Special relativity particle observation puzzle
In summary, the two particles experience a space-time separation as they accelerate, which changes in accordance with the principle of relativity.
StatusX
2,570
Here's a little special relativity puzzle that I found interesting.
Say we have two particles initially at rest in a frame O and separated by a distance L. They begin to uniformly accelerate at t=0 in a direction along the line separating them, until they reach a velocity v at some time t, and then return to inertial motion. Say the first particle follows a path x(t) in O. Then since both particles undergo the same motion, the second particle follows the path x(t)+L. Thus at any time, the distance measured in O between the two particles is L. But this means that in the final rest frame of the particles, the separation has expanded to [itex]\gamma[/itex] L. What's going on? What happens to the separation as observed by the two particles during this process?
I think the answer would have to do with the relativity of simultaneity--if they both start and stop accelerating simultaneously in O, then in any other inertial frame, they started accelerating at different moments and stopped accelerating at different moments, so the distance between them would be constantly changing.
That's true, but a little more analysis shows an interesting effect. Consider what the separation the particles observe during their acceleration.
As observed in the reference frame of the trailing particle, assumed for simplicity to be accelerating uniformly, will reckon the leading particle to be higher up in a gravitational field, i.e. the one produced by acceleration. The leading particle in this accelerating frame will be reckoned, due to gravitational time dilation, to having his clock to be running at a higher rate as reckoned by the trailing particle. Thus in the rest frame of the trailing particle the leading particle will be measured to be accelerating in the trailing particle's rest frame and thus the distance measured in that frame will be an increasing function of time.
Pete
Assuming that t=0 is defined in frame O, this is known as Bell's spaceship paradox.
see for example:
http://en.wikipedia.org/w/index.php?title=Bell's_spaceship_paradox&oldid=140470138
http://www.math.ucr.edu/home/baez/physics/Relativity/SR/spaceship_puzzle.html The two particles do in fact separate as measured in their own frame. If one desires the particles to maintain a constant distance ('Born rigid motion'), the lead particle must have a lower proper acceleration than the trailing particle.
In the modified version, the lead particle accelerates for a longer proper time at a lower acceleration, winding up with the same velocity as the tailing particle.
In this modified version, the lead particle maintains a constant proper distance from the trailing particle, and they both maintain a constant proper distance from some particular "pivot point".
In the unmodified problem, the particles separate.
See also "Born rigid motion"
on the WWW for example
http://www.mathpages.com/home/kmath422/kmath422.htm
Related to Special relativity particle observation puzzle
1. What is special relativity?
Special relativity is a theory proposed by Albert Einstein in 1905 to explain the relationship between space and time and how objects move in different reference frames. It states that the laws of physics are the same for all non-accelerating observers, and the speed of light in a vacuum is constant regardless of the observer's frame of reference.
2. What is the particle observation puzzle in special relativity?
The particle observation puzzle in special relativity refers to the phenomenon where particles moving at extremely high speeds appear to have different properties and behaviors than those observed at lower speeds. This puzzle has led to the development of theories such as quantum mechanics and the theory of relativity to explain these discrepancies.
3. How does special relativity affect particle observation?
Special relativity affects particle observation by introducing the concept of time dilation, where time appears to pass slower for objects moving at high speeds. This means that particles moving at high speeds may appear to have longer lifetimes or exhibit different behaviors than those observed at lower speeds. It also explains the relationship between mass and energy, as particles moving at high speeds have an increase in energy and mass.
4. Can special relativity be tested through particle observation?
Yes, special relativity can be tested through particle observation. Experiments such as the Large Hadron Collider (LHC) have been conducted to study high-energy particle collisions and confirm the predictions of special relativity, such as the existence of time dilation and energy-mass equivalence.
5. How does special relativity impact our understanding of the universe?
Special relativity has had a significant impact on our understanding of the universe by providing a framework for understanding the relationship between space and time and how objects move in different reference frames. It has also led to the development of other theories, such as general relativity and quantum mechanics, which have greatly expanded our understanding of the universe and its fundamental laws.
