Special theory of relativity, a collision between two partic
In summary, the collision of two particles, one with a mass m and a speed of 0.6c and the other at rest, results in the formation of a new particle with a mass of 2.12m and a velocity of 0.33c. This is based on the conservation of momentum and energy, using the equations ##E^2 = p^2c^2 + m^2c^4## and ##v/c = pc/E##.
alizeid
A particle of mass m comes with the speed 0.6c and collides with another particle of mass m which is at rest. In the collision melts the particles together and form a particle. What is the mass and velocity of the particle is formed?
solution:
The momentum and the total energy is conserved
[tex]E_{before}=\frac{mc^2}{\sqrt{1-\frac{v^2}{c^2}}}+mc^2,v=0.6c \\ \Rightarrow E_{before}=2.25mc^2 \\ [/tex]
[tex]E_{after}=\frac{Xmc^2}{\sqrt{1-\frac{z^2}{c^2}}}\\ [/tex] , where xm is the new mass and z is the velocity
Now, the energy is conserved
[tex]\frac{Xmc^2}{\sqrt{1-\frac{z^2}{c^2}}}=2.25mc^2\Leftrightarrow X^2=2.25^2(1-\frac{z^2}{c^2})\\ [/tex]
Now we do the same for momentum:
[tex]P_{befor}=\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}}, v=0.6c\Rightarrow P_{befor}=0,75mc[/tex]
momentum after the collision:
[tex]P_{after}=\frac{mz}{\sqrt{1-\frac{z^2}{c^2}}}[/tex]
the momentum is conserved:
[tex]\frac{mz}{\sqrt{1-\frac{z^2}{c^2}}}=0.75mc\Leftrightarrow xz=0.75c\cdot\sqrt{1-\frac{z^2}{c^2}}\\ \Leftrightarrow x^2z^2=0.75^2c^2\cdot(1-\frac{z^2}{c^2})[/tex]
we have from the first equation that [tex]x^2=2.25^2\cdot(1-\frac{z^2}{c^2})[/tex]:
[tex] x^2z^2=0.75^2c^2\cdot(1-\frac{z^2}{c^2})\\ \Leftrightarrow 2.25^2\cdot(1-\frac{z^2}{c^2})z^2=0.75^2c^2\cdot(1-\frac{z^2}{c^2})\\ z^2=\frac{0.75^2}{2.25^2}c^2\\ \Leftrightarrow z=0.33c[/tex]
Now we have z, and then we can solve X. I get x = 2.12. Thus the mass to be 2.12m and the speed 0.33c. Is this true? Thanks for the help
Te momentum of the new particle after the collision must be based on the mass after collision. Otherwise you have more or less the idea. Just one comment, for any particle, you can use the relations ##E^2 = p^2c^2 + m^2c^4## and ##v/c = pc/E##.
Thanks for the tip but is it correct answer?
Yes. The answer looks reasonable.
Thank you very much!
Related to Special theory of relativity, a collision between two partic
What is the Special Theory of Relativity?
The Special Theory of Relativity, also known as the Theory of Special Relativity, is a scientific theory developed by Albert Einstein in 1905 that explains how objects in motion appear to observers and how time and space are perceived by different observers. It is based on two main principles: the laws of physics are the same for all observers in uniform motion, and the speed of light is constant in a vacuum regardless of the observer's frame of reference.
What is meant by a "collision" in the Special Theory of Relativity?
In the Special Theory of Relativity, a collision refers to the interaction between two particles moving at high speeds. This can include particle collisions in a particle accelerator or collisions between celestial bodies in space. The theory explains how the energy and momentum of the particles involved in the collision are conserved, and how the results of the collision may appear different to different observers depending on their relative motion.
How does the Special Theory of Relativity explain time dilation in a collision?
According to the Special Theory of Relativity, time is relative and can appear to pass at different rates for observers in different frames of reference. In a collision between two particles moving at high speeds, the time experienced by each particle may appear to pass at a different rate to an outside observer. This is known as time dilation and is a fundamental concept in the Special Theory of Relativity.
What are the implications of the Special Theory of Relativity on our understanding of the universe?
The Special Theory of Relativity has had a significant impact on our understanding of the universe and has led to many advancements in modern physics. It has helped to explain phenomena such as time dilation, length contraction, and the equivalence of mass and energy. It also plays a crucial role in other theories, such as the General Theory of Relativity and the Standard Model of particle physics, and has been confirmed through numerous experiments and observations.
Are there any practical applications of the Special Theory of Relativity?
Yes, the Special Theory of Relativity has many practical applications in modern technology. For example, it is used in the development of GPS systems, which rely on precise timing and the concept of time dilation to function accurately. It is also essential in the field of nuclear energy and particle accelerators, where it helps to understand the behavior of subatomic particles at high speeds. Additionally, the theory has influenced our understanding of space and time, leading to advancements in fields such as cosmology and astrophysics.
