Special Relativity, Light cones in Minkowski Diagrams
In summary, the conversation discusses the concept of a "light cone" and its relation to points outside and inside the cone in different frames of reference. It is mentioned that a point Q outside the cone can occur before or after a point P inside the cone, depending on the frame of reference. It is also stated that a point R inside the cone will always be in the future or past with respect to P, regardless of the frame of reference. The conversation also briefly touches on the transformation of light cones between frames and the concept of x2 > c2t2.
king vitamin
243
Show that a point Q outside the "light cone" can occur either before or after a point P inside the light cone (eg: at the origin), depending upon the frame of reference. Show that a point R inside the light cone is always in the future or in the past with respect to P, irrespective of frame S'.
this is just diagrams
I know this isn't a difficult problem, but I'm having trouble conceptualizing it because I've never even seen light cones displaced from the origin, let alone in other frames of reference. How does a light cone transform between reference frames? I can't picture it because the x' and ct' axes are no longer orthogonal when drawn over S, so I'm not sure how to represent things.
Hi king vitamin! :smile:
Forget the shape of the cone …
the question is just asking you to prove that x2 > c2t2, then in some frames t' > 0 but in others t' < 0 (while if x2 < c2t2, then in all frames, t' has the same sign). :wink:
In Special Relativity, the concept of a light cone is essential for understanding the relationship between space and time. A light cone is a geometric representation of the paths that light can take in a given reference frame. It is a cone-like shape with the tip at the origin, representing the present moment, and the sides extending outwards to represent the past and future.
In Minkowski Diagrams, the x-axis represents space and the ct-axis represents time. The light cone is represented by a 45 degree line, with the tip at the origin and the sides extending outwards. Any event that occurs within the light cone is considered to be in the causal future or past of the origin event, depending on the direction of the event.
Now, in the given scenario, we are considering a point Q outside the light cone and a point P inside the light cone. This means that the event at Q is not causally connected to the event at P, as it is outside the light cone. This also means that the event at Q can occur at any time, either before or after the event at P, depending on the frame of reference. This is because the concept of simultaneity is relative in Special Relativity, and different frames of reference will have different perspectives on the timing of events.
On the other hand, for a point R inside the light cone, it will always be in the future or past with respect to P, irrespective of the frame of reference. This is because any event within the light cone is causally connected to the event at the origin, and therefore, will always be considered to be in the future or past of the origin event.
To visualize this, we can consider the transformation of the light cone between frames of reference. As you mentioned, the x' and ct' axes are no longer orthogonal when drawn over S, so we cannot simply rotate the light cone to represent the new frame. Instead, we have to use the Lorentz transformation equations to calculate the coordinates of the light cone in the new frame.
In conclusion, the position of a point outside the light cone is relative and can occur either before or after the point inside the light cone, depending on the frame of reference. However, for a point inside the light cone, it will always be in the future or past with respect to the origin event, regardless of the frame of reference. The transformation of the light cone between frames of reference can be calculated using the Lorentz transformation
FAQ: Special Relativity, Light cones in Minkowski Diagrams
1. What is special relativity?
Special relativity is a theory in physics that describes the relationship between space and time. It was developed by Albert Einstein in the early 20th century and is based on the principle that the laws of physics are the same for all observers in uniform motion.
2. What are light cones in Minkowski diagrams?
Light cones are graphical representations of the paths that light travels in the four-dimensional space-time continuum. In Minkowski diagrams, light cones are represented as diagonal lines that divide the diagram into two regions: the forward light cone and the backward light cone.
3. How do light cones illustrate causality in special relativity?
Light cones illustrate causality in special relativity by showing the limits of cause and effect relationships. Anything that lies within the light cone can potentially have a causal influence on an event, while anything outside the light cone cannot have a causal influence.
4. Can objects travel faster than the speed of light in special relativity?
No, according to special relativity, the speed of light is the maximum speed at which anything can travel in the universe. This is because as an object approaches the speed of light, its mass increases and it requires more and more energy to accelerate it further.
5. How does special relativity impact our understanding of time and space?
Special relativity has fundamentally changed our understanding of time and space. It introduced the concept of time dilation, where time appears to pass differently for observers in relative motion, and length contraction, where objects appear to be shorter when moving at high speeds. It also showed that space and time are interconnected and cannot be considered separately.
