Special Relativity & Relativistic Mass
In summary, according to this source, the energy is added to the particle's kinetic energy. This can be as large as you like without ever exceeding the speed of light.
Jimmy87
686
Hi,
If a particle is within 2 m/s of the speed of light (like at CERN) and then more energy is transferred to the particle, where does this energy go? Some sources I have read talk about relativistic mass getting bigger and approaching infinity as a particle approaches 'c'. However, this source which seems reliable (as he has worked all his life in particle accelerators) says that there is no such thing as relativistic mass - it is just a useful concept to help make equations easier to work with:
So if a particle really only has one single mass and there is no such thing as relativistic mass then where does the energy go if you keep transferring it to a particle that is within 1 or 2 m/s of 'c'?
Thanks
The added energy increases the kinetic energy of the particle. The total energy of the particle (including both the contributions of its rest mass and its kinetic energy) is ##\gamma mc^2##, where ##\gamma=1/\sqrt {1-v^2/c^2}##. That can be as large as you like without ever exceeding the speed of light.
Some sources call the quantity ##\gamma m## the relativistic mass. That has largely dropped out of favour because it tends to lead to incorrect guesses (e.g. "do I become a black hole if I go really fast?") and lots of confusion between "rest mass" and "relativistic mass". So now we use "mass" to mean "rest mass" and don't use "relativistic mass". Relativistic mass is just total energy divided by ##c^2##, anyway, so you can always talk about total energy if you need the concept.
Likes Jimmy87
Thanks that helps! If the mass stays the same though I still don't get where the energy physically is when you transfer more to it. If the kinetic energy goes up but it can't go faster or get more massive then the energy must be doing something?
Energy isn't anywhere. It's just an accounting mechanism, really.
For example, you are presumably sitting somewhere. Your kinetic energy is zero in your local frame of reference. But the Earth is doing 20km/s around the Sun. So your kinetic energy in the solar system frame of reference is about ten billion Joules (if my mental arithmetic is reliable). Both answers are correct; your kinetic energy depends on who is doing the measuring. So it can't "be" anywhere.
Likes Jimmy87
This is quite a good question, I think. There is, in fact, a similar conundrum in good old classical physics, where KE is ##\frac{1}{2}mv^2##.
If, in your reference frame, an object of unit mass accelerates from ##0## to ##1m/s## then it gains ##0.5J##.
But, in a reference frame where the object accelerates from ##10## to ##11m/s## it gains ##10.5J##.
How can the energy be frame dependent? How can you get different answers for the energy gained depending on how you are moving relative to the object?
If the object is a car, could you not simply measure the fuel consumption to see who is right?
If you know a bit of physics you might like to think about this.
Likes Jimmy87
Ok, well let's say we are in the frame of a particle physicist measuring the speed of the particle. He/she increases the kinetic energy (and speed) of the particle until it gets to within 2 m/s of 'c' from their frame of reference. They keep injecting more and more energy into the particle but it can't get any faster (at least not much) or any more massive, so if the physicist is transferring more energy to the particle what is happening to the particle as a result. It like dropping a tennis ball on the floor and asking "where did the energy go?" - answer - into heat and sound. So "where did the energy I transferred to the particle that was already going within 2 m/s of 'c'?". Into sound? Heat? Obviously not - but where?
How could that situation exist? If I am in a car going at 30m/s and increase to 31m/s surely both me and stationary observer agree I have gone from 30 to 31m/s. In my car I could use the time it takes to go between road signs to deduce my speed couldn't I? Which would still give me the same as the stationary observer?
Into the kinetic energy of the particle. Do you have any program that can plot a graph? Excel for example? Or just pen and paper. You might like to plot the kinetic energy as velocity increases towards c (I gave you the total energy in #2 - kinetic energy is just the total energy, ##\gamma mc^2##, minus the rest mass energy, ##mc^2##, so ##K.E.=(\gamma-1)mc^2##).
Likes Jimmy87
According to the roadside observer the road signs are stationary and you are moving north (picking a direction out of a hat). According to you, you are stationary and the road signs are moving south. So, no. You determine that the road signs have the same speed in the opposite direction as the roadside observer says you have.
This was the point behind Einstein's famous "when does Oxford stop at this train" comment. Conventionally, we regard the train as moving. But there's nothing wrong with thinking of Oxford as moving and the train as stationary. Either view is fine, and it is a key principle of relativity (actually called "the principle of relativity") that neither is wrong.
Likes Jimmy87
I think I get what your saying. You are saying that the gamma factor gets bigger since the particles mass and velocity can't change (if it is nearly at c). So the kinetic energy is not increasing because the mass is increasing but because the gamma factor increases?
I think there is a refinement in the wording, that is invariant mass From the exception of netting momentum of massless particles to zero. i.e. things not at rest, but invariant.
The speed continues to increase, it's just that at low speeds most of the energy goes into making the speed increase, but at high speeds most of it goes into making ##\gamma## bigger. The speed continues to increase as you transfer energy, getting closer and closer to ##c##, but ##\gamma## increaes beyond all bounds, there is no limit to how large it can get.
Likes Jimmy87
I think he's saying just the opposite. There is such a thing as relativistic mass, but it's a rather useless quantity. Particle physicists have never used it, as far as I know, and if there were cases where they did use it, they would have been quite rare. Certainly its use among authors of physics books has fallen off fairly rapidly in the last few decades.
