Special subspace of M(2*3) (R)
  • Thread starter estro
  • Tags
    Subspace
In summary, the conversation is about finding a subspace T to satisfy the conditions T+W=M_{2*3} and T \cap W=0. The approach involves finding 6 linearly independent matrices, possibly by using Gram-Schmidt, to serve as a basis for T. The issue is that the matrices in W are linearly dependent, so 4 more independent matrices need to be found.
estro
241
[tex]W=Sp\{\left( \begin{array}{ccc} 1 & 1 & 1 \\ 1 & 2 & 3 \end{array} \right), \left( \begin{array}{ccc} 1 & 0 & 1 \\ 2 & 2 & 3 \end{array} \right), \left( \begin{array}{ccc} -1 & 1 & -1 \\ -3 & -2 & -3 \end{array} \right) \}[/tex]
I have to find subspace T, so that [tex]M_{2*3}(R)=W\oplus T[/tex]
I solved it by finding 5 liner independent matrices (in relation to matrices in W) and made them basis for T.
I'll appreciate any ideas.
not sure if I'm reading it correctly but don't you need to find the matricies orthogonal to those in W
you will need 6 linearly independent matricies to span M_2,3
Maybe I should clear myself.
I have to find a liner space T so that, [tex]T+W=M_{2*3}[/tex] and [tex]T \cap W=0[/tex]
I've noticed that matricies from [tex]
[/tex] are liner dependent, so I have to find 4 more independent matrices.
ok, so what's the issue?
note if it helps you can wirte them as 6-vectors and do normal gram-schimdt...
FAQ: Special subspace of M(2*3) (R)
What is a special subspace?
A special subspace is a subset of a larger mathematical space that satisfies certain properties or conditions. In this case, the special subspace is a subset of the space M(2*3) (R) which consists of all 2x3 matrices with real number entries.
How is a special subspace different from a regular subspace?
A special subspace is a specific type of subspace that satisfies additional conditions beyond those required for a general subspace. These conditions can vary depending on the context, but typically involve specific properties or relationships between the elements of the subspace.
What are the dimensions of the special subspace in M(2*3) (R)?
The dimensions of the special subspace in M(2*3) (R) depend on the specific conditions or properties that define the subspace. In general, a subspace of M(m*n) (R) has dimensions that are less than or equal to the dimensions of the larger space, so the dimensions of the special subspace in this case would be between 0 and 6.
How is a special subspace useful in mathematics?
Special subspaces are useful in mathematics because they allow us to study specific types of structures or relationships within a larger space. By defining certain conditions for the subspace, we can gain a deeper understanding of the properties and behaviors of the elements within that subspace.
Can a special subspace exist in other types of mathematical spaces?
Yes, special subspaces can exist in any type of mathematical space that allows for subspaces to be defined. These can include vector spaces, function spaces, and more. The specific conditions or properties that define a special subspace may vary depending on the type of space, but the concept remains the same.
