lucas, P.E. Hodgson ( ) where they try to diagram the various approaches to obtain the Lorentz Transformations. [Certainly, the chart is not complete... but merely representative.]
Search the American Journal of Physics (http://scitation.aip.org/ajp/ ) for specific papers. Try to search for say, Lorentz, in the keyword field. WOW! You can now search all the way back to the first issue from 1933... and download articles (for free, if your school has access).
My personal favorites (in the terminology of the chart) include pseudoangles, Michelson-Morley, radar, metric, and causality/partial ordering.
PS: If the goal is to move on to GR or beyond, where many of symmetries enjoyed by Minkowski spacetime are not available, some of these approaches might not be so easy to extend.
My $0.02.
There is an article in there about things like extinction in the MMX experiment etc. It seems very complete and a very interesting read when I get around to it.
Pete
"*In point 1), "We know..." is an assumption that requires justification."
I did not mean by that that there aren't several reasonable arguments for that assumption. I just was responding to the "Follow the derivation and list the assumptions (postulates) used to derive the theory." directive in the question.
Even a "somewhat arm-waving classroom demonstration" should not confuse the students or suggest ad hoc assumptions. It certainly shouldn't be put on a website, even if it does lead to discussions about its shortcomings.
I sort of agree, although I'm more tolerant of loose derivations ("motivations"). I do like the idea that preserving length-ratios plus "reasonable" extra assumptions like no change in orthogonal directions, gives the LTs, because that would tie in with projective relativity, which I find interesting. If length ratios are preserved then so would be the cross-ratio, no?
From translational symmetry of space and time, we conclude that the functions f_x(x, t) and f_t(x, t) must be linear functions.
This assertion improperly combines an undefined notion (translational symmetry) with an incorrect statement (implied linearity).
Sorry, I kind of abandoned this after I posted it. Let me just say that I don't particularly like the derivation upon further analysis. Particularly equations 14 and 26 jump out at me. Feel free to discuss amongst yourselves :wink:
zero problem
Having read the derivation, I am struck by what seems to be a problem in equation (5) of the reference. In the lead in paragraph, the author states clearly that x = vt. This is substituted in equation (2) to find that B = -vA which is substituted back into equation (2) (!) and results in the equation x' = A(x - vt).
However, it has only just been stated that x = vt so x' = A(x - vt) = A(0) = 0.
Seems there is some confusion of terms going on here.
Related to Special Relativity Knowledge Challenge (for experts only)
1. What is the concept of special relativity?
Special relativity is a theory proposed by Albert Einstein in 1905 that explains the relationship between space and time. It describes how the laws of physics are the same for all observers in uniform motion and how space and time are relative to the observer's perspective.
2. How is special relativity different from general relativity?
Special relativity deals with the laws of physics in inertial frames of reference, while general relativity extends those laws to non-inertial frames of reference, such as those in gravitational fields. In other words, special relativity only applies to objects moving at constant velocities, while general relativity includes the effects of acceleration and gravity.
3. What is time dilation in special relativity?
Time dilation is the phenomenon where time appears to pass slower for an object in motion compared to an object at rest. This is a consequence of the fact that the speed of light is constant for all observers, regardless of their relative motion. As an object's speed increases, time appears to slow down for that object from the perspective of a stationary observer.
4. Can you explain the twin paradox in special relativity?
The twin paradox is a thought experiment where one twin travels at high speeds in space while the other remains on Earth. According to special relativity, time will appear to move slower for the traveling twin, so when they return to Earth, they will have aged less than their twin who remained on Earth. This paradox highlights the concept of time dilation in special relativity.
5. How has special relativity impacted modern science and technology?
Special relativity has revolutionized our understanding of space and time and has had a significant impact on modern science and technology. It has led to advancements in particle accelerators, GPS technology, and nuclear power, among others. It also paved the way for the development of general relativity, which is crucial for our understanding of the universe and its origins.
