Special Relativity Q: Choosing Light as Ref
In summary: A null worldline is a worldline that goes through the origin and has a slope of 0. That's what a pulse of light has, because there is no mass along its path and so it moves through spacetime at the speed of light.
Cathr
67
Special relativity states that the speed of light is constant for all the references, as long as they are not accelerating. For example, the speed of light would be c for a train moving linearly with a constant speed and would also be c for an observer who's not moving at all (I took the Earth as reference).
I know that it was proved experimentally, but I don't completely understant it. Is it true because of space and time dilation?
But what if we choose a photon as reference? How would the light itself perceive the movement of other objects, of the train and the observer for example? Wouldn't they be perceived as moving with the same speed?
We can't. This would mean that there is an inertial reference frame in which the photon (or pulse of light) is at rest. However, there is no such reference frame, because the speed of light is always c, in any inertial reference frame.
Likes Cathr
Usually the proof is written the other way. You start with the invariance of c and then you derive time dilation (TD) and length contraction (LC) and the relativity of simultaneity (RS). However, you certainly could write the proof backwards starting with TD, LC, and RS and then proving the invariance of c. I am pretty sure that nobody would find that proof particularly compelling.
There is no such thing as the reference frame of a pulse of light. An object's frame is a tetrad where the timelike vector is tangent to the object's worldline. The worldline of a pulse of light has a null tangent, and a null vector cannot be equal to a timelike vector.
Likes Cathr
Never thought of that, thank you!
Thank you!
What did you mean by the object's worldline? Is this the set of space vectors? And why does it have a null tangent for the pulse of light?
Cathr said:
Thank you!
If you haven't come across the term "worldline" yet, then the answer from @Dale may be a bit advanced. The basic answer is that light follows a special type of path through spacetime (it's called "null", because no proper time passes along its path). Particles with mass, on the other hand, follow "timelike" paths through spacetime, where proper time is experienced.
Likes Cathr and vanhees71
What if we take, as reference, a particle that moves really fast, with a speed very close to the one of light, will if also perceive the speed of light as being c?
Yes. But, more fundamentally, there is no such thing as a particle that moves fast. All velocities are relative. That particle would perceive you as moving near the speed of light.
Likes Douglas Sunday
It's hard to answer a "why" question, because it's not always clear what that means. But it is possible to start with the notions of time dilation, length contraction, and the relativity of simultaneity and use them to show that if something moves with speed ##c## in one inertial reference frame, it moves with speed ##c## in all inertial reference frames. The idea that all inertial reference frames are in this sense equivalent is the called the Principle of Relativity.
Once you grasp the idea that the speed ##c## is the same in all inertial reference frames you conclude that it's the fastest possible speed and that no reference frame can ever have that speed. Thus it's not possible to understand what things would look like from such a non-existent frame.
If you are familiar with space-time graphs you know that, for example, you can make a graph of time versus (one-dimensional) position. If you plot the position and time of a particle on such a graph you create the worldline of that particle.
Related to Special Relativity Q: Choosing Light as Ref
1. What is the concept of "Special Relativity Q: Choosing Light as Ref"?
Special Relativity Q: Choosing Light as Ref is a theory proposed by Albert Einstein in 1905 that describes the relationship between space and time in the absence of gravitational forces. It states that the laws of physics are the same for all observers in uniform motion and that the speed of light is constant for all observers.
2. Why is light chosen as the reference point in Special Relativity?
Light is chosen as the reference point in Special Relativity because it travels at a constant speed of 299,792,458 meters per second in a vacuum. This makes it a reliable reference point for measuring distances and time intervals, as well as for understanding the effects of motion on these measurements.
3. How does Special Relativity affect our understanding of space and time?
Special Relativity revolutionized our understanding of space and time by showing that they are not absolute, but rather relative to an observer's frame of reference. This means that the measurements of space and time can vary depending on the observer's relative motion, and the laws of physics remain the same for all observers.
4. What are some practical applications of Special Relativity?
Special Relativity has many practical applications, including the development of GPS technology, nuclear energy, and particle accelerators. It also plays a crucial role in telecommunications, as it allows for accurate time measurements between different locations.
5. Can Special Relativity be proven or tested?
Yes, Special Relativity has been extensively tested and proven through numerous experiments and observations. One of the most famous experiments is the Michelson-Morley experiment, which showed that the speed of light is constant for all observers, regardless of their relative motion. Additionally, many modern technologies, such as GPS, would not work without taking into account the principles of Special Relativity.
