Special relativity - scattering angle
The discussion revolves around calculating the maximum scattering angle of a particle with mass m1 colliding with a stationary particle of mass m2 (where m2 < m1) at relativistic speeds. The participant sets up the problem using 4-momenta and conservation laws, deriving an expression for cos(θ) related to the energies and masses involved. They encounter difficulties in solving the derivative of cos(θ) and express uncertainty about their calculations. Ultimately, they arrive at a plausible result for the maximum angle, cos(θ_max) = √(1 - m2²/m1²), which is confirmed as correct and aligns with non-relativistic results, indicating the independence from the incoming particle's speed. The conversation emphasizes the importance of careful setup and verification in complex relativistic problems.
Aleolomorfo
Finding the maximum scattering angle of a particle whose mass in ##m_1## which hits with relativistic velocity ##v## a particle at rest with mass ##m_2<m_1##.
I've written the 4-momenta (p before the collision, k after the collision and the z-axis is along the direction of the incident particle):
$$p_1=(m_1\gamma,0,0,m_1\gamma v)$$
$$p_2=(m_2,0,0,0)$$
$$k_1=(E,0,\sqrt{E^2-m^2_1}\sin{\theta},\sqrt{E^2-m^2_1}\cos{\theta})$$
For ##k_2## the components are not important, it's important that ##k^2_2=m^2_2##
Then I've used the conservation of 4-momentum ##p_1+p_2=k_1+k_2##, then ##k_2=p_1+p_2-k_1##, then ##k^2_2=p^2_1+p^2_2+k^2_1+2p_1p_2-2p_1k_1-2p_2k_1##. After calculations I've found:
$$\cos{\theta}=\frac{m^2_1+m_1m_2\gamma-2E(m_1\gamma+m_2)}{m_1\gamma v\sqrt{E^2-m^2_1}}$$.
Then I've taken the derivative ##\frac{d(\cos{\theta})}{dE}## and put it equal to 0. However, I've found an equation quite difficult to solve and I think it's wrong.
I think the way I set up the problem is not incorrect, but maybe there is a easier way or some trick to reduce calcus.
Check the overall sign of the right hand side of the equation for ##\cos \theta## and also check if the factor of 2 in the numerator is correct.
With the corrections mentioned above, it will work out if you slog through it. I don't know of a clever trick to reduce the algebra. Maybe someone else can show us a better way.
Likes Aleolomorfo
Thank you for your help. The worst is when you make a mistake at the beginning. My result is ##\cos{\theta_{max}}=\sqrt{1-\frac{m^2_2}{m^2_1}}##, I think it's correct or at least is plausible.
Yes, that's the correct answer. It's even nicer when expressed in terms of ##\sin \theta##. Since the answer is independent of the speed of the incoming particle, the result is the same as the nonrelativistic, Newtonian result.