That's how fast the car is going relative to the ground. But, of course, the Earth is rotating and orbiting the Sun, so your car is going much faster relative to a "stationary" observer in space.
To them, if your car accelerates by 1m/s that could represent a huge increase in kinetic energy.
Likes Jimmy87
The velocity changes, but it changes less for each additional injection of energy. This is so even at low speeds - 1J added to a stationary 1kg mass accelerates it to about 1.4m/s. Adding another 1J accelerates it to 2m/s, less than double the speed. This diminishing return effect gets stronger as you get closer to c.
Of course, an object with 2J of kinetic energy will hit twice as hard as one with 1J, whether they're 1kg masses moving at walking pace or atoms moving a tiny fraction under the speed of light.
Likes Jimmy87
I agree that invariant mass is a better term than rest mass. The point I was making was that you don't have to use either - you just use "mass", and use "total energy" for what used to be called "relativistic mass".
Likes Jimmy87 and nitsuj
oh, I totally missed that point but agree.
Over a long(er) period of time, the car is only 100 horse power. :smile:
So is gamma technically an energy store. Let me explain. We are taught that when energy is transferred it goes from one store to another - this helps show conservation of energy. So burning a fuel for example you may start off with 200J in the chemical store (fuel) and if you burn it all you will end up with 200J in the thermal store. So is gamma an energy store in this sense? If a particle is going at 99.99999999999% speed of light and transfer 1000000000J to it then would this be contained in the gamma store? Is this kosher?
Thanks for all the excellent info guys btw
In a particle accelerator energy is being transferred to the particle, and it's accounted for in the kinetic energy of the particle. That is, you transfer energy ##E## to the particle and the particle's kinetic energy increases by ##E##.
The only issue you're having is that the relationship between speed and kinetic energy is not what you think it is. You think that as the kinetic energy increases so does the speed. And you're absolutely correct about that. It's just that it doesn't increase in the way that doesn't seem to make sense to you.
##\gamma## is simply a mathematical function of the speed ##v##. The only reason it has a physical implication is that it's used in the formula that relates the kinetic energy to ##v##.
This "energy store" business is not helpful in my view.
Momentum: ##\mathbf{p} = \gamma m \mathbf{v}##
Energy: ##E = \gamma m c^2##
It is true that if something is moving near light-speed and you transfer momentum to it in the direction it's already going, the increase in its magnitude-of-momentum that you measure will be almost entirely in its ##\gamma##, and hardly at all in its ##v## (I'm assuming its mass stays constant). At very low speeds, on the other hand, the "roles" of ##\gamma## and ##v## here would be reversed: the increase in ##\gamma## would be negligible, while the increase in ##p## would be almost entirely accounted for by the increase in ##v##.
You'd also measure a corresponding increase in the object's energy, and that increase would be entirely accounted for by the increase in ##\gamma##, regardless of the object's initial speed.
The rate of kinetic energy gain by a car powered by a 100 horse power motor can greatly exceed 100 horse power if the highway is moving at multiple miles per second. This does not violate energy conservation once you consider the force the tires apply to the highway.
You're getting a bit confused by the mathematics. There is only a change in kinetic energy here. There is no gamma store. In fact if you expand the expression for gamma, you get:
##\gamma mc^2 = mc^2 + \frac{1}{2}mv^2 + \dots##
Where the remaining terms in the expansion have increasing orders of ##1/c^2##.
From this you can see that the relativistic expression for kinetic energy reduces to the classical expression where ##v## is small compared to ##c##.
In any case, there is no need to see relativistic kinetic energy as fundamentally different from classical kinetic energy. They just have different formulas, where one is an approximation of the other.
Are you able to reword that? I don't understand what you're saying.
Working entirely with Newton - if a car is doing v and increases to v+1 then the kinetic energy increase is m(2v+1)/2. This energy increase can be tiny in a frame where v was initially small or enormous where v was initially large. But the engine has the same power output and the time taken is the same in either frame (Newton, remember). This is not paradoxical, however, as long as you take into account what happened to the road. It also changes speed slightly, and if you include its kinetic energy change then the energy difference before and after the acceleration will work out to 100 hp times the time.
If you neglect the road then energy is not conserved. But that's because you are ignoring part of the scenario, not a fundamental problem with physics.
Likes jbriggs444
Related to Special Relativity & Relativistic Mass
1. What is the principle of relativity in special relativity?
The principle of relativity in special relativity states that the laws of physics should be the same for all observers, regardless of their relative motion.
2. How does special relativity affect the concept of time?
Special relativity introduces the idea of time dilation, which means that time passes slower for objects that are moving at high speeds. This is due to the fact that the speed of light is constant and time and space are relative.
3. What is relativistic mass and how does it differ from rest mass?
Relativistic mass is the mass of an object as it is measured by an observer in motion relative to the object. It differs from rest mass, which is the mass of an object at rest. Relativistic mass increases as an object's velocity approaches the speed of light.
4. How does special relativity explain the twin paradox?
The twin paradox is a thought experiment that illustrates the effects of time dilation in special relativity. It involves one twin staying on Earth while the other travels through space at high speeds. When the traveling twin returns, they will have aged less than the twin who stayed on Earth due to the effects of time dilation.
5. Can relativistic mass become infinite?
No, relativistic mass cannot become infinite. As an object's velocity approaches the speed of light, its relativistic mass will increase, but it will never reach infinity. The speed of light acts as a barrier, preventing objects from reaching infinite mass.
