Special Relativity -- Velocity transformation
In summary: You should be able to calculate the velocity of the other ball in the frame of the ball. In summary, the x-velocities of the balls with respect to the ground are 0.94 and 0.58, and the x-velocity of the first ball with respect to the second is uncertain but can be calculated using the velocity transformation equations.
Lito
A train travels in the +x direction with a speed of β = 0.80 with respect to the ground. At a certain time, two balls are ejected, one traveling in the +x direction with x-velocity of +0.60 with respect to the train and the other traveling in the −x direction with x-velocity of −0.40 with respect to the train.
(a) What are the x-velocities of the balls with respect to the ground?
(b) What is the x-velocity of the first ball with respect to the second? [Hint: The frames you will choose to be the Home Frame and the Other Frame for part (a) will not be the same as your choices for part (b).]
(a) Using the transformation equations: β= 0.8
Train Frame:
$$ V'_{xL}= +0.6 , V'_{xR}= -0.4 $$
Ground frame:
$$ V_{xR}=\frac{0.6+0.8}{1+0.6*0.8} = 0.94 $$
$$ V_{xL}=\frac{-0.4+0.8}{1-0.4*0.8}= 0.58 $$
** No question about this section **
(b)
I thought taking the Train frame as the home frame and the +0.6 ball as the Other frame.Drawing the -0.4 ball worldline, I can take a random event on this line and transform Δx and Δt in the home frame to Δx' and Δt' in the Other frame.
Calculating Δx' /Δt' will evaluate the speed of the -0.4 ball with respect to +0.6 ball.Is this process correct?
Thanks so much!
(a) Using the transformation equations:β= 0.8
Train Frame:
Ground frame:
(b)
Thanks so much!
(Try not to use so much Bold face type.)
I'm uncertain whether that process is correct or not.
I would be inclined to use one of the balls ( probably the -0.4 ball) as one of your frames and the train as the other.
You know the velocity of the train in the frame of the ball, and the velocity of the other ball in the frame of the train.
Likes Lito
FAQ: Special Relativity -- Velocity transformation
What is special relativity?
Special relativity is a theory proposed by Albert Einstein in 1905 to explain how objects move at high speeds and how time and space are perceived by observers in different frames of reference.
What is the velocity transformation in special relativity?
The velocity transformation in special relativity is a mathematical formula used to calculate the velocity of an object from the perspective of two different observers, who are moving relative to each other at a constant velocity.
How does special relativity affect our understanding of time and space?
Special relativity states that time and space are relative concepts and can be perceived differently by observers in different frames of reference. It also shows that the laws of physics are the same for all observers, regardless of their relative motion.
What is the difference between special relativity and general relativity?
Special relativity deals with objects moving at constant velocities in a straight line, while general relativity includes the effects of gravity and accelerated motion. General relativity is a more comprehensive theory that includes special relativity as a special case.
How has special relativity been confirmed by experimental evidence?
There have been numerous experiments that have confirmed the predictions of special relativity, such as the famous Michelson-Morley experiment and the measurement of time dilation in high-speed particle accelerators. GPS technology also relies on the principles of special relativity to make accurate calculations.
